uszkodzony plik .mov - plik uszkodzony .mtd - Jak uratować nagranie .mov bez zna
15 Maj 2019 13:32 174 6
  • Poziom 2  
    początek pliku uszkodzonego z HXD
    poprawiłem na :
    00 00 00 18 66 74 79 70 71 74 20 20 20 11 07 00 71 74 20 20 70 61 6E 61 00 03 FF 71 6D 6F 6F 76 00 00 00 6C 6D 76 68 64 00 00 00 00 D8 FD FF 73 D8 FD A1 24 00 02 BF 20 00 2E 24 80 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 27 C9 74 72 61 6B 00 00 00 5C 74 6B 68 64 00 00 00 0F D8 FD A1 24 D8 FD A1 24 00 00 00 01 00 00 00 00 00 2E 24 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 07 80 00 00 04 38 00 00 00 00 00 24 65 64 74 73 00 00 00 1C 65 6C 73 74 00 00 00 00 00 00 00 01 00 2E 24 80 00 00 0E 10 00 01 00 00 00 00 00 14 74 72 65 66 00 00 00 0C 74 6D 63 64 00 00 00 03 00 00 27 2D 6D 64 69 61 00 00 00 20 6D 64 68 64 00 00 00 00 D8 FD A1 24 D8 FD A1 24 00 02 BF 20 00 2E 24 80 55 C4 00 00 00 00 00 21 68 64 6C 72 00 00 00 00 6D 68 6C 72 76 69 64 65 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 26 E4 6D 69 6E 66 00 00 00 14 76 6D 68 64 00 00 00 01 00 40 80 00 80 00 80 00 00 00 00 21 68 64 6C 72 00 00 00 00 64 68 6C 72 61 6C 69 73 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 24 64 69 6E 66 00 00 00 1C 64 72 65 66 00 00 00 00 00 00 00 01 00 00 00 0C 61 6C 69 73 00 00 00 01 00 00 26 83 73 74 62 6C 00 00 02 5F 73 74 73 64 00 00 00 00 00 00 00 01 00 00 02 4F 61 76 63 31 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 80 04 38 00 48 00 00 00 48 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 FF 00
    plik nie uszkodzony z którego brałem początek (5 różnych filmików z tej samej kamerki ma taki sam początek) uszkodzony plik .mov - plik uszkodzony .mtd - Jak uratować nagranie .mov bez zna
    Proszę o pomoc co trzeba jeszcze poprawić
    pod offsetem 0x20 jest nagłówek struktury, w której one siedzą ? 00 05 FF 72 00 ??
    plik uszkodzony zajmuje 47,2 GB
    podczas nagrania kamera się zawiesiła :( oribowałem za pomoca róznych aplikacji naprawić plik ale w końcu zobaczyłem że są tutaj magicy którzy to ogarniają , dlatego proszę o pomoc i z góry dziękuje
    Analiza :
    Wszystkie "dobre pliki" zaczynają się tak samo:
    66 74 79 70 71 74 ftypqt czyli "typ formatu QuickTime"
    71 74 20 20 20 qt i dwie spacje czyli "QuickTime"
    6D 6F 6F 76 moov firmowe oznaczenie pliku z rozszerzeniem MOV
    6D 76 68 64 mvhd film w wersji HD
  • Poziom 23  
    Wrzuć uszkodzony plik oraz dowolny inny plik z tego samego urządzenia na jakiś hosting.
  • Poziom 2  
    Próbowałem Remo repair MOV niestety program sie sam zamyka :(
    plik przykładowy dobry :
    https://uloz.to/!TtEgaPDJvmBC/p1077781-mov
    uszkodzony plik ma 47,2 GB nie dam rady wrzucić go na hosting :( chyba że zrobie konwersje ale nie wiem czy w kodach HxD sie nie zrobi bałagn?
    kindlar napisał:
    Tu https://www.youtube.com/watch?v=0gKTgdtMgpw widzę programik, który na podstawie dobrego pliku naprawia uszkodzony.
    komunikat z błedem uszkodzony plik .mov - plik uszkodzony .mtd - Jak uratować nagranie .mov bez zna
  • Poziom 23  
    Nie zauważyłem rozmiaru. Ale na pewno nic nie rób z plikiem źródłowym, żadna konwersja. Naprawa tylko i wyłącznie na kopii pliku.
  • Poziom 2  
    Plik uszkodzony: mtd
    https://www.myqnapcloud.com/share/6d5856k64l6...YQmkxM_6NCxQHizFv6sC4CRFYgfuLl61Upe21lA#/home
    plik wzorcowy z kamery:
    https://www.myqnapcloud.com/share/6d5856k64l6...YR-vZCoEAnv4w52bbayCoYu18F_TkW7fczomb04#/home
    kolejny plik wzorcowy z kamery:
  • Poziom 33  
    Utwórz jakiś katalog na dysku wrzuć tam ten uszkodzony.mdt i program (załącznik) odpal program i czekaj
    przy prawie 50gb nie wiem ile to będzie trwało ale myślę że film z komunii da się odzyskać. :)
