[Rozwiązano] Odblokowanie LCP w falowniku VLT 5000 - jak przywrócić dostęp?
Grzegorz_madera 20 Maj 2019 20:57 537 2
    adamjk
    Grzegorz_madera napisał:
    jak przywrócić nastawy fabryczne żeby zlikwidować blokadę?
    Initialisation to factory setting
    The frequency converter can be initialised to
    factory settings in two ways.
    Initialisation by parameter 620
    - Recommended initialisation
    • Select parameter 620
    • Press [CHANGE]
    • Select "Initialisation"
    • Press the [OK] key
    • Cut off the mains supply and wait until
    the display turns off.
    • Reconnect the mains supply - the frequency
    converter is now reset.
    This parameter initialises all except:
    500 Serial communication address
    501 Baud rate for serial communication
    601-605 Operating data
    615-617 Fault logs
    Manual initialisation
    • Disconnect from mains and wait until the
    display turns off.
    • Press the following keys at the same time:
    [Display/status]
    [Change data]
    [OK]
    • Reconnecting the mains supply while
    pressing the keys.
    • Release the keys
    • The frequency converter has now been
    programmed for the factory setting.
    600-605 Operating data
    NB!:
    Settings for serial communication and
    fault logs are reset.
