R Pi 3 - Serwer pptpd nie działa prawidłowo
07 Lip 2019 17:45 102 1
  • Poziom 11  
    Witam. zainstalowałem na R Pi 3 VPN server pptpd
    Mogę się połączyć z VPN ale nie działają strony na kliencie. Na R pi działają www. Sprawdzałem czy to DNS nie działa prawidłowo i niestety poprzez IP też nie mogę wyświetlić strony.
    pptpd-options
    Spoiler:
    Code:
    # $Id$
    # Sample Poptop PPP options file /etc/ppp/pptpd-options
    # Options used by PPP when a connection arrives from a client.
    # This file is pointed to by /etc/pptpd.conf option keyword.
    # Changes are effective on the next connection.  See "man pppd".
    # You are expected to change this file to suit your system.  As
    # packaged, it requires PPP 2.4.2 and the kernel MPPE module.
    # Authentication
    # Name of the local system for authentication purposes
    # (must match the second field in /etc/ppp/chap-secrets entries)
    name pptpd
    # Optional: domain name to use for authentication
    # domain mydomain.net
    # Strip the domain prefix from the username before authentication.
    # (applies if you use pppd with chapms-strip-domain patch)
    #chapms-strip-domain
    # Encryption
    # (There have been multiple versions of PPP with encryption support,
    # choose with of the following sections you will use.)
    # BSD licensed ppp-2.4.2 upstream with MPPE only, kernel module ppp_mppe.o
    refuse-pap
    refuse-chap
    refuse-mschap
    # Require the peer to authenticate itself using MS-CHAPv2 [Microsoft
    # Challenge Handshake Authentication Protocol, Version 2] authentication.
    require-mschap-v2
    # Require MPPE 128-bit encryption
    # (note that MPPE requires the use of MSCHAP-V2 during authentication)
    require-mppe-128
    # Network and Routing
    # If pppd is acting as a server for Microsoft Windows clients, this
    # option allows pppd to supply one or two DNS (Domain Name Server)
    # addresses to the clients.  The first instance of this option
    # specifies the primary DNS address; the second instance (if given)
    # specifies the secondary DNS address.
    # Attention! This information may not be taken into account by a Windows
    # client. See KB311218 in Microsoft's knowledge base for more information.
    #ms-dns 10.0.0.1
    #ms-dns 10.0.0.2
    # If pppd is acting as a server for Microsoft Windows or "Samba"
    # clients, this option allows pppd to supply one or two WINS (Windows
    # Internet Name Services) server addresses to the clients.  The first
    # instance of this option specifies the primary WINS address; the
    # second instance (if given) specifies the secondary WINS address.
    #ms-wins 10.0.0.3
    #ms-wins 10.0.0.4
    # Add an entry to this system's ARP [Address Resolution Protocol]
    # table with the IP address of the peer and the Ethernet address of this
    # system.  This will have the effect of making the peer appear to other
    # systems to be on the local ethernet.
    # (you do not need this if your PPTP server is responsible for routing
    # packets to the clients -- James Cameron)
    proxyarp
    # Normally pptpd passes the IP address to pppd, but if pptpd has been
    # given the delegate option in pptpd.conf or the --delegate command line
    # option, then pppd will use chap-secrets or radius to allocate the
    # client IP address.  The default local IP address used at the server
    # end is often the same as the address of the server.  To override this,
    # specify the local IP address here.
    # (you must not use this unless you have used the delegate option)
    #10.8.0.100
    # Debian: do not replace the default route
    nodefaultroute
    # Logging
    # Enable connection debugging facilities.
    # (see your syslog configuration for where pppd sends to)
    #debug
    # Print out all the option values which have been set.
    # (often requested by mailing list to verify options)
    #dump
    # Miscellaneous
    # Create a UUCP-style lock file for the pseudo-tty to ensure exclusive
    # access.
    lock
    # Disable BSD-Compress compression
    nobsdcomp
    # Disable Van Jacobson compression
    # (needed on some networks with Windows 9x/ME/XP clients, see posting to
    # poptop-server on 14th April 2005 by Pawel Pokrywka and followups,
    # http://marc.theaimsgroup.com/?t=111343175400006&r=1&w=2 )
    novj
    novjccomp
    # turn off logging to stderr, since this may be redirected to pptpd,
    # which may trigger a loopback
    nologfd
    # put plugins here
    # (putting them higher up may cause them to sent messages to the pty)
    pptpd.conf
    Spoiler:
    Code:
    # $Id$
    # Sample Poptop configuration file /etc/pptpd.conf
    # Changes are effective when pptpd is restarted.
    # TAG: ppp
    #   Path to the pppd program, default '/usr/sbin/pppd' on Linux
    #ppp /usr/sbin/pppd
    # TAG: option
    #   Specifies the location of the PPP options file.
    #   By default PPP looks in '/etc/ppp/options'
    option /etc/ppp/pptpd-options
    # TAG: debug
    #   Turns on (more) debugging to syslog
    #debug
    # TAG: stimeout
    #   Specifies timeout (in seconds) on starting ctrl connection
    # stimeout 10
    # TAG: noipparam
    #       Suppress the passing of the client's IP address to PPP, which is
    #       done by default otherwise.
    #noipparam
    # TAG: logwtmp
    #   Use wtmp(5) to record client connections and disconnections.
    logwtmp
    # TAG: bcrelay <if>
    #   Turns on broadcast relay to clients from interface <if>
    #bcrelay eth1
    # TAG: delegate
    #   Delegates the allocation of client IP addresses to pppd.
    #       Without this option, which is the default, pptpd manages the list of
    #       IP addresses for clients and passes the next free address to pppd.
    #       With this option, pptpd does not pass an address, and so pppd may use
    #       radius or chap-secrets to allocate an address.
    #delegate
    # TAG: connections
    #       Limits the number of client connections that may be accepted.
    #       If pptpd is allocating IP addresses (e.g. delegate is not
    #       used) then the number of connections is also limited by the
    #       remoteip option.  The default is 100.
    #connections 100
    # TAG: localip
    # TAG: remoteip
    #   Specifies the local and remote IP address ranges.
    #   These options are ignored if delegate option is set.
    #       Any addresses work as long as the local machine takes care of the
    #       routing.  But if you want to use MS-Windows networking, you should
    #       use IP addresses out of the LAN address space and use the proxyarp
    #       option in the pppd options file, or run bcrelay.
    #   You can specify single IP addresses seperated by commas or you can
    #   specify ranges, or both. For example:
    #      192.168.0.234,192.168.0.245-249,192.168.0.254
    #   IMPORTANT RESTRICTIONS:
    #   1. No spaces are permitted between commas or within addresses.
    #   2. If you give more IP addresses than the value of connections,
    #      it will start at the beginning of the list and go until it
    #      gets connections IPs.  Others will be ignored.
    #   3. No shortcuts in ranges! ie. 234-8 does not mean 234 to 238,
    #      you must type 234-238 if you mean this.
    #   4. If you give a single localIP, that's ok - all local IPs will
    #      be set to the given one. You MUST still give at least one remote
    #      IP for each simultaneous client.
    # (Recommended)
    localip 192.168.0.1
    remoteip 192.168.0.30-39
    # or
    #localip 192.168.0.234-238,192.168.0.245
    #remoteip 192.168.1.234-238,192.168.1.245
    sudo iptables -t nat -L -n
    Code:
    Chain PREROUTING (policy ACCEPT)
    target     prot opt source               destination
    Chain INPUT (policy ACCEPT)
    Chain OUTPUT (policy ACCEPT)
    Chain POSTROUTING (policy ACCEPT)
    cat /proc/sys/net/ipv4/ip_forward
    Code:
    1
    Proszę o pomoc. Może inny server vpn zainstalować?
  • Poziom 17  
    Hi,
    Ja obstawiam, ze pula adresów IP, która przypisujesz do klienta, nie podlega po NAT i próbujesz wychodzić z puli 192.168.X.X do Internetu.
    Jesli klientem jest Windows to po podłączeniu sie , pokaz tablice routingu na tej stacji , polecenie w cmd: route pirnt lub netstat -r
    Daj jakis rysunek tego rozwiązania, czy to jest tak, ze z jednej strony jesteś podlaczon kablem do sieci z internetem a od strony np wifi uruchamiasz pptpd i tam chcesz autoryzować klientów ?
    M
