IT SerwisIT Serwis
[Rozwiązano] AC58u naprawa po nieudanym wgraniu OpenWRT.
27 Sie 2019 17:04 390 1
  • Poziom 21  
    Witam. Posiadam router Asus RT-AC58U. Problem taki, że nie wstaje po próbie wgrania OpenWRT. Po podpięciu po UART:
    Spoiler:
    Format: Log Type - Time(microsec) - Message - Optional Info
    Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic
    S - QC_IMAGE_VERSION_STRING=BOOT.BF.3.1.1-00096
    S - IMAGE_VARIANT_STRING=DAABANAZA
    S - OEM_IMAGE_VERSION_STRING=CRM
    S - Boot Config, 0x00000021
    S - Core 0 Frequency, 0 MHz
    B - 261 - PBL, Start
    B - 1338 - bootable_media_detect_entry, Start
    B - 1678 - bootable_media_detect_success, Start
    B - 1692 - elf_loader_entry, Start
    B - 5068 - auth_hash_seg_entry, Start
    B - 7210 - auth_hash_seg_exit, Start
    B - 572126 - elf_segs_hash_verify_entry, Start
    B - 686905 - PBL, End
    B - 686930 - SBL1, Start
    B - 775254 - pm_device_init, Start
    D - 6 - pm_device_init, Delta
    B - 776764 - boot_flash_init, Start
    D - 54263 - boot_flash_init, Delta
    B - 835214 - boot_config_data_table_init, Start
    D - 3843 - boot_config_data_table_init, Delta - (419 Bytes)
    B - 842433 - clock_init, Start
    D - 7579 - clock_init, Delta
    B - 854535 - CDT version:2,Platform ID:8,Major ID:1,Minor ID:1,Subtype:0
    B - 858024 - sbl1_ddr_set_params, Start
    B - 863012 - cpr_init, Start
    D - 2 - cpr_init, Delta
    B - 867504 - Pre_DDR_clock_init, Start
    D - 4 - Pre_DDR_clock_init, Delta
    D - 13147 - sbl1_ddr_set_params, Delta
    B - 881206 - pm_driver_init, Start
    D - 2 - pm_driver_init, Delta
    B - 951635 - sbl1_wait_for_ddr_training, Start
    D - 29 - sbl1_wait_for_ddr_training, Delta
    B - 966862 - Image Load, Start
    D - 135001 - QSEE Image Loaded, Delta - (262104 Bytes)
    B - 1102357 - Image Load, Start
    D - 1445 - SEC Image Loaded, Delta - (2048 Bytes)
    B - 1112731 - Image Load, Start
    D - 223561 - APPSBL Image Loaded, Delta - (457299 Bytes)
    B - 1336713 - QSEE Execution, Start
    D - 58 - QSEE Execution, Delta
    B - 1342910 - SBL1, End
    D - 658091 - SBL1, Delta
    S - Flash Throughput, 2005 KB/s (721870 Bytes, 359867 us)
    S - DDR Frequency, 537 MHz
    U-Boot 2012.07-05763-g80e4eb4 [local,local] (Jul 06 2016 - 11:01:57)
    RT-AC58U bootloader version: 1.0.0.3
    smem ram ptable found: ver: 1 len: 3
    ASUS RT-AC58U gpio init : wps / reset pin
    DRAM: 128 MiB
    machid : 0x8010100
    Maximum malloc length: 4096 KBytes
    mem_malloc_start/brk/end: 0x86ef0000/86ef0000/87300000
    Relocation offset: 0
    NAND: spi_nand: spi_nand_flash_probe SF NAND ID 0:ef:aa:21
    SF: Detected W25N01GV with page size 2 KiB, total 128 MiB
    SF: Detected MX25L1605D with page size 4 KiB, total 2 MiB
    ipq_spi: page_size: 0x100, sector_size: 0x1000, size: 0x200000
    130 MiB
    *** Warning - bad CRC, using default environment
    In: serial
    Out: serial
    Err: serial
    0:SBL1 : 00000000 00040000
    0:MIBIB : 00040000 00020000
    0:QSEE : 00060000 00060000
    0:CDT : 000c0000 00010000
    0:DDRPARAMS : 000d0000 00010000
    0:APPSBLENV : 000e0000 00010000
    0:APPSBL : 000f0000 00080000
    0:ART : 00170000 00010000
    machid: 8010100
    Net: MAC0 addr:DELETED
    PHY ID1: 0x4d
    PHY ID2: 0xd0b1
    ipq40xx_ess_sw_init done
    eth0
    Creating 1 MTD partitions on "nand1":
    0x00000000-0x08000000 : "mtd=0"
    UBI: attaching mtd2 to ubi0
    UBI: physical eraseblock size: 131072 bytes (128 KiB)
    UBI: logical eraseblock size: 126976 bytes
    UBI: smallest flash I/O unit: 2048
    UBI: VID header offset: 2048 (aligned 2048)
    UBI: data offset: 4096
    UBI: max. sequence number: 1363
    UBI: attached mtd2 to ubi0
    UBI: MTD device name: "mtd=0"
    UBI: MTD device size: 128 MiB
    UBI: number of good PEBs: 1024
    UBI: number of bad PEBs: 0
    UBI: number of corrupted PEBs: 0
    UBI: max. allowed volumes: 128
    UBI: wear-leveling threshold: 4096
    UBI: number of internal volumes: 1
    UBI: number of user volumes: 7
    UBI: available PEBs: 10
    UBI: total number of reserved PEBs: 1014
    UBI: number of PEBs reserved for bad PEB handling: 10
    UBI: max/mean erase counter: 41/2
    UBI: image sequence number: 1543254291
    UBI: vol_id reserved_pebs alignment data_pad vol_type usable_leb_size us ed_ebs used_bytes last_eb_bytes corrupted upd_marker name_len name
    UBI: 0 3 1 0 dynamic 1f000 3 5d000 1f000 0 0 5 nvram
    UBI: 1 1 1 0 dynamic 1f000 1 1f000 1f000 0 0 7 Factory
    UBI: 2 1 1 0 dynamic 1f000 1 1f000 1f000 0 0 8 Factory2
    UBI: 3 12 1 0 dynamic 1f000 12 22e000 1f000 0 0 5 linux
    UBI: 4 18d 1 0 dynamic 1f000 18d 3013000 1f000 0 0 6 linux2
    UBI: 5 14 1 0 dynamic 1f000 14 26c000 1f000 0 0 6 rootfs
    UBI: 6 230 1 0 dynamic 1f000 230 43d0000 1f000 0 0 b rootfs_data
    UBI: 7fffefff 2 1 0 dynamic 1f000 2 3e000 2 0 0 d layout volum e
    UBI volume [linux] size 22e000 smaller than 3013000!
    UBI error: do_ubi: available_pebs 10 < MIN_AVAILABLE_PEB 30
    Latest UBI volumes layout.
    Read 0x1f000 bytes from volume [Factory] offset 0x0 to 86ec0ce8
    EEPROM set 0: OK (version 20)
    Read 0x1f000 bytes from volume [Factory2] offset 0x0 to 86ec0ce8
    EEPROM set 1: OK (version 20)
    Read 0x1f000 bytes from volume [Factory] offset 0x0 to 86ef3480
    Select EEPROM set 0 at offset 0x0.
    Please choose the operation:
    1: Load System code to SDRAM via TFTP.
    2: Load System code then write to Flash via TFTP.
    3: Boot System code via Flash (default).
    4: Entr boot command line interface.
    7: Load Boot Loader code then write to Flash via Serial.
    9: Load Boot Loader code then write to Flash via TFTP. 0
    MAC Address: DELETED
    Read 0x40 bytes from volume [linux] offset 0x0 to 84000000
    FIT/FDT format image found at 0x84000000, size 0x002280d0
    Read 0x228110 bytes from volume [linux] offset 0x0 to 84000000
    ## Booting kernel from FIT Image at 84000000 ...
    Using 'config@1' configuration
    Trying 'kernel@1' kernel subimage
    Description: ARM OpenWrt Linux-4.14.81
    Type: Kernel Image
    Compression: lzma compressed
    Data Start: 0x840000e4
    Data Size: 2243000 Bytes = 2.1 MiB
    Architecture: ARM
    OS: Linux
    Load Address: 0x80208000
    Entry Point: 0x80208000
    Hash algo: crc32
    Hash value: 22f4b1d3
    Hash algo: sha1
    Hash value: 470411dca88331f5363d0477b1addeaf727385fb
    ## Flattened Device Tree from FIT Image at 84000000
    Trying 'fdt@1' FDT blob subimage
    Description: ARM OpenWrt asus_rt-ac58u device tree blob
    Type: Flat Device Tree
    Compression: uncompressed
    Data Start: 0x84223bd4
    Data Size: 16396 Bytes = 16 KiB
    Architecture: ARM
    Hash algo: crc32
    Hash value: 81be304b
    Hash algo: sha1
    Hash value: ca8aac8ca80a4a7238c55700caced4e13f7bba1a
    Booting using the fdt blob at 0x84223bd4
    Read 0x28 bytes from volume [linux2] offset 0x0 to 86edfc40
    Uncompressing Kernel Image ... OK
    Loading Device Tree to 86ed8000, end 86edf00b ... OK
    ipq: fdt fixup unable to find compatible node
    Using machid 0x8010100 from environment
    Starting kernel ...
    [ 0.000000] Booting Linux on physical CPU 0x0
    [ 0.000000] Linux version 4.14.81 (buildbot@buildslave) (gcc version 7.3.0 (O penWrt GCC 7.3.0 r8459-3a6bddd7f7)) #0 SMP Wed Nov 14 17:41:18 2018
    [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
    [ 0.000000] CPU: div instructions available: patching division code
    [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
    [ 0.000000] OF: fdt: Machine model: ASUS RT-AC58U
    [ 0.000000] Memory policy: Data cache writealloc
    [ 0.000000] random: get_random_bytes called from start_kernel+0x88/0x3c4 with crng_init=0
    [ 0.000000] percpu: Embedded 15 pages/cpu @c7caf000 s29388 r8192 d23860 u6144 0
    [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32004
    [ 0.000000] Kernel command line: root_rfs=0x00000000 flash_type=norplusnand ubi.mtd=UBI_DEV
    [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
    [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
    [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
    [ 0.000000] Memory: 119984K/129024K available (4352K kernel code, 145K rwdata , 1196K rodata, 1024K init, 235K bss, 9040K reserved, 0K cma-reserved, 0K highme m)
    [ 0.000000] Virtual kernel memory layout:
    [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
    [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
    [ 0.000000] vmalloc : 0xc8000000 - 0xff800000 ( 888 MB)
    [ 0.000000] lowmem : 0xc0000000 - 0xc7e00000 ( 126 MB)
    [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
    [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
    [ 0.000000] .text : 0xc0208000 - 0xc07402d8 (5345 kB)
    [ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
    [ 0.000000] .data : 0xc0a00000 - 0xc0a24640 ( 146 kB)
    [ 0.000000] .bss : 0xc0a26000 - 0xc0a60c58 ( 236 kB)
    [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [ 0.000000] Hierarchical RCU implementation.
    [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [ 0.000000] arch_timer: cp15 timer(s) running at 48.00MHz (virt).
    [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb11fd3bfb, max_idle_ns: 440795203732 ns
    [ 0.000007] sched_clock: 56 bits at 48MHz, resolution 20ns, wraps every 43980 46511096ns
    [ 0.000023] Switching to timer-based delay loop, resolution 20ns
    [ 0.000253] Calibrating delay loop (skipped), value calculated using timer fr equency.. 96.00 BogoMIPS (lpj=480000)
    [ 0.000270] pid_max: default: 32768 minimum: 301
    [ 0.000407] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.000423] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.001041] CPU: Testing write buffer coherency: ok
    [ 0.001735] Setting up static identity map for 0x80300000 - 0x80300060
    [ 0.001881] Hierarchical SRCU implementation.
    [ 0.002534] smp: Bringing up secondary CPUs ...
    [ 0.005275] smp: Brought up 1 node, 4 CPUs
    [ 0.005294] SMP: Total of 4 processors activated (384.00 BogoMIPS).
    [ 0.005302] CPU: All CPU(s) started in SVC mode.
    [ 0.009403] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
    [ 0.009550] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns
    [ 0.009574] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [ 0.009773] pinctrl core: initialized pinctrl subsystem
    [ 0.010746] NET: Registered protocol family 16
    [ 0.011036] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [ 0.012078] cpuidle: using governor ladder
    [ 0.012121] cpuidle: using governor menu
    [ 0.029025] usbcore: registered new interface driver usbfs
    [ 0.029089] usbcore: registered new interface driver hub
    [ 0.029166] usbcore: registered new device driver usb
    [ 0.029220] pps_core: LinuxPPS API ver. 1 registered
    [ 0.029230] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
    [ 0.029254] PTP clock support registered
    [ 0.030511] clocksource: Switched to clocksource arch_sys_counter
    [ 0.031340] NET: Registered protocol family 2
    [ 0.032015] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.032046] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
    [ 0.032076] TCP: Hash tables configured (established 1024 bind 1024)
    [ 0.032184] UDP hash table entries: 256 (order: 1, 8192 bytes)
    [ 0.032221] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
    [ 0.032412] NET: Registered protocol family 1
    [ 0.033446] No memory allocated for crashlog
    [ 0.033628] workingset: timestamp_bits=30 max_order=15 bucket_order=0
    [ 0.036984] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.036997] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORIT Y) (c) 2001-2006 Red Hat, Inc.
    [ 0.042302] io scheduler noop registered
    [ 0.042322] io scheduler deadline registered (default)
    [ 0.044992] bam-dma-engine 8e04000.dma: num-channels unspecified in dt
    [ 0.045010] bam-dma-engine 8e04000.dma: num-ees unspecified in dt
    [ 0.045700] tcsr 1949000.tcsr: setting wifi_glb_cfg = 41000000
    [ 0.045789] tcsr 194b000.tcsr: setting usb hs phy mode select = e700e7
    [ 0.045863] tcsr 1953000.ess_tcsr: setting ess interface select = 0
    [ 0.045945] tcsr 1957000.tcsr: setting wifi_noc_memtype_m0_m2 = 2222222
    [ 0.046167] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
    [ 0.047939] msm_serial 78af000.serial: msm_serial: detected port #0
    [ 0.047985] msm_serial 78af000.serial: uartclk = 1843200
    [ 0.048038] 78af000.serial: ttyMSM0 at MMIO 0x78af000 (irq = 25, base_baud = 115200) is a MSM
    [ 0.048066] msm_serial: console setup on port #0
    [ 0.558587] console [ttyMSM0] enabled
    [ 0.563502] msm_serial: driver initialized
    [ 0.571077] loop: module loaded
    [ 0.572228] spi_qup 78b5000.spi: IN:block:16, fifo:64, OUT:block:16, fifo:64
    [ 0.574717] m25p80 spi0.0: mx25l1606e (2048 Kbytes)
    [ 0.581279] 8 fixed-partitions partitions found on MTD device spi0.0
    [ 0.585731] Creating 8 MTD partitions on "spi0.0":
    [ 0.592363] 0x000000000000-0x000000040000 : "SBL1"
    [ 0.597587] 0x000000040000-0x000000060000 : "MIBIB"
    [ 0.602338] 0x000000060000-0x0000000c0000 : "QSEE"
    [ 0.607020] 0x0000000c0000-0x0000000d0000 : "CDT"
    [ 0.611931] 0x0000000d0000-0x0000000e0000 : "DDRPARAMS"
    [ 0.616639] 0x0000000e0000-0x0000000f0000 : "APPSBLENV"
    [ 0.621738] 0x0000000f0000-0x000000170000 : "APPSBL"
    [ 0.626911] 0x000000170000-0x000000180000 : "ART"
    [ 0.632965] libphy: ipq40xx_mdio: probed
    [ 0.666940] ESS reset ok!
    [ 0.699912] ESS reset ok!
    [ 1.130943] libphy: Fixed MDIO Bus: probed
    [ 1.131847] EDMA using MAC@ - using
    [ 1.131864] DELETED
    [ 1.138042] EDMA using MAC@ - using
    [ 1.138053] DELETED
    [ 1.241503] i2c /dev entries driver
    [ 1.280755] nand: device found, Manufacturer ID: 0xef, Chip ID: 0xaa
    [ 1.280789] nand: Winbond W25N01GV 1G 3.3V 8-bit
    [ 1.286179] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB siz e: 64
    [ 1.291260] Scanning device for bad blocks
    [ 1.315808] random: fast init done
    [ 1.771067] random: crng init done
    [ 1.818201] 1 fixed-partitions partitions found on MTD device spi0.1
    [ 1.818233] Creating 1 MTD partitions on "spi0.1":
    [ 1.823666] 0x000000000000-0x000008000000 : "UBI_DEV"
    [ 1.831572] NET: Registered protocol family 10
    [ 1.835086] Segment Routing with IPv6
    [ 1.837784] NET: Registered protocol family 17
    [ 1.841519] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [ 1.846085] 8021q: 802.1Q VLAN Support v1.8
    [ 1.858959] Registering SWP/SWPB emulation handler
    [ 1.866693] ubi0: attaching mtd8
    [ 9.730104] ubi0: scanning is finished
    [ 9.785444] ubi0: attached mtd8 (name "UBI_DEV", size 128 MiB)
    [ 9.785479] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
    [ 9.790175] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
    [ 9.797065] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
    [ 9.803918] ubi0: good PEBs: 1024, bad PEBs: 0, corrupted PEBs: 0
    [ 9.810675] ubi0: user volume: 7, internal volumes: 1, max. volumes count: 12 8
    [ 9.816914] ubi0: max/mean erase counter: 41/2, WL threshold: 4096, image seq uence number: 1543254291
    [ 9.824062] ubi0: available PEBs: 0, total reserved PEBs: 1024, PEBs reserved for bad PEB handling: 20
    [ 9.833352] ubi0: background thread "ubi_bgt0d" started, PID 86
    [ 9.836934] block ubiblock0_5: created from ubi0:5(rootfs)
    [ 9.836941] ubiblock: device ubiblock0_5 (rootfs) set to be root f▒[ 9.886 031] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
    [ 9.908762] Freeing unused kernel memory: 1024K
    [ 11.630172] init: Console is alive
    [ 11.630403] init: - watchdog -
    [ 14.034240] kmodloader: loading kernel modules from /etc/modules-boot.d/*
    [ 14.713995] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [ 14.714062] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [ 14.718624] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f665 hci version 0x100 quirks 0x02010010
    [ 14.726039] xhci-hcd xhci-hcd.0.auto: irq 94, io mem 0x08a00000
    [ 14.735306] hub 1-0:1.0: USB hub found
    [ 14.740586] hub 1-0:1.0: 1 port detected
    [ 14.744635] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [ 14.748429] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [ 14.753758] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
    [ 14.761433] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [ 14.768569] hub 2-0:1.0: USB hub found
    [ 14.776279] hub 2-0:1.0: 1 port detected
    [ 14.780313] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [ 14.783901] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
    [ 14.789368] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f665 hci version 0x100 quirks 0x02010010
    [ 14.796763] xhci-hcd xhci-hcd.1.auto: irq 95, io mem 0x06000000
    [ 14.805962] hub 3-0:1.0: USB hub found
    [ 14.811323] hub 3-0:1.0: 1 port detected
    [ 14.815372] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [ 14.819175] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
    [ 14.824499] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
    [ 14.832136] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    [ 14.839129] hub 4-0:1.0: USB hub found
    [ 14.847021] hub 4-0:1.0: config failed, hub doesn't have any ports! (err -19)
    [ 14.852578] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
    [ 14.871081] init: - preinit -
    [ 15.530461] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [ 15.530614] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    Press the [f] key and hit [enter] to enter failsafe mode
    Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
    [ 18.835051] UBIFS (ubi0:6): background thread "ubifs_bgt0_6" started, PID 149
    [ 19.505333] UBIFS (ubi0:6): recovery needed
    [ 21.190781] UBIFS (ubi0:6): recovery completed
    [ 21.190926] UBIFS (ubi0:6): UBIFS: mounted UBI device 0, volume 6, name "rootfs_data"
    [ 21.194133] UBIFS (ubi0:6): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
    [ 21.202066] UBIFS (ubi0:6): FS size: 69836800 bytes (66 MiB, 550 LEBs), journal size 3555328 bytes (3 MiB, 28 LEBs)
    [ 21.211960] UBIFS (ubi0:6): reserved for root: 3298564 bytes (3221 KiB)
    [ 21.222187] UBIFS (ubi0:6): media format: w4/r0 (latest is w5/r0), UUID CB6E8FD5-E29B-49FC-ADF7-50E9B8372019, small LPT model
    [ 21.291453] mount_root: switching to ubifs overlay
    [ 21.409698] urandom-seed: Seeding with /etc/urandom.seed
    [ 21.745177] procd: - early -
    [ 21.745316] procd: - watchdog -
    [ 22.471615] procd: - watchdog -
    [ 22.474395] procd: - ubus -
    [ 22.614414] procd: - init -
    Please press Enter to activate this console.
    [ 22.924024] kmodloader: loading kernel modules from /etc/modules.d/*
    [ 22.927957] ip6_tables: (C) 2000-2006 Netfilter Core Team
    [ 22.936089] Loading modules backported from Linux version v4.19-rc5-0-g6bf4ca7fbc85
    [ 22.936128] Backport generated by backports.git v4.19-rc5-1-0-g05571dcd
    [ 22.945016] ip_tables: (C) 2000-2006 Netfilter Core Team
    [ 22.954119] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
    [ 22.987677] xt_time: kernel timezone is -0000
    [ 23.015551] PPP generic driver version 2.4.2
    [ 23.017118] NET: Registered protocol family 24
    [ 23.220813] ath10k_ahb a000000.wifi: Direct firmware load for ath10k/fwcfg-ahb-a000000.wifi.txt failed with error -2
    [ 23.220867] ath10k_ahb a000000.wifi: Falling back to user helper
    [ 23.262578] firmware ath10k!fwcfg-ahb-a000000.wifi.txt: firmware_loading_store: map pages failed
    [ 23.273232] ath10k_ahb a000000.wifi: Direct firmware load for ath10k/QCA4019/hw1.0/ct-firmware-5.bin failed with error -2
    [ 23.273288] ath10k_ahb a000000.wifi: Falling back to user helper
    [ 23.332807] firmware ath10k!QCA4019!hw1.0!ct-firmware-5.bin: firmware_loading_store: map pages failed
    [ 23.333201] ath10k_ahb a000000.wifi: Direct firmware load for ath10k/QCA4019/hw1.0/ct-firmware-2.bin failed with error -2
    [ 23.341082] ath10k_ahb a000000.wifi: Falling back to user helper
    [ 23.433395] firmware ath10k!QCA4019!hw1.0!ct-firmware-2.bin: firmware_loading_store: map pages failed
    [ 23.433781] ath10k_ahb a000000.wifi: Direct firmware load for ath10k/QCA4019/hw1.0/firmware-6.bin failed with error -2
    [ 23.441675] ath10k_ahb a000000.wifi: Falling back to user helper
    [ 23.491739] firmware ath10k!QCA4019!hw1.0!firmware-6.bin: firmware_loading_store: map pages failed
    [ 24.547447] ath10k_ahb a000000.wifi: qca4019 hw1.0 target 0x01000000 chip_id 0x003b00ff sub 0000:0000
    [ 24.547493] ath10k_ahb a000000.wifi: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
    [ 24.558880] ath10k_ahb a000000.wifi: firmware ver 10.4-ct-4019-fW-011-cf79c7f api 5 features mfp,peer-flow-ctrl,txstatus-noack,wmi-10.x-CT,ratemask-CT,regdump-CT,txrate-CT,flush-all-CT,pingpong-CT,ch-regs-CT,nop-CT,set-special-CT,cust-stats-CT crc32 3aa71cb7
    [ 24.648045] ath10k_ahb a000000.wifi: board_file api 2 bmi_id 0:16 crc32 bcebe54c
    [ 25.926326] ath10k_ahb a000000.wifi: 10.4 wmi init: vdevs: 16 peers: 48 tid: 96
    [ 25.926373] ath10k_ahb a000000.wifi: msdu-desc: 2500 skid: 32
    [ 25.961453] ath10k_ahb a000000.wifi: wmi print 'P 48/48 V 16 K 144 PH 176 T 186 msdu-desc: 2500 sw-crypt: 0'
    [ 25.962288] ath10k_ahb a000000.wifi: wmi print 'free: 65652 iram: 15164 sram: 43468'
    [ 26.070738] ath10k_ahb a000000.wifi: htt-ver 2.2 wmi-op 6 htt-op 4 cal pre-cal-file max-sta 32 raw 0 hwcrypto 1
    [ 26.372793] ath10k_ahb a800000.wifi: Direct firmware load for ath10k/fwcfg-ahb-a800000.wifi.txt failed with error -2
    [ 26.372850] ath10k_ahb a800000.wifi: Falling back to user helper
    [ 26.751353] firmware ath10k!fwcfg-ahb-a800000.wifi.txt: firmware_loading_store: map pages failed
    [ 26.767760] ath10k_ahb a800000.wifi: Direct firmware load for ath10k/QCA4019/hw1.0/ct-firmware-5.bin failed with error -2
    [ 26.767805] ath10k_ahb a800000.wifi: Falling back to user helper
    [ 26.829764] firmware ath10k!QCA4019!hw1.0!ct-firmware-5.bin: firmware_loading_store: map pages failed
    [ 26.830100] ath10k_ahb a800000.wifi: Direct firmware load for ath10k/QCA4019/hw1.0/ct-firmware-2.bin failed with error -2
    [ 26.838075] ath10k_ahb a800000.wifi: Falling back to user helper
    [ 26.913418] firmware ath10k!QCA4019!hw1.0!ct-firmware-2.bin: firmware_loading_store: map pages failed
    [ 26.913775] ath10k_ahb a800000.wifi: Direct firmware load for ath10k/QCA4019/hw1.0/firmware-6.bin failed with error -2
    [ 26.921763] ath10k_ahb a800000.wifi: Falling back to user helper
    [ 26.978674] firmware ath10k!QCA4019!hw1.0!firmware-6.bin: firmware_loading_store: map pages failed
    [ 26.978984] ath10k_ahb a800000.wifi: qca4019 hw1.0 target 0x01000000 chip_id 0x003b00ff sub 0000:0000
    [ 26.986682] ath10k_ahb a800000.wifi: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
    [ 27.000762] ath10k_ahb a800000.wifi: firmware ver 10.4-ct-4019-fW-011-cf79c7f api 5 features mfp,peer-flow-ctrl,txstatus-noack,wmi-10.x-CT,ratemask-CT,regdump-CT,txrate-CT,flush-all-CT,pingpong-CT,ch-regs-CT,nop-CT,set-special-CT,cust-stats-CT crc32 3aa71cb7
    [ 27.048160] ath10k_ahb a800000.wifi: board_file api 2 bmi_id 0:17 crc32 bcebe54c
    [ 28.327239] ath10k_ahb a800000.wifi: 10.4 wmi init: vdevs: 16 peers: 48 tid: 96
    [ 28.327282] ath10k_ahb a800000.wifi: msdu-desc: 2500 skid: 32
    [ 28.362595] ath10k_ahb a800000.wifi: wmi print 'P 48/48 V 16 K 144 PH 176 T 186 msdu-desc: 2500 sw-crypt: 0'
    [ 28.363561] ath10k_ahb a800000.wifi: wmi print 'free: 65652 iram: 15164 sram: 43468'
    [ 28.474063] ath10k_ahb a800000.wifi: htt-ver 2.2 wmi-op 6 htt-op 4 cal pre-cal-file max-sta 32 raw 0 hwcrypto 1
    [ 28.530576] kmodloader: done loading kernel modules from /etc/modules.d/*
    [ 31.832267] br-lan: port 1(eth0) entered blocking state
    [ 31.832306] br-lan: port 1(eth0) entered disabled state
    [ 31.836622] device eth0 entered promiscuous mode
    [ 31.844288] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
    [ 31.859721] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [ 32.881645] br-lan: port 1(eth0) entered blocking state
    [ 32.881687] br-lan: port 1(eth0) entered forwarding state
    [ 32.886069] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
    Próbowałem wejść po ssh na 192.168.1.1 , ale niestety odrzuca połączenie.
    ssh root(malpa)192.168.1.1
    ssh: connect to host 192.168.1.1 port 22: Connection refused
    Pytanie czy jest jakaś inna opcja, żeby wrzucić mu oryginalne oprogramowanie? Asus Firmware Restoration będzie działać, ale najpierw muszę wyczyścić bloki po OpenWRT. Ale aktualnie nie mogę tego zrobić bez zalogowania po SSH.
  • IT SerwisIT Serwis
  • Poziom 21  
    Problem rozwiązany.
    Zapomniałem w putty kliknąć enter, żeby móc pisać komendy :)
    Write
    ubirmvol /dev/ubi0 -N linux2
    and press enter to delete the volume.
    After this, write
    sysupgrade -F /bin/busybox
    and press enter. The router will now be in recovery/rescue mode.
    Run the restoration tool.
    Select the firmware we downloaded and click Upload. The file should start uploading immediately. If it doesn't upload, reboot the router and try again. Be patient, the restoration might take some time.
    The router should reboot and you should be back on the ASUS firmware.
