Jak przywrócić kodowanie ABS 8.2 w Skoda Roomster 2010/11 1.6Tdi?
RomanBoski 11 Paź 2019 15:06 2235 6
  • #1 18213496
    RomanBoski
    Poziom 7  
    Witam potrzebuje pomocy z długim kodowaniem. Skoda Roomster 2010/11 r 1.6Tdi wysypało się kodowanie ABS 8.2 .
    Vin: TMBNL25JXB5008736 Zamieszczam auto-scan w spojlerze
    Spoiler:
    Friday,11,October,2019,14:43:02:00007
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 18.9.0.2
    Data version: 20180927 DS296.0
    www.Ross-Tech.com
    VIN: TMB1JC5J5B7016323 License Plate:
    Mileage: 496790km-308690mi Repair Order:
    Chassis Type: 5J-SK25 (6N0)
    Scan: 01 03 08 09 10 15 17 19 25 44 56
    VIN: TMB1JC5J5B7016323 Mileage: 496790km-308690miles
    01-Engine -- Status: Malfunction 1010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 LK HW: 03L 906 023 LK
    Component: R4 1.6l TDI H33 9978
    Revision: --H33--- Serial number:
    Coding: 00114016000400080000
    Shop #: WSC 13765 031 00121
    ASAM Dataset: EV_ECM16TDI02103L906023LK 003011
    ROD: EV_ECM16TDI02103L906023LL.rod
    VCID: 7AFB44E9FDDF5E9A9B-802E
    1 Fault Found:
    7332 - Mass Air Flow Sensor (G70)
    P0103 00 [165] - Signal too High
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 496793 km
    Date: 2019.10.11
    Time: 00:19:08
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 9 °C
    Intake air temperature: 10 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 11.520 V
    Unlearning counter according OBD: 40
    Engine speed: 0 /min
    Vehicle speed: 255 km/h
    Battery voltage: 10.4 V
    EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
    Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
    Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
    Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 6R0 907 379 AG HW: 6R0 907 379 AB
    Component: ABS8.2 front H03 0001
    Revision: --------
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 35110 377 09999
    VCID: 0305390D86151F52C8-8056
    2 Faults Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 247
    Mileage: 496793 km
    Time Indication: 0
    Date: 2014.03.03
    Time: 06:05:38
    Freeze Frame:
    Hex Value: 0x0005
    Hex Value: 0x0000
    Hex Value: 0x1213
    Hex Value: 0x1490
    Hex Value: 0x00FF
    Hex Value: 0x007F
    Hex Value: 0x7F00
    Hex Value: 0x0000
    03306 - Coding Not Valid
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 31
    Mileage: 496793 km
    Time Indication: 0
    Date: 2014.03.03
    Time: 06:07:41
    Freeze Frame:
    Hex Value: 0x0001
    Hex Value: 0x0000
    Hex Value: 0x1227
    Hex Value: 0x148F
    Hex Value: 0x00FF
    Hex Value: 0x007F
    Hex Value: 0x7E00
    Hex Value: 0x0000
    Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
    Part No SW: 5J0 820 045 B HW: 5J0 820 045 B
    Component: Climatic 12 0660
    Revision: 0002S 12
    VCID: 24475A9127DBF86A91-8070
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 496793 km
    Time Indication: 0
    Date: 2014.03.03
    Time: 01:15:17
    Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
    Part No SW: 6R7 937 086 F HW: 6R7 937 086 B
    Component: PQ25 BCM H10 0017
    Revision: -3------ Serial number: 1002430401
    Coding: 64980B3808010000002000003E0B08C00000400F600000000000
    Shop #: WSC 33361 790 00085
    VCID: 4683E019F1A7EA7AAF-8012
    Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 002 3240
    Serial number: --------------------
    Coding: 020000
    Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
    Component: J387__TSG_BT 002 3240
    Coding: 020000
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
    Part No SW: 5J0 919 475 HW: 5J0 919 475
    Component: PARKHILFE 4K H10 0002
    Revision: --H10--- Serial number: 76241009101254
    Coding: 100003
    Shop #: WSC 73430 790 00085
    ASAM Dataset: EV_SK25XParkiAssis2 S01002
    ROD: EV_SK25XParkiAssis2.rod
    VCID: 72EB6CC9A5AF26DAD3-8026
    1 Fault Found:
    1458176 - Internal Control Module Memory Check Sum Error
    B2000 46 [008] - Calibration/parameter memory failure
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
    Component: VW10AirbagTA0 H09 0018
    Revision: -------- Serial number: 003DW00EN5JN
    Coding: 004130
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250.rod
    VCID: 428BFC09D58FD65A83-8016
    Crash sensor for side airbag: driver side:
    Serial number: 3496GRB4027DKEVR7RDQ
    Crash sensor for side airbag: front passenger side:
    Serial number: 3506GRB402JCU8L3AS8+
    1 Fault Found:
    9437211 - Igniter for Driver's Airbag
    B1000 1B [137] - Resistance Too High
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 496793 km
    Date: 2019.10.11
    Time: 00:19:12
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 5J0 920 840 D HW: 5J0 920 840 D
    Component: KOMBI H15 0206
    Serial number: 00000000000000
    Coding: 120A00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
    VCID: 2A5BB4A94DFF2E1AAB-807E
    1 Fault Found:
    12648448 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 496793 km
    Date: 2019.10.11
    Time: 01:15:16
    Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R7 937 086 B
    Component: GW-K-CAN TP20 0017
    Revision: -3------
    Coding: 832200
    VCID: 70EF66C1A3A314CA25-8024
    1 Fault Found:
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H15 0206
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
    ROD: EV_Immo_UDS_VDD_RM09.rod
    VCID: 6ADB74A98D7FEE1A6B-803E
    1 Fault Found:
    9456128 - Engine Control Module (ECM) not authorized
    B104A 00 [008] - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 496793 km
    Date: 2019.10.11
    Time: 01:17:47
    Address 44: Steering Assist Labels: 6Q0-423-156.clb
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 10110
    Shop #: WSC 33361
    VCID: 2F6DA5BDEA1D4B327C-807A
    2 Faults Found:
    49-10 - No Communications - Intermittent
    01317 - Control Module in Instrument Cluster (J285)
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 5J0 035 161 C HW: 5J0 035 161 C
    Component: Radio-SWING 008 0031
    Revision: -----05S Serial number: SKZ4Z2K1179527
    Coding: 0D0004000006
    VCID: 224B5C893DCFF65AE3-8076
    No fault code found.
    End-------------------------(Elapsed Time: 01:40)--------------------------
    [/syntax]
  • #3 18213509
    RomanBoski
    Poziom 7  
    Zmiana sterownika silnika gdyż padł.
    Auto odpala już aczkolwiek wysypał sie ABS niestety nie miałem wpływu na to..
  • #5 18213518
    RomanBoski
    Poziom 7  
    Mam aczkolwiek online chce...
