Mam do zakodowania ABS w moim Polo. Wymieniłem pompę ABS i teraz mam błąd nieprawidłowego kodowania.
Pomoże mi ktoś z przeliczeniem prawidłowego kodu?
Poniżej pełny AutoScan VCDS:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 37 44 56
VIN: WVWZZZ6RZAY030158
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYA) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 E HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 5360
Revision: -------- Serial number:
Coding: 00114014000400080000
Shop #: WSC 124697 483 00190
ASAM Dataset: EV_ECM16TDI02103L906023E 001007
ROD: EV_ECM16TDI02103L906023AH_VW25.rod
VCID: 285F1E2B5306C05EFC3-807D
1 Fault Found:
10156 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 00 [037] - Electrical Fault
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 196340 km
Date: 2107.14.23
Time: 18:14:59
Readiness: 1010 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 02069 000 00000
VCID: 4D918FBF1024C5762F5-8018
3 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 8
Reset counter: 99
Mileage: 196339 km
Time Indication: 0
Date: 2043.14.23
Time: 00:07:08
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x3213
Hex Value: 0x149B
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 8
Reset counter: 99
Mileage: 196339 km
Time Indication: 0
Date: 2043.14.23
Time: 00:07:08
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x3251
Hex Value: 0x1B9B
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
00493 - ESP-Sensor Unit (G419)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 99
Mileage: 196339 km
Time Indication: 0
Date: 2043.14.23
Time: 00:07:08
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x32E1
Hex Value: 0x1A9B
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 HW: 6R0 820 045
Component: Climatic 23 0500
Revision: 00 09 23
VCID: EBD5A1270A70AB46D11-80BE
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 11748 km
Time Indication: 0
Date: 2008.14.21
Time: 13:31:19
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag008 H09 0018
Revision: -------- Serial number: 003DW004KPY2
Coding: 003038
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 428BAC83D57A0A0EC27-8017
Crash sensor for side airbag; driver side:
Serial number: 3572SRB400008F5C624A
Crash sensor for side airbag; passenger side:
Serial number: 3582SRB400008F08F8ER
Crash sensor for side airbag; rear driver side:
Serial number: 3516GRB402H9GI4H5SS2
Crash sensor for side airbag; rear passenger side:
Serial number: 3526GRB402F9GI4GMRVJ
No fault code found.
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 A HW: 6R0 920 861 A
Component: KOMBI H23 0110
Serial number: 00000000000000
Coding: 140000
Shop #: WSC 12469 483 00190
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 3365F9479AC0B386591-8066
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 086 B
Component: GW-K-CAN TP20 0025
Coding: 002200
VCID: F0EFB64B2356489EE43-80A5
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H23 0110
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
Address 37: Navigation (J794) Labels: 3C0-035-270.clb
Part No SW: 3C0 035 270 HW: 3C0 035 270
Component: RNS310 H12 0212
Serial number: VWZ1Z2I8035939
Coding: 000004010200000000000000
ASAM Dataset: VW_RNS310 A02007
ROD: EV_VWRNS310UDS.rod
VCID: D7BDEDD7AEF83FA6059-8082
2 Faults Found:
1048634 - Antenna 2 for radio
B111A 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 179
Reset counter: 99
Mileage: 185752 km
Date: 2083.14.19
Time: 17:21:37
1048658 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 139
Mileage: 196339 km
Date: 2099.14.07
Time: 15:02:24
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10130
Shop #: WSC 00000
VCID: 2E53E833EDE29E6E36F-807B
End ---------------------------------------------------------------------
