Rozkodowanie VIN dla Peugeot 308 SW, nr VF34H9HZHAS082842
Driver- 26 Paź 2019 23:28 618 7
  • #1 18241536
    Driver-
    Proszę o rozkodowanie VIN Peugeot 308 Nr VF34H9HZHAS082842.
  • #2 18241771
    madamsz1
    Poziom 41  
    Nie wiem jak u kogoś innego, ale mi wychodzi błędny VIN
  • #3 18241822
    pepe150
    Poziom 36  
    Z pełnego VINu - nieznany pojazd.
    Z nr VIS (8 ostatnich cyfr) - 5008 (T87E) KOMBI REKREACYJNE 1.6 HDi 110 FAP (DV6TED4) BVMP 6
    Więc nie wiem czy to jest 308.
  • #4 18241851
    Driver-
    Zrobiłem literówkę w 2 cyfrach, poprawnie jest VF34H9HZHAS082482.
  • #5 18242005
    madamsz1
    Poziom 41  
    VIN VF34H9HZHAS082482
    Brand PEUGEOT
    Vehicle characteristics
    Parameter Value
    Vehicle family 308 (T7)
    AS/RP N° 12170 89 1 0426
    Warranty Start Date 02/08/2010
    Engine serial number 10 JBBN 3121835
    BER e2*2001/116*0362*20
    P4A 9663324399
    TRIM LEVEL MEDIUM HIGH
    PAINT TYPE METALLIC PAINTWORK
    BODY COLOUR KTV - BLACK PEARL PAINT
    INTERIOR TRIM TYPE KAWANA CLOTH + OMNI "TT"
    UPHOLSTERY COLOUR "FX"
    GEARBOX (CHARACTERISTICS) MCD MANUAL GEARBOX
    General information
    Parameter Value
    PRODUCT TYPE CAR
    COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
    VEHICLE FAMILY 308 (T7)
    SILHOUETTE ESTATE - LEISURE
    ENGINE DIESEL TURBO DV6TED4 FAP
    TRANSMISSION BVM6
    DEFINITION TO FOLLOW OLD RANGE
    ENGINE (TYPE) DV TYPE ENGINE
    OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
    Fuel supply-Engine
    Parameter Value
    FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
    DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
    FUEL DIESEL GRADE DA/DE/DE+
    EMISSIONS STANDARD (ENGINE) EURO 4 ENGINE EMISSION CONTROL
    EXHAUST STANDARD EXHAUST
    CAPACITY 1600 CM3
    CATALYTIC CONVERTER CATALYTIC CONVERTER LESS THAN 10PPM
    COOLING MOTOR RADIATOR THICKNESS: 27 - 21 DM2 BRAZED ALUMINIUM
    CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
    POWER VARIATION (ENGINE) POWER 80 KW 240 NM
    EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
    DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
    VEHICLE TECHNICAL DEPOLLUTION L5 VEHICLE TECHNICAL DEPOLLUTION
    PARTICLE FILTER WITH PARTICLE EMISSION FILTER
    FAN 1 AERO 2-SPEED 140W FAN WITHOUT SCOOP
    FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
    INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
    TANK FILTER RESERVOIR FILTER INTERIOR
    STOP AND START WITHOUT STOP AND START
    Gearbox Transmission
    Parameter Value
    TRANSMISSION BVM6
    FINAL DRIVE RATIO CP 19 X 74
    WHEEL STYLE 16-INCH SANTIAGUITO WHEEL
    CLUTCH HYDRAULIC CLUTCH
    DIFFERENTIAL (GEARBOX) DIFFERENTIAL 86
    RIM/TYRE SIZE 16 INCH TYRE FITMENT
    TYRE (SIZE, TYPE) TYRE 205/55 R16 91V NON REINFORCED
    WHEELS FITTED 7" RIM ROAD WHEELS
    WHEEL (TYPE) ALLOY WHEELS
    INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR
    GEARBOX TYPE MC MANUAL GEARBOX
    Suspension-Steering-Brakes
    Parameter Value
    ABS WITH ABS BRAKES
    REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 29
    FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAMETER 22.5
    BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
    SUSPENSION NORMAL SUSPENSION
    DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
    BRAKE ASSOCIATED VARIANT 8 1 BOSCH ESP
    PEDAL BRACKET (TYPE) PEDAL STANDARD
    Body fittings
    Parameter Value
    TOWBAR TOWBAR
    HORNS HORN STANDARD
    AERIAL SHORT ROOF AERIAL
    REAR SPOILER ASSEMBLY WITHOUT REAR SPOILER
    SIDE MOULDINGS (TYPE) BODY COLOUR LATERAL PROTECTORS
    SIDE MOULDINGS (DIMENSION) STANDARD LATERAL PROTECTORS
    WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL CAP
    REVERSING LAMPS WITH 1 REVERSING LAMP
    SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
    ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
    EXT. REARVIEW MIRROR COMP. FUNCTION EXT MIRROR MANUAL-FOLD BACK
    SPLASH SHIELD STANDARD MUD GUARD
    EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
    ENGINE BAY SOUNDPROOFING SOUNDPROOFING UNDER BONNET + BULKHEAD + LOWER
    WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
    REAR SCREEN WIPER REAR SCREEN WIPER
    HEADLAMP WIPER W/O HEADLAMP WIPER
    REAR SCREEN WIPER (OPERATION) AUTO INTERMITTENT RR WIPER IN REVERSE GEAR
    FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
    ROOF GLASS WITH ROOF WINDOW
    REAR TAILGATE GLASS OPENING TAILGATE WINDOW
    BUMPER FR BUMPER STBC GRIL PT ALU+AR STBC
    MUDFLAP WITHOUT REAR MUDGUARD
    NUMBER PLATE WITHOUT LICENCE PLATE
    FRONT FOGLAMP FRONT FOG LIGHTS
    EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) DRIVER’S DOOR MIRROR ELECTRIC CONTROL
    EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
    SPARE WHEEL EMERGENCY WHEEL
    EXTERIOR ACCESSORIES EXT HANDLE + MIRROR BASE + MIRROR CC
    EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CONVEX EXTERIOR MIRROR GLASS
    SUN ROOF FIXED ROOF
    BUMPER TRIM BODY COLOUR BUMPER STRIP
    GLASS (APPEARANCE) TINTED + OVER-TINTED
    REAR QUARTER WINDOW (TYPE) FIXED REAR QTR GLASS
    WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
    Interior fittings
    Parameter Value
    ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
    REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
    REAR SEAT 3 SEPARATED REAR SEATS (1 SLIDING)
    SUPPLEMENTARY SEAT WITHOUT SUPPLEMENTARY SEAT POSITN
    REAR SEAT ARMREST WITHOUT REAR ARMREST
    LUGGAGE COVER SCREEN
    REAR SEATBELT RR SEAT BELT 5 INERT REELS 3 PTS + FASTEN WARN LGH
    FRONT SEATBELT PYROTECHNIC SEAT BELT WITH ALARM
    CLIMATE (AMBIENT TEMP) COLD COUNTRIES
    CHILD LOCK ELECTRIC REAR CHILD LOCK
    SPEED GRADUATIONS GRADUATION KMS/H
    CONSOLE LONG CONSOLE
    DRIVING POSITION LEFT-HAND DRIVE
    ADDITIONAL HEATING AUTOMATIC ADDITIONAL HEATING
    BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT AND LOAD VOL SWITCH
    DASHBOARD EQUIPMENT FASCIA PANEL BASE BLACK U WARM SILVER
    MISC. INT. LAMPS REAR MAP READING LIGHT + SPOTLIGHT
    WORK TABLE WITHOUT WORK TABLE
    UNDERSEAT STORAGE WITHOUT UNDER SEAT STORAGE
    INSTRUMENT PANEL (CHARACTERISTICS) 230 KM/H 140 MPH GRAD BLACK BACKGND CHROME CIRCLE
    LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
    RADIO CONTROLS REMOTE RADIO CONTROL
    PASSENGER COMPARTMENT SOUNDPROOFING BULKHEAD SOUNDPROOFING 13 KG
    FRONT PASSENGER SEAT HEIGHT CONTROL FRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT
    DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
    FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
    DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK
    FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
    DRIVER’S SEAT FOLDING W/O FOLDING DRIV FRONT SEATING
    FRONT PASSENGER SEAT FOLDING W/O FOLDING PASS FRONT SEATING
    FRONT SEAT ARMREST FRONT SEAT CENTRAL ARMREST
    EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
    COMPACT DISC WITHOUT COMPACT DISC
    SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
    HEADLAMP BULBS HALOGEN BULB
    REAR WINDOW LIFT SEQUENTIAL ELECTRIC REAR WINDOW + LOCKING
    TRAFFIC INFORMATION READER WITHOUT LATERAL TRAJECTORY MONITORING
    DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
    PASSENGER’S WINDOW LIFT SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
    DISPLAY MONOCHROME SCREEN LEVEL C DISPLAY
    MISC. INT. ACCESSORY WITHOUT WINDSTOP
    COURTESY MIRROR DRIV OCCULT+PASS OCCULT W/O LIGHT
    FOOTREST DRIVER’S FOOTREST
    CUSHION PADDING STANDARD FRONT SEAT CUSHION PADDING
    OIL GAUGE STD OIL LEVEL INDICATOR
    HEATING ELEMENT NON HEATED SEAT
    FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
    FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
    PASSENGER AIRBAG PASSENGER AIRBAG
    EQUIPMENT PACK W/O EQUIPMENT PACK
    EXTERIOR REAR VIEW MIRROR (HEATED) HEATED DOOR MIRROR
    AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
    INTERIOR DOOR CONTROL (APPEARANCE) CHROME EFFECT DOOR HANDLE + COLOURED TRIM
    HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
    DIRECTIONAL HEADLAMP WITHOUT DIRECTIONAL LIGHTS
    FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
    FRONT SUN VISOR DRIVER’S+PASSENGER’S SIDE WITHOUT INSCRIPTION
    STORAGE (DRIVING POSITION) GLASSES CASE
    RADIO RECEIVER "RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM
    REFRIGERATION SINGLE AIR CONDITIONING
    CRUISE CONTROL REGULATOR AND SPEED LIMIT
    INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
    DRIVER AIRBAG DRIVERS AIR BAG
    LOAD SPACE STORAGE W/O BOOT TIDY
    TUNER RADIO MONO RADIO TUNER
    OBSTACLE DETECTION SYSTEM REAR RADAR OBSTACLE SENSOR
    LATERAL BLINDS WITHOUT SIDE BLINDS
    TRIM ADAPTATION GEAR LEVER KNOB PLASTIC+CHROME INSERT
    FLOOR MAT W/O CARPETMAT
    EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
    RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
    LOCKING CONTROL SIMPLE + AUTOMATIC CENTRAL LOCKING
    STEERING WHEEL LEATHER STEERING WHEEL 3 BRANCHES
    DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG
    AUDIO PACK AUXILIARY SOCKET WITHOUT AUDIO PACK AUXILIARY SOCKET
    TELEMATIC UNIT WITHOUT TELEMATIC UNIT
    Electrical
    Parameter Value
    ALTERNATOR ALTERNATOR 150 AMP
    HORNS HORN STANDARD
    BATTERY BATTERY L3 450
    STARTER MOTOR CLASS 6 STARTER MOTOR
    SPECIAL LIGHTING FRONT DAYTIME LIGHTS
    BATTERY CHARGE MEASUREMENT WITHOUT BATTERY CHARGE MEASUREMENT
    LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF LIGHTS
    Component manufacturers
    Parameter Value
    Miscellaneous
    Parameter Value
    SPECIAL SPECIFICATION STANDARD
    ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
    SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
    SET OF KEYS 1 HIGH FREQUENCY REMOTE CONTROL KEY+1 MAIN KEY ONLY
    EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
    SLAVE CONTROL UNIT BSI COMM 2003
  • #6 18242063
    Driver-
    Stała się jasność :D Wielkie dzięki, pozdrawiam.
  • #7 18242135
    pepe150
    Poziom 36  
    Czytać się nie da...
    308 (T7) KOMBI REKREACYJNE 1.6 HDi 110 FAP (DV6TED4) BVM 6
    Spoiler:
    Charakterystyki pojazdu
    Model 308 (T7)
    Nr APV/PR (obsługa posprzedażna/część zamienna) 12170 89 1 0426
    Data Początku Gwarancji 02.08.2010
    Numer seryjny silnika 10 JBBN 3121835
    NRE(homologacja) e2*2001/116*0362*20
    P4A 9663324399
    Informacje ogólne
    RODZAJ PRODUKTU POJAZD SPECJALNY
    ZNAK HANDLOWY/TYP ELEMENTU PEUGEOT
    LINIA PRODUKTU 308 (T7)
    TYP NADWOZIA KOMBI REKREACYJNE
    WYKOŃCZENIE ŚREDNIE WYSOKIE
    SILNIK DIESEL TURBO DV6TED4 FAP
    PRZENIESIENIE NAPĘDU SKRZYNIA MECHA 6
    RODZAJ FARBY LAKIER METALICZNY DWUWARSTWOWY
    KOLOR NADWOZIA KTV - LAKIER CZARNY PERLA NERA
    TYP TAPICERKI WEWNĘTRZNEJ TKANINA KAWANA + OMNI "TT"
    KOLOR OKŁADSZIN "FX"
    SKRZYNIA BIEGÓW (CHARAKTERYSTYKA) RĘCZNA SK BIEGÓW MCD
    DEFINICJA DO USTALENIA STARA GAMA
    SILNIK (TYP) SILNIK TYPU DV
    MONOGRAM DODATKOWY, INNE BEZ MONOGRAMU DODATKOWEGO
    Charakterystyka pojazdu
    Zasilanie silnika
    ZASILANIE WTRYSK TURBO WYMIENNIK BEZPOŚR
    CZUJNIK WODY FILTRA PALIWA BEZ CZUJNIKA OBECNOŚCI WODY W OLEJU NAP
    PALIWO ON KLASA JAKOŚCIOWA DA/DE/DE+
    USUWANIE ZANIECZYSZCZEŃ (SILNIK) NORMA CZYSTOŚCI SPALIN SILNIKA EURO 4
    UKŁAD WYDECHOWY UKŁAD WYDECHOWY STANDARDOWY
    POJEMNOŚĆ SKOKOWA 1600 CM3
    KATALIZATOR KATALIZATOR PON 10PPM
    SILNIK (CHŁODZENIE) CHŁODNICA GRUBOŚĆ: 27 - 21 DM2 ALU SPAW
    PODGRZANIE OBIEGU GAZU OBUDOWY BEZ PODGRZEWANIA OBIEGU GAZU
    WAHANIA MOCY (SILNIK) MOC 80 KW 240 NM
    AUTODIAGNOSTYKA EOBD AUTODIAGNOST. "EOBD" BEZ PRZYSPIESZOMIERZA
    SYSTEM ANTYZANIECZYSZCZENIOWY RECYRKULACJA SPALIN "EGR"
    TECHNIKA USUWANIA ZANIECZYSZCZEŃ POJAZDU TECHN. OCZYSZ SPALIN POJAZD EURO 4
    FILTR CZĄSTEK (FAP) Z FILTREM CZĄSTEK STAŁYCH
    WENTYLATOR 1 WENTYLATOR 2 PRĘDKOŚCI 140W NAGRZ. BEZ CZERPN.
    ODZYSK OPARÓW BENZYNY BEZ POCHŁANIACZA OPARÓW PALIWA
    WARIANT SKOJARZONY WTRYSK SYSTEM WTRYSKU BOSCH
    FILTR ZBIORNIKA FILTR ZBIORN. WEWN.
    STOP AND START BEZ STOP AND START
    Skrzynia biegów, Napęd
    PRZEKŁADNIA PRZEŁOŻENIE CP 19 X 74
    KOŁO STYLIZOWANE KOŁO SANTIAGUITO 16-CALOWE
    SPRZĘGŁO SPRZĘGŁO HYDRAULICZNE
    UKŁAD RÓŻNICOWY (OBUDOWA) MECH. RÓŻNIC. 86
    FELGA/OPONA/ WYMIARY ZAŁOŻONA OPONA 16-CAL.
    OGUMIENIE (WYMIARY, TYP) OPONA 205/55 R16 91V NIE WZMACNIANA
    KOŁA ZAMONTOWANE KOŁO 7 CALI
    KOŁO (TYP) MONTAŻ KOŁA ZE STOP LEK
    WSKAŹNIK SPADKU CIŚNIENIA W OGUMIENIU BEZ WSKAŹNIKA CIŚNIENIA OPON
    SKRZYNIA BIEGÓW (TYP) RĘCZNA SK BIEGÓW MC
    Zawieszenie, Układ kierowniczy, Hamulce
    ABS ABS
    STABILIZATOR POPRZECZNY TYLNY TYLNY DRĄŻEK STABILIZATORA O ŚREDNICY 29
    STABILIZATOR PRZEDNI DRĄŻEK STAB. PRZEDNI O ŚREDN. 22,5
    HAMULEC TYP TARCZE PRZED WENTYLOWANE/TARCZE TYL
    ZAWIESZENIE ZAW NORMALNE
    DYNAMICZNA KONTROLA STABILNOŚCI Z SYSTEMEM ESP
    WARIANT SKOJARZONY HAMULCE ESP BOSCH 8 1
    PODSTAWA PEDAŁU (TYP) ZESP.PEDAŁÓW STAND.
    Nadwozie, Wyposażenie
    HAK HOLOWNICZY ZACZEP HOLOW
    SYGNAŁ DŹWIĘKOWY KLAKSON STANDARDOWY
    ANTENA ANTENA W DACHU KRÓTKA
    TYLNY SPOJLER MONTAŻ BEZ OWIEWKI TYL
    ZDOBIENIA BOCZNE (WYGLĄD) LISTWY OCHRONNE BOCZNE W KOL NADW
    ZDOBIENIA BOCZNE (WYMIARY) LISTWY OCHRONNE BOCZNE
    KOŁPAK (STYL) BEZ KOŁPAKA OZDOBNEGO KOŁA
    ŚWIATŁA COFANIA Z 1 ŚWIATŁEM COFANIA
    ŚWIATŁO OŚWIETLENIA PROGU BEZ ŚWIATŁA OŚWIET PROGU
    OSŁONA DODATKOWA (POD SILNIKIEM) BEZ DODATKOWEJ DOLNEJ OSŁONY SILNIKA
    FUNKCJA DODATKOWA LUSTERKA WSTECZNEGO ZEW. LUSTERKO ZEWN SKŁADANE RĘCZNIE
    OSŁONA PRZECIWBŁOTNA OSŁ PRZECIWBŁ STANDARD
    OZDOBNA KOŃCÓWKA RURY WYDECHOWEJ BEZ WYKOŃCZ OZDOB RURY WYDECH
    WYCISZENIE OD STRONY SILNIKA WYGŁUSZ POD POKR SLN + PRZEGR CZOŁ + DLN
    WYCIERACZKA PRZEDNIA WYCIERACZKA PRZED Z CZUJNIKIEM OPADÓW
    WYCIERACZKA TYLNA WYCIERACZKA TYL
    WYCIERACZKA REFLEKTORA BEZ WYCIERACZEK REFLEKTORÓW
    WYCIERACZKA TYLNA (DZIAŁANIE) WYCIER SZYBY TYLNEJ PRZERYW AUTOMAT NA WST BIEGU
    PRZEPUSTNICA PRZEDNIEGO PASA BEZ ZAŚLEPKI W PASIE PRZEDNIM
    SZYBA DACHU Z SZYBERDACHEM
    SZYBA DRZWI BAGAŻNIKA PRZESZKLONE TLN. DRZWI OTWIERANE
    ZDERZAKI ZD PRZ ZAĆ KOL NADW KRAT PT ALU+TLN ZAĆ KOL NADW
    OSŁONA PRZECIWBŁOTNA (CHLAPACZ) BEZ CHLAPACZY TYL
    TABLICA REJESTRACYJNA BEZ TABLICY REJESTRACYJNEJ
    REFLEKTOR PRZECIWMGIELNY REFLEKTORY PRZECIWMGIELNE
    LUSTERKO ZEWNĘTRZNE KIEROWCY LUSTERKO ZEWN KIER STER ELE
    LUSTERKO ZEWNĘTRZNE PASAŻERA LUST. WSTECZ. ZEWN. PASAŻERA STER. ELEKTR.
    KOŁO ZAPASOWE KOŁO GALETTE
    OSPRZĘT ZEWNĘTRZNY KLAMK ZEW + PODST LUST WST + LUST WST KOL NADW
    LUSTERKO ZEWNĘTRZNE (PROMIEŃ OD STR. KIEROWCY) SZKŁO LUST. WSTECZ. ZEWN. WYPUKŁE
    DACH OTWIERANY DACH SZTYWNY
    MASKOWNICE ZDERZAKÓW PAS OCHR ZDERZAKA W KOLORZE NADWOZIA
    SZYBA (WYGLĄD) PRZYCIEMNIONA + INTENSYWNIE PRZYCIEMNIO
    SZYBA TYLNEGO BOCZNEGO OKNA (RODZAJ) SZYBA BOCZ TYL STAŁA
    SZYBA (TYP) PRZ SZYBA WARSTWOWA AKUST + TLN HARTOWANA
    Wyposażenie wnętrza
    ALARM ANTYWŁAMANIOWY BEZ ALARMU ANTYKRADZIEŻOWEGO
    ZAGŁÓWEK TYLNY ZAGŁÓWEK TYLNY REGULOWANY
    SIEDZENIE TYLNE 3 ODDZIELNE FOTELE TYLNE (1 PRZESUWANY)
    SIEDZENIE DODATKOWE BEZ DODATK KANAPY
    PODŁOKIETNIK SIEDZENIA TYLNEGO BEZ TYLNEGO PODŁOKIETNIKA
    ZASŁONA BAGAŻNIKA LINKA PRZYTRZYMUJĄCY
    PAS BEZPIECZEŃSTWA TYLNY PAS BEZP TLN 5 NAWIJACZY 3 DRZ + KONTR NIEZ PAS
    PAS BEZPIECZEŃSTWA PRZEDNI PAS PIROTECHNICZNY Z ALARMEM
    KLIMAT (TEMP. ZEWNĘTRZNA) KRAJE O ZIMNYM KLIMACIE
    BLOKADA OTWARCIA DRZWI PRZEZ DZIECI BLOKADA PRZEW. DZIECI ELEKTRYCZNA TLN.
    STOPNIOWANIE BIEGÓW PODZIAŁKA W KM/H
    KONSOLA KONSOLA DŁUGA
    STRONA KIEROWNICY (STANOWISKO KIEROWCY) KIEROWNICA PO LEWEJ
    OGRZEWANIE DODATKOWE OGRZEWANIE DODATKOWE AUTOMATYCZNE
    OŚWIETLENIE BAGAŻNIK POJEMNOŚĆ ŁADOWANIE STER OŚWIET AUTO BAGAŻ I PRZESTRZ BAGAŻ
    WYPOSAŻENIE TABLICY ROZDZIELCZEJ DESKA ROZDZ PODSTAWA CZARN U WARM SILVER
    ŚWIATŁA WEW. RÓŻNE LAMP. CZYT. MAP + TYLNA LAMPA PUNKT.
    STOLIK ROBOCZY BEZ PÓŁKI ROBOCZEJ
    SZUFLADA POD FOTELEM BEZ SCHOWKA POD FOTEL
    TABLICA ROZDZIELCZA (CHARAKTERYSTYKA) PODZIAŁKA 230 KM/H 140 M/H TŁO CZARNE CHROM WYKOŃC
    GŁOŚNIK 4 GŁOŚ PRZED (2 TW + 2 PRZED) + 2 GŁ TYL
    STEROWANIE AUTORADIA ZDALNE STEROWANIE RADIOODTWARZACZEM
    WYGŁUSZENIE WNĘTRZA NADWOZIA WYGŁ PRZEGR CZOŁ 13 KG
    NADSTAWKA SIEDZENIA PRZEDNIEGO PASAŻERA PODWYŻSZ SIEDZISKA PRZÓD PASAŻERA REGULACJA RÓWNOLEGŁA
    STEROWANIE SIEDZENIA PRZEDNIEGO KIEROWCY STER RĘCZNE FOTELEM PRZED KIEROWCY
    STEROWANIE SIEDZISKA PRZEDNIEGO PASAŻERA STER RĘCZNE FOTELEM PRZED PASAŻERA
    REGULACJA SIEDZISKA PRZEDNIEGO KIEROWCY OPARCIE KIEROWCY ODCHYLANE
    REGULACJA SIEDZISKA PRZEDNIEGO PASAŻERA OPARCIE PASAŻERA ODCHYLANE
    WYWINIECIE SIEDZENIA PRZEDNIEGO KIEROWCY BEZ SKŁADANEGO FOTELA KIER
    WYWINIECIE SIEDZENIA PRZEDNIEGO PASAŻERA BEZ SKŁADANEGO FOTELA PRZED PAS
    PODŁOKIETNIK SIEDZISKA PRZEDNIEGO PODŁOKIETN. ŚRODK. SIEDZ. PRZ.
    WSKAŹNIK TEMPERATURY ZEWNĘTRZNEJ WSKAŹNIK TEMPERATURY ZEWNĘTRZNEJ
    ODTWARZACZ PŁYT KOMPAKTOWYCH BEZ INSTALACJI DO MONT ODTWARZACZA CD
    SYSTEM NAWIGACJI BEZ SYSTEMU NAWIGACJI
    ŻARÓWKI REFLEKTORÓW ŻARÓWKA HALOGENOWA
    PODNOŚNIK SZYBY TYLNEJ PODN. SZYB. TLN. ELEKT. STER. SEKWENC. + RYGLOW.
    CZYTNIK INFORMACJI DROGOWYCH BEZ NADZORU BOCZNYCH ODCHYLEŃ TORU JAZDY
    PODNOŚNIK SZYBY PRZEDNIEJ KIEROWCY PODNOŚ SZYBY PRZED KIER STER SEKWENC
    PODNOŚNIK SZYBY PRZEDNIEJ PASAŻERA PODNOŚ SZYBY PRZED PASAŻ STER SEKWENC
    WYŚWIETLACZ WYŚWIETLACZ POZIOM C EKRAN CZARNO-BIAŁY
    OSPRZĘT WEWNĘTRZNY RÓŻNY BEZ SIATKI WINDSCHOT
    LUSTERKO PODRĘCZNE PASAŻERA LUSTERKO KIER+PASAŻ Z OSŁONĄ BEZ OŚWIET
    PODNÓŻEK PODNÓŻEK KIER.
    WYPEŁNIENIE PODUSZKI WYPEŁNIENIE PRZEDNIEGO SIEDZENIA STANDARD
    WSKAŹNIK OLEJU CZUJNIK POZIOMU OLEJU
    MATA GRZEJNA FOTEL BEZ PODGRZEWANIA
    PODUSZKA POWIETRZNA BOCZNA PRZEDNIA PODUSZKA POW BOCZNA TUŁOWIA + KURTYNA
    OŚWIETLENIE DOLNE WNĘTRZA NADWOZIA BEZ OŚWIETL. DLN. KABINY
    PODUSZKA POWIETRZNA PASAŻERA PODUSZKA POW PASAŻERA
    PAKIET WYPOSAŻENIA BEZ ZESTAWU WYPOSAŻENIA DODATKOWEGO
    LUSTERKO WSTECZNE ZEW. (PODGRZEWANE) LUSTERKO ZEWN OGRZEWANE
    BLOKADA PODUSZKI POWIETRZNEJ RĘCZNE WYŁĄCZENIE PODUSZKI POWIETRZNEJ
    WEWNĘTRZNE ELEMENTY STEROWANIA DRZWI (WYGLĄD) CHR KLAMKA DRZWI + POMALOWANA MASKOWNICA
    REFLEKTOR, KOREKTOR POCHYLENIA ZDALNA REGULACJA MECHANICZNA REFLEKTORÓW
    REFLEKTOR KIERUNKOWY BEZ REFLEKTOR. KIERUNKOW.
    ZABEZPIECZENIE MIEJSC PRZEDNICH BEZ OSŁONY PRZEDNIEGO STANOWISKA
    OSŁONA P-SŁONECZNA PRZEDNIA STRONA KIEROWCY+PASAŻERA BEZ NAPISU
    SZUFLADA (STANOWISKO KIEROWCY) SCHOWEK NA OKULARY
    ODBIORNIK RADIOWY SYST. AUDIO ODTW. CD RDS "RD4/MP3"
    CHŁODZENIE KLIMATYZACJI CHŁODZENIE ZWYKŁE
    REGULATOR SZYBKOŚCI TEMPOMAT I OGRANICZNIK PRĘDKOŚCI
    WEWNĘTRZNE LUSTERKO WSTECZNE LUSTERKO WEWN DZIEŃ-NOC
    PODUSZKA POWIETRZNA KIEROWCY PODUSZKA POW KIEROWCY
    SCHOWEK, PRZESTRZEŃ ŁADUNKOWA BEZ SIATKI W BAGAŻNIKU
    TUNER RADIOWY MONO TUNER RADIO
    WYKRYWANIE PRZESZKODY RADAR.CZUJN.PRZESZKODY TLN.
    ZASŁONY BOCZNE BEZ ŻALUZJI BOCZNYCH
    DOSTOSOWANIE WYKŁADZINY GAŁKA DŹWIGNI BIEG PLASTYK+PŁYTKA CHROM
    DYWANIK NA WYKŁADZINIE BEZ WYKŁADZINY WYKAŃCZAJĄCEJ
    WZMACNIACZ KOREKTORA BEZ AMPLITUNERA
    CZĘSTOTLIWOŚĆ RADIOWA CZĘSTOTL. RADIOWA EUROPA ZACHODNIA
    STEROWANIE RYGLOWANIEM ZAMEK ZWYKŁA BLOKADA + AUTOMATYCZNA
    KIEROWNICA KIER SKÓRA 3 RAMIONA
    PODUSZKA POWIETRZNA KOLAN KIEROWCY BEZ PODUSZKI POW NÓG KIEROWCY
    DODATKOWE ZŁĄCZE ZESTAWU AUDIO BEZ DODATK. GNIAZDA ZEST. AUDIO
    MODUŁ TELEMATYKI BEZ MODUŁU TELEMATYCZNEGO
    Elektryka
    ALTERNATOR ALTERNATOR KLASA 15
    AKUMULATOR AKUMULATOR L3 450
    ROZRUSZNIK ROZRUSZNIK KLASA 6
    OŚWIETLENIE SPECJALNE ŚWIATŁA DZIENNE PRZ
    POMIAR NAŁADOWANIA AKUMULATORA BEZ POMIARU NAŁADOWANIA AKUMULATORA
    WŁĄCZANIE ŚWIATEŁ AUTOMATYCZNE WŁĄCZANIE ŚWIATEŁ
    Marki wyposażenia
    Inne
    KRYTERIUM ZMIENNOŚCI, KLIENCI, KONCEPCJA STANDARD
    ATMOSFERA ATMOSFERA NORMALNA
    ZDERZENIA BOCZNE DRZWI NIE WZMOCNIONE
    ZESTAWY KLUCZY 1 KLUCZ PILOT WYS CZĘSTOTLIWOŚCI+1 KLUCZ PODSTAWOWY POJEDYNCZY
    WYPOSAŻENIE BEZPIECZEŃSTWA BEZ WYPOSAŻENIA BEZPIECZEŃSTWA
    MODUŁ ZARZĄDZAJĄCY BSI COMM 2003
  • #8 18242159
    Driver-
    Stała się pełna jasność :D Wielkie dzięki, pozdrawiam.
