Temat opanowany.
"Close OP1 and you have 25615-30105 AM/FM with 4 watts Power
Hold the PTT, DN Button and the RF Gain while turn on the radio you get PL, press the UP on the mike till PH is on screen and then turn off. When turn on again the H is on the display of the radio - w moim przypadku moc około 12W.
0 and 5 ending press and hold RFGAIN and P is on screen, this is 0 ending. Press and hold RF GAIN again and E is on screen so band to 5 ending channels
CLOSE OP2 and 10m mode is enabled, the power modification is the same as with the 11m mode.
You loose all EU norms menu in EXPORT MODE so no ending .125 in UK mode. Band DE will be the mid band for use.
DOWNLOAD CRT One, the modification is the same and can be found in the Modifications menu on the front page.
As i get increasingly asked about the Anytone Smart and the bands that it covers i have decided to put here on the blog 3 photos which will show the users, mostly who come from the USA and Chile what they can achieve via the jumpers so hope this small piece will help them.
- Smart 10m Mode (OP1 closed + OP2 closed)
Both the OP1 and OP2 are closed so this is 10m (28000-29700)
- Anytone Smart 10/11 Mode (25615-30105) (OP1 closed + OP2 open)
Release the solder from OP2 and just leave OP1 closed
- Multi Norm CB Radio Use (OP1 open + OP2 open)
Open the OP1 and the OP2 and you will have the same bands as the EU version of the Smart which is called the Albrecht AE-6110"
To change Band, turn on pressing A/F, and then select the band you want (AE-BE-CE-DE-EE-EF-GE-HE-IE-LE)
W radiu są dwie pr-ki koło siebie, do zwiększenia mocy nadajnika i wzmocnienia modulacji. Nie ruszałem ich, bo nie mam takiej potrzeby.
