EFM8 Sleepy Bee Starter Kit slstk2010A – 50pln
Manufacturer: Silicon Laboratories
Product Category: Development Boards & Kits - 8051
Core: CIP-51
Tool Is For Evaluation Of: EFM8SB10
Interface Type: I2C, SMBus, SPI, UART
Data Bus Width: 8 bit
Maximum Operating Temperature: + 85 C
Minimum Operating Temperature: - 40 C
Operating Supply Voltage: 2.4 V
EFM8 Universal Bee Starter Kit slstk2000A - 70pln
Core: CIP-51
Tool Is For Evaluation Of: EFM8UB10
EFM8UB2 Universal Bee Starter Kit slstk2001A - 70pln
Core: CIP-51
Tool Is For Evaluation Of: EFM8UB20
Operating Supply Voltage: 3.3 V
EFM32 Leopard Gecko Starter Kit – 120pln
Product Category: Development Boards & Kits - ARM
RoHS: Details
Tool Is For Evaluation Of: EFM32LG990F256
Interface Type: USB
EFM32-G8xx-STK EFM32 Gecko Starter Kit – 130pln
Core: ARM Cortex M3
Tool Is For Evaluation Of: EFM32G
Interface Type: JTAG
Data Bus Width: 32 bit
Operating Supply Voltage: 5 V
EFM32 Happy Gecko Starter Kit stk3400A – 150pln
Core: ARM Cortex M0+
Tool Is For Evaluation Of: EFM32HG
Interface Type: USB
Operating Supply Voltage: 3.3 V, 5 V
EFM32 Wonder Gecko Starter Kit slstk3800A – 150pln
Core: ARM Cortex M4
Tool Is For Evaluation Of: EFM32WG
Interface Type: I2C, UART, USB
Operating Supply Voltage: 1.85 V to 3.8 V
EFM32ZG-STK3200 – 170pln
Core: ARM Cortex M0
Tool Is For Evaluation Of: EFM32ZG
Interface Type: I2C, I2S, USART
Operating Supply Voltage: 3.8 V
CY8CKIT-050ARM Cortex M3Development Kits – 160pln
Manufacturer: Cypress Semiconductor
Core: ARM Cortex M3
Tool Is For Evaluation Of: PSoC 5LP
Interface Type: RS-232, USB
Operating Supply Voltage: 9 V, 12 V
CY8CKIT-031 CapSense Expansion Module – 80pln
Product Category: Daughter Cards & OEM Boards
Interface Type: I2C
Product Type: Daughter Cards & OEM Boards
SLSTK3201A Zero Gecko Starter Kit-170pln
Si7013 Humidity and Temperature sensor
Si1147 proximity sensor
3 IR LEDs for gesture detection
20-pin expansion header
Battery operation with long battery life
Core: ARM Cortex M0
GR-SAKURAII-FULL, RX63N, Wakamatsu Tsusho Co Ltd -100pln
32-bitowy mikrokontroler 96MHz RX63N z 1 MB pamięci Flash, 256 KB pamięci RAM, 32 KB pamięci Flash
Aparat RX63N jest wyposażony w zmiennoprzecinkowe jednostki matematyczne i instrukcje DSP
55 styków GPIO
6 styków wejść analogowych
Zakresy pokrycia hedera modułu bezprzewodowego XBEE
Złącze Mini-B USB-host
Gniazdo karty microSD
Przycisk resetowania
Przycisk użytkownika
4 diody LED użytkownika
Zasilanie z USB lub złącza BĘBENKA
Ślad dla 14-pinowego nagłówka programu JTAG/debugowania
Ekranowane zespoły żniwne (GR-SAKURAII-FULL)
Złącze RJ-45 Ethernet LAN (GR-SAKURAII-FULL)
Złącze cylindra zasilania +5VDC (GR-SAKURAII-FULL)
nRF52840 PREVIEW DEVELOPMENT KIT -120 pln
4 przyciski programowalne przez użytkownika
4 x diod LED programowalnych przez użytkownika
Niedrogi, jednopokładowy zestaw rozwojowy do układów SoC nRF52811 i nRF52840
Wszystkie moduły we/wy (48) i interfejsy są dostępne za pośrednictwem złączy
Złącze zgodne z Arduino Rev3 do użytku z systemem
Akcelerator kryptograficzny ARM CryptoCell CC310
Moduł radiowy Bluetooth 5 MultiProtocoll
Uchwyt baterii pastylkowej
Złącze zewnętrznej anteny NFC
Zestaw instrukcji DSP
Zewnętrzna pamięć wbudowana
Zintegrowana antena PCB 2,4 GHz
Antena NFC
Styki do pomiaru zużycia energii
Obsługa programowania/debugowania SEGGER J-Link OB
Obsługa programowania/debugowania zewnętrznych płyt głównych
Złącze RF SWF do bezpośrednich pomiarów RF
Interfejs USB bezpośrednio do nRF52840 SoC
Interfejs USB do zasilania i programowania/debugowania
Napięcie 1,7V i 5,5 V dostarczane z akumulatora, zewnętrznego lub USB
Promotion Board for RL78/G14 MCU -60pln
RL78/G14 Promotion Development Kit The YRPBRL78G14 is a promotion board for the Renesas RL78/G14 microcontroller. It supports on-board debugging, Flash programming, and is pre-programmed to work with the GUI provided on the included DVD to demonstrate the low-power capabilities of the Renesas RL78 MCU. Supplied with USB cable, documentation RL78 Family Microcontrollers, Renesas Electronics
Freescale's Attach Demo -130pln
frdm-kl26z- Kinetis® KL2x-72/96 MHz, USB Ultra-Low-Power Microcontrollers (MCUs) based on Arm® Cortex®-M0+ Core
frdm-batt- li-ion battery mc34673+gyrofxas21000+speaker-driven via i2c bus
+arduino touch lcd
msp430-ultra low power debug usb interface-100pln
The MSP-FET430UIF is a powerful flash emulation tool to quickly begin application development on the MSP430 MCU. It includes USB debugging interface used to program and debug the MSP430 in-system through the JTAG interface or the pin saving Spy Bi-Wire (2-wire JTAG) protocol. The flash memory can be erased and programmed in seconds with only a few keystrokes, and since the MSP430 flash is ultra-low power, no external power supply is required.
The debugging tool interfaces the MSP430 to the included integrated software environment and includes code to start your design immediately. The MSP-FET430UIF development tools supports development with all MSP430 FLASH devices, including
Features:
- Support firmware online upgrading.
- Support IAR430, CCS, AQ430, HI-TECH, GCC, TI, and other third-party 5 and 6 series compiler integrated development environment. It enables real-time simulation, debugging, single-step execution, break-point setting, memory content viewing modification, etc.
- Support JTAG, SBWand BSL interfaces.
- Support for WINXP/7/10 32- & 64-bit (Drivers for WIN7, WIN10 need to be installed via universal driver).
RENESAS Starter Kit for RL78/L13 R0K5010WMS00BE -290pln
Product Package Includes:
1. CPU board (with through hole for common expansion circuit board interface)
2. LCD display module (removable)
3. Adjustable shaft for potentiometer (removable)
- The potentiometer manufacturer name and model name is listed in the "Board Specifications" table on the "Layout and Specifications" page on each product page.
4. With compatible microcomputer, E1 emulator or E8a emulator is included.
5. Connection cable (USB cable, user interface cable)
6. Quick Start Guide
7. CD-ROM
- Various Documents
- Integrated Development Environment: High-performance Embedded Workshop or CubeSuite+ with compatible microcontroller
- C Compiler: Renesas Starter Kits Varies Please check on each product page.
- Debugger: E1 emulator debugga or E8a emulator debugga with compatible microcomputers.
- Flash Memory Programmer: With support microcontrols, Flash Development Toolkit free rating or
Renesas Flash Programmer Free Rating
8. Voltage conversion board for QzROM microcomputer (*740 family only included)
9. AC adapter (*Only Starter Kit + products such as RX62N are included.)
Dialog Semiconductor DA7280 Evaluation Board-300pln
Manufacturer: Dialog Semiconductor
Product Category: Power Management IC Development Tools
Product: Evaluation Boards
Type: Power Management Specialized
Tool Is For Evaluation Of: DA7280
Brand: Dialog Semiconductor
Interface Type: I2C, SPI
Silica Pengwyn Board-180pln
Texas Instruments Sitara AM 3354 ARM Cortex-A8 MCU @ 720 MHz
System Memory – 256 MB DDR3
Storage – 1 GB Nand Flash, 32 MB SPI Flash Memory, and microSD slot (if not used with Wi-Fi/Bt modules)
Connectivity and expandability
USB Host and Device Ports
RJ-45 Ethernet Port
Connector for optional 1 GB Ethernet Port
2x connectors for generic expansions modules
SDIO/MMC Port (can be used for optional WI-FI/bluetooth modules)
DVI Display Port
Silica PENGWYN Display Board-70pln
wqvga display 4.3"touch
Architech’s Hachiko-190pln
RZ/A1H ARM Cortex-A9 processor Spansion S25FL512SDPMF QSPI Flash Memory Maxim MAX5098AATJ dual power supply SD card slot 1 CAN channel (in CAR entertainment) MOST channel (in CAR entertainment) 2x USB host ports LVDS display output Ethernet Optional SDRAM Optional 4.3” Wide LCD touch screen The board is able to drive the Avnet ZedBoard display
Silicon Laboratories Si2457-EVB -120pln
Debuger ukladow uart.
C8051F35x 8-bit MCU Development Kit
8051F350 Development Kit Includes:
C8051F350 target board
Quick Start Guide
USB debug adapter
Supported by Simplicity Studio
C8051F50x - 8051 Tak, MCU, 8-bitowy Płytki ewaluacyjne -120pln
![[Sprzedam] Plytki ewalucyjne Renesas Cypress Silicon Labs [Sprzedam] Plytki ewalucyjne Renesas Cypress Silicon Labs](https://obrazki.elektroda.pl/6909176200_1618870102_thumb.jpg)
Core: CIP-51
Core: CIP-51
Core: CIP-51
RoHS: Details
Interface Type: USB
Core: ARM Cortex M3
Interface Type: USB
Core: ARM Cortex M4
Core: ARM Cortex M0
Core: ARM Cortex M3
Interface Type: I2C
Core: ARM Cortex M0
55 styków GPIO
Antena NFC
+arduino touch lcd
Features:
7. CD-ROM
- Various Documents
RJ-45 Ethernet Port
DVI Display Port
Quick Start Guide
USB debug adapter
