Witam potrzebuje pomocy ponieważ deska rozdzielcza była tylko odłączona na kilka minut i po podłączeniu pompa abs zgubiła kodowanie.Bardzo prosze o pomoc w zakodowaniu tej pompy.
Dziękuje Robert
Saturday,01,May,2021,16:33:01:17683
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WAUZZZ8P19A026548 License Plate:
Mileage: 162810km-101165mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 47 52 56 62 69 72
VIN: WAUZZZ8P19A026548 Mileage: 162810km-101165miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 8P7 907 115 D HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0020
Revision: AAH03--- Serial number: AUX7Z0H6FNV0I0
Coding: 0103000C180F0160
Shop #: WSC 06314 000 00000
VCID: 3A7F7F99751A8A5BCD-806E
1 Fault Found:
006439 - Relay for Aux Coolant Pump (J496)
P1927 - 000 - Open Circuit
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 162790 km
Time Indication: 0
Date: 2021.07.28
Time: 22:20:02
Freeze Frame:
RPM: 767 /min
Load: 12.9 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 40.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.716 V
Readiness: 0110 0000
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 52409 002 1048576
VCID: 77F9A6ADC6885733F2-8022
6 Faults Found:
03306 - Coding Not Valid
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 249
Mileage: 162814 km
Time Indication: 0
Date: 2021.07.29
Time: 00:59:35
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 4161
Count: 49664
Count: 0
Count: 0
Count: 0
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 1
Fault Frequency: 1
Reset counter: 249
Mileage: 162814 km
Time Indication: 0
Date: 2021.07.29
Time: 00:17:28
Freeze Frame:
Count: 16391
Count: 32770
Count: 12288
Count: 143
Count: 44800
Count: 0
Count: 0
Count: 0
01435 - Brake Pressure Sensor 1 (G201)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 162814 km
Time Indication: 0
Date: 2021.07.29
Time: 00:17:28
Freeze Frame:
Count: 16391
Count: 32770
Count: 12288
Count: 279
Count: 44800
Count: 0
Count: 0
Count: 0
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 162814 km
Time Indication: 0
Date: 2021.07.29
Time: 00:17:28
Freeze Frame:
Count: 16391
Count: 32770
Count: 12288
Count: 195
Count: 44800
Count: 0
Count: 0
Count: 0
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 162814 km
Time Indication: 0
Date: 2021.07.29
Time: 00:17:28
Freeze Frame:
Count: 16391
Count: 32770
Count: 12288
Count: 320
Count: 44800
Count: 0
Count: 0
Count: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 162814 km
Time Indication: 0
Date: 2021.07.29
Time: 00:17:28
Freeze Frame:
Count: 16391
Count: 32770
Count: 12288
Count: 291
Count: 44800
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000168 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
VCID: 73E192BD12F03B13CE-8026
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 5
Reset counter: 249
Mileage: 162802 km
Time Indication: 0
Date: 2021.07.28
Time: 23:42:55
Freeze Frame:
Voltage: 13.90 V
Temperature: 34.0°C
(no units): 136.0
(no units): 150.0
Temperature: 26.0°C
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008751204
Coding: B1AC2F8194141380EF00001C0000000000094E056401040300A800000000
Shop #: WSC 21044 141 210441
VCID: 489B15513BF6E8CB4B-801C
Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H12 0050
Coding: 00055568
Shop #: WSC 21044
No fault code found.
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 F HW: 8P0 919 475
Component: PARKHILFE 4K H06 0102
Revision: 11001001 Serial number: 52330821212751
Coding: 010003
VCID: 418D0875D8CCD9838C-8014
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030354A55304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4_AU35.rod
VCID: 499D1055E8FC11C354-801C
Crash sensor for side airbag: driver side:
Serial number: 3572DRB4000079D0797
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3582DRB4000079C4C36/
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35128RB400003EA986C.
Passenger side rear thorax airbag crash sensor:
Serial number: 35228RB400003EA1F4CZ
Crash sensor for front airbag: driver side:
Serial number: 35547RB400003FE1240J
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400003FE11AC.
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0000042
VCID: 418D087518CCD9838C-8014
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 931 T HW: 8P0 920 931 T
Component: KOMBIINSTR. VDO H15 0830
Revision: D0H15005 Serial number: 2246H005010756
Coding: 0005028
Shop #: WSC 00046 000 00000
VCID: 4483016107DECCABA7-8010
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0871801EB
Coding: E9A27F461002022102
VCID: 35656CA55C04652320-8060
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 11
Reset counter: 249
Mileage: 162790 km
Time Indication: 0
Date: 2021.07.28
Time: 22:20:00
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 162790 km
Time Indication: 0
Date: 2021.07.28
Time: 22:20:05
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 4381027D02D0CB939E-8016
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H15005 Serial number: AUX7Z0H6FNV0I0
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000148
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5F4FD985BA3ADBBD-807E
1 Fault Found:
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162790 km
Time Indication: 0
Date: 2021.07.28
Time: 22:20:02
Freeze Frame:
Battery Volts: 13.8 V
DU
Temperature: 36.0°C
Count: 3
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 L
Component: KSG H11 0080
Coding: 1880200002186D0985054C8F0167
VCID: 45851C650CE4F5A3B0-8010
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000148
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0050
Revision: 3A002002 Serial number: 00000113170995
Coding: 0100000100000000
Shop #: WSC 25477 000 00000
VCID: 2F695ECD7E585FF36A-807A
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 428F07791DCAC29B95-8016
End-------------------------(Elapsed Time: 02:44)--------------------------
Dziękuje Robert
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 162790 km
Time Indication: 0
Date: 2021.07.28
Time: 22:20:02
Freeze Frame:
RPM: 767 /min
Load: 12.9 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 40.0°C
Voltage: 13.716 V
Revision: 00H35001
6 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 249
Mileage: 162814 km
Time Indication: 0
Date: 2021.07.29
Time: 00:59:35
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 4161
Count: 49664
Count: 0
Count: 0
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 249
Mileage: 162814 km
Time Indication: 0
Date: 2021.07.29
Time: 00:17:28
Freeze Frame:
Count: 16391
Count: 32770
Count: 12288
Count: 143
Count: 44800
Count: 0
Count: 0
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 162814 km
Time Indication: 0
Date: 2021.07.29
Time: 00:17:28
Freeze Frame:
Count: 16391
Count: 32770
Count: 12288
Count: 279
Count: 44800
Count: 0
Count: 0
Count: 0
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 162814 km
Time Indication: 0
Date: 2021.07.29
Time: 00:17:28
Freeze Frame:
Count: 16391
Count: 32770
Count: 12288
Count: 195
Count: 44800
Count: 0
Count: 0
Count: 0
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 162814 km
Time Indication: 0
Date: 2021.07.29
Time: 00:17:28
Freeze Frame:
Count: 16391
Count: 32770
Count: 12288
Count: 320
Count: 44800
Count: 0
Count: 0
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 162814 km
Time Indication: 0
Date: 2021.07.29
Time: 00:17:28
Freeze Frame:
Count: 16391
Count: 32770
Count: 12288
Count: 291
Count: 44800
Count: 0
Count: 0
Count: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 249
Mileage: 162802 km
Time Indication: 0
Date: 2021.07.28
Time: 23:42:55
Freeze Frame:
Voltage: 13.90 V
Temperature: 34.0°C
(no units): 136.0
(no units): 150.0
Temperature: 26.0°C
Coding: 00055568
Shop #: WSC 21044
Coding: 010003
Coding: 0000042
Coding: 0005028
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 11
Reset counter: 249
Mileage: 162790 km
Time Indication: 0
Date: 2021.07.28
Time: 22:20:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 162790 km
Time Indication: 0
Date: 2021.07.28
Time: 22:20:05
Coding: 0000005
Coding: 0000148
Revision: 00H15000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162790 km
Time Indication: 0
Date: 2021.07.28
Time: 22:20:02
Freeze Frame:
DU
Temperature: 36.0°C
Count: 3
Count: 0
SteerAng n.Init
Cannot be reached
Coding: 0000148
Address 56: Radio
Cannot be reached
Coding: 0000144
Coding: 0000144
