Wednesday,03,November,2021,08:43:25:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 20.4.1.0
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WVGSV7AX8HK014450 License Plate:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 1C 22 25 2B 42 44 46 4C 4F 52
53 5F 62 72 75
VIN: WVGSV7AX8HK014450 Mileage: 47000km-29204miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: OK 0000
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 027 KB HW: 06J 907 309 A
Component: MED17.5.2 TFSI 2 07 3231
Revision: P3H08--- Serial number:
Coding: 0423010A190F0160
Shop #: WSC 01383 790 00058
VCID: 75E154D31CC13F2E28-8020
1 Fault Found:
001152 - Coolant Fan Control Circuit 1
P0480 - 000 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 47007 km
Time Indication: 0
Date: 2021.11.02
Time: 16:12:23
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 111.0°C
Temperature: 55.0°C
Absolute Pres.: 930.0 mbar
Voltage: 12.192 V
Readiness: 1110 0101
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 NK HW: 09G 927 750 NK
Component: AQ 250 6F 2627
Revision: 00H97000 Serial number:
Coding: 0000840
Shop #: WSC 00040 028 00018
VCID: 071D2E1B762D3DBE4A-8052
No fault code found.
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BN HW: 5N0 614 109 CH
Component: J104 C6 450M VDF1 0021
Revision: --H07--- Serial number: 00000009262955
Coding: 0005161
VCID: 78FF5DE70BD3424633-802C
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 G HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1305
Revision: 00092000 Serial number: 0420697434
Coding: 032C0C
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 397998E3B8599B4E0C-806C
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 561 907 426 G HW: 561 907 426 G
Component: AC Manuell H03 0506
Revision: 00001K02
Coding: 0010001002
ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
ROD: EV_ACManuaElectGen2BHTC_VW36.rod
VCID: 1F4D567B06BDD57E12-804A
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 N HW: 5K0 937 084 N
Component: BCM PQ35 B 122 0184
Revision: BG122001
Coding: EF1A0A1B80232EC4018800C11400044448512F86566D8DF064800000A040
VCID: 3D718CF3A471A76E20-8068
Subsystem 1 - Part No SW: 5N1 955 119 B HW: 5N1 955 119 B Labels: 1KX-955-119.CLB
Component: WWS316 120916 24 0664
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 281016 05 54 0403
Coding: 02304D
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 AB HW: 5N0 959 655 AB
Component: J234__005 VW10 HI 5418
Revision: 36023000 Serial number: 003MAPMWFWG5
Coding: 0012341
VCID: 7DF14CF324F1676E60-8028
Subsystem 1 - Part No: 5N0 959 339 B
Component: BF-Gewichtsens. 003 0001
Subsystem 2 - Serial number: 0000000000U7EQ
Subsystem 3 - Serial number: 0010.08.160000300000660067˙†63
Subsystem 4 - Serial number: 660067˙†6332MTS614432616/˙†63
Subsystem 5 - Serial number: 32616/˙†6342MTS6215528868˙†63
Subsystem 6 - Serial number: 528868˙†6351HTS6DGRFGEKRS˙†63
Subsystem 7 - Serial number: FGEKRS˙†6361HTS648KFGEKR5˙†63
Subsystem 8 - Serial number: FGEKR5˙†63727TS6AV62GEKR%˙†63
Subsystem 9 - Serial number: 2GEKR%˙†63827TS68I72GEKJL˙
Subsystem 10 - Serial number: 2GEKJL˙
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 501 DM HW: 5K0 953 569 AP
Component: LENKS.MODUL 016 0180
Revision: FF010042 Serial number: 20161029100564
Coding: 110A140000
Shop #: WSC 00040 028 00056
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 78FF5DE7C3D3424633-802C
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0022335
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5N0 920 973 M HW: 5N0 920 973 M
Component: KOMBI H02 1104
Serial number: 00000000000000
Coding: 221F010000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 3E738BFFA177BC7639-806A
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BK HW: 7N0 907 530 AM
Component: J533 Gateway H55 1682
Revision: H55 Serial number: 101016F1001465
Coding: 356022
Shop #: WSC 00040 028 00001
VCID: 7AFB47EFF5DF505645-802E
Address 1C: Position Sensing
Cannot be reached
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7540
Serial number: HA1-00021.09.16
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X_002.rod
VCID: 52ABCF4F05EF4816ED-8006
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H02 1104
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6ADB77AF8D7FE0D6B5-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 16000177839006
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X_VW31.rod
VCID: 3169A0C36029530EB4-8064
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 5N0 959 701 H HW: 3C0 959 793 H
Component: TUER-SG FT 002 0601
Revision: 13100010 Serial number: 0010770401
Coding: 0004B4
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 3A7B87EFBD5F905605-806E
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 703 G HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 010 1505
Serial number: 00000009821119
Coding: 000490
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 S HW: 5N1 909 148 K
Component: J500__APA-BS KL.286 1501
Revision: 1BH04843 Serial number: 00162810060101
Coding: 0000258
VCID: 428BFF0F1D8FD8965D-8016
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1682
Coding: 050B0500
VCID: 6FED66BBBE9D05FEE2-803A
Subsystem 1 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H04 0090
Serial number: 0123456789ABCDEFGHIJ
1 Fault Found:
02907 - Control Module for Roof Shade (J394)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 47007 km
Time Indication: 0
Date: 2021.11.03
Time: 08:38:33
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 5N0 959 702 H HW: 3C0 959 792 H
Component: TUER-SG BT 002 0601
Revision: 15100010 Serial number: 0010716931
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 3B7582EBB265A95E1E-806E
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 704 G HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 010 1505
Serial number: 00000009810652
Coding: 000490
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H20 Serial number: 00000000308243
Coding: 0026156
VCID: 387F9DE74B538246F3-806C
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 200 B HW: 5C0 035 200 B
Component: MU-S-S-US H31 0359
Serial number: VWZAZ2S0609470
Coding: 02130600FF00000051110001001808009F0100D40020010002
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 14270957FF7B8626BF-8040
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0160
Serial number: 000003554140558
Coding: 02130604C21632107F1606C20000
ASAM Dataset: EV_OCULow 002010
ROD: EV_OCULow_002.rod
End-------------------------(Elapsed Time: 03:39)--------------------------
