Weryfikacja kodu UART w mikrokontrolerze AVR dla komunikacji z ESP8226
patryk117pat 18 Lut 2022 10:27 321 5
  • #1 19891142
    patryk117pat
    Witam, Mógł by ktoś sprawdzić czy mój kod jest prawidłowy? Ponieważ nie mogę odebrać danych z Esp przez protokół UART.
     * uart.c
     *  Created on: 11 lut 2021
     *      Author: admin
    // uart.c
    #include "prj.h"
    volatile char uart_buf[MAX_UART_BUF_SIZE];
    volatile char uart_rsp[MAX_UART_BUF_SIZE];
    volatile int  uart_buf_idx =0;
    volatile int  uart_char_size =0;
    volatile u8 command_ready = FALSE;
    volatile u8 http_get = 0;
    volatile u8 rsp_greater = 0;
    volatile u8 rsp_sendok=0;
    volatile u8 rsp_control=0;
    volatile u8 led;
    volatile u8 led_value;
    volatile u8 rsp_got_ip;
    volatile u8 rsp_found=0;
    void uart_init(uint32_t baud)
    	// fosc = 8000000 Hz
    	    // baud=9600.0,
    	    UBRRL = 0x33;
    	    UBRRH = 0x00;
    	    // enable uart N81
    	    UCSRB =  _BV(RXEN) | _BV(TXEN) | _BV(RXCIE) ;
    	    UCSRC = _BV(URSEL) | _BV(UCSZ1) | _BV(UCSZ0);
    	    memset( (void *) &uart_buf[0], 0, MAX_UART_BUF_SIZE);
    void uart_send_char(unsigned char ch)
       while (! (UCSRA & _BV(UDRE)) );
    	UDR = ch;
    void uart_sendString(char *s)
       unsigned int i=0;
       while (s[i] != '\x0')
           uart_send_char(s[i++]);
    void uart_sendString_hex(char *s)
       unsigned int i=0;
            uart_send_hex(s[i++]);
            uart_send_char(' ');
    void  uart_send_hex(unsigned char ch)
        unsigned char i,temp;
        for (i=0; i<2; i++)
            temp = (ch & 0xF0)>>4;
            if ( temp <= 9)
                uart_send_char ( '0' + temp);
            else
                uart_send_char(  'A' + temp - 10);
            ch = ch << 4;
    ISR (USART_RXC_vect)
        char status ,ch;
    	static int idx=0;
    	static int crlf_idx = 0;
    	BOOL bGET_flag = FALSE;
        char *pBuf = (char *) &uart_buf[0];
        status = UCSRA;
        ch   = UDR;
        idx = idx % (MAX_UART_BUF_SIZE-1);
        uart_buf[idx] = ch;
        idx++;
            if (crlf_idx==3 && ch=='\n')
    		//	Debug("htpp ");
    			idx= 0;
    			crlf_idx=0;
                http_get= 1;
    		if (crlf_idx==2)
    			if (ch=='\r')  crlf_idx++;
    			else crlf_idx =0;
    		if (crlf_idx==1 && ch=='\n')
    			if (bGET_flag == FALSE)
    				crlf_idx= 0;
    				uart_buf[idx] = '\x0';
                    // kopiuj
                    if (idx != 2)
                        memcpy( (void *) &uart_rsp[0] , (void *) &uart_buf[0],idx+1);
                        rsp_found = 1;
                     	// "+CIFSR:STAIP"
    				if (strstr(pBuf, "STAIP") != NULL)
    				    get_ip(pBuf,MAX_UART_BUF_SIZE);
    				idx = 0;
    			else // bGet_flag == 1
    				crlf_idx++;
    		if (crlf_idx ==0 && ch =='\r')
    			 crlf_idx++;
    	    if (ch == '>')
                rsp_greater = 1;
    [/i][/i]
     * uart.h
     *      Author: admin
    #ifndef _UART_H
    #define _UART_H
    #include "prj.h"
    void uart_init();
    void uart_send_char(unsigned char ch);
    void uart_sendString(char *s);
    void uart_send_hex(unsigned char ch);
    void uart_sendString_hex(char *s);
    void copy_command();
    #define MAX_UART_BUF_SIZE  64
    extern volatile char cmd_buf[MAX_UART_BUF_SIZE];
    extern volatile char uart_rsp[MAX_UART_BUF_SIZE];
    extern volatile unsigned char command_ready;
    extern volatile int  buf_index;
    extern volatile int  uart_char_size;
    extern volatile u8 http_get ;
    extern volatile u8 rsp_greater;
    extern volatile u8 rsp_sendok;
    extern volatile u8 rsp_control;
    extern volatile u8 led;
    extern volatile u8 led_value;
    extern volatile u8 rsp_got_ip;
    extern volatile u8 rsp_found;
    #endif
  • #2 19891230
    adamegah
    1.Włącz ostrzeżenia kompilatora i jeszcze raz skompiluj kod źródłowy.
    2.Czy możesz odebrać cokolwiek?
    Spoiler:
    jeśli nie to może występować problem sprzętowy
    3.Chcesz przesyłać z ESP8226 na coś czy z czegoś na ESP8226?
  • #3 19891322
    patryk117pat
    Jedyne ostrzeżenie to W Lini 98 /uart.c:98:10: warning: variable 'status' set but not used [-Wunused-but-set-variable]. a ma być to komunikacja miedzy atmega16 a esp obustronna dlatego rejestry są nastawione na nadawanie i odbiór. chyba ze jeszcze timer mam nastawiony źle.
    volatile  int timestamp =0;
    void Timer0_init()
        TCCR0 = 0x03; //  = 64
        TCNT0 = 256 - 115; // 1ms
        TIMSK |= _BV(TOIE0);
    ISR (TIMER0_OVF_vect)
        timestamp++;
  • #4 19891392
    ex-or
    Skoro wszystkie zmienne, które z założenia powinny być lokalne dla modułu są wywalone na zewnątrz i opatrzone, jak leci, specyfikatorem volatile to można powiedzieć, że nie jest prawidłowy.
  • #5 19891456
    patryk117pat
    ex-or wszystko jest w pliku prj.h i przez to są globalne
  • #6 19891922
    ex-or
    Ale po co? I nie, nie przez to.
    Skąd wiesz, że błąd nie tkwi po stronie ESP?
