QIACHIP Universal WIFI Ceiling Fan Light Remote Control Kit - BK7231N - CB2S
echojjj 24 Maj 2022 01:20 9099 9
Treść została przetłumaczona angielski » polski Zobacz oryginalną wersję tematu
  • QIACHIP Universal WIFI Ceiling Fan Light Remote Control Kit
    model: KLCW-110v/220v
    buy: amazon.com, aliexpress.com
    It transforms your traditional ceiling fan and its light into a "smart" fan and light!
    QIACHIP Universal WIFI Ceiling Fan Light Remote Control Kit - BK7231N - CB2SQIACHIP Universal WIFI Ceiling Fan Light Remote Control Kit - BK7231N - CB2S
    This controller has the following functions:
    Turn the fan on or off.
    Turn the light on or off.
    Set the speed of the fan to low, medium or high.
    Set a timer to automatically turn the fan off after a number of hours.
    Display how much time is remaining after the timer has been set.
    Turn the controller's signal beep on or off.
    I first bought this ceiling fan/light controller after seeing it listed as a Tasmota supported device. Out of the box, this device can be controlled by its RF remote control or the Smart Life (cloud) app. Smart Life is compatible with Alexa for voice control. But, it's always my goal to keep my smart home devices out of the cloud and have local control. Tasmota is the answer for ESP-based devices. This fan controller has the CB2S module with Beken BK7231N so I would need an ESP drop-in replacement like TYWE2S (ESP-02S) in order to flash Tasmota. So, I ordered the TYWE2S from aliexpress and knew it would take quite a long time for it to arrive.
    But, wait...
    In the meantime, I discovered OpenBeken firmware supporting the BK7231N (also BK7231T, XR809 and BL602). Wow!
    Connections and flashing the firmware:
    When OTA programming method becomes available in the near future, you will not have to do this! :D
    First, I had to cut the RX and TX traces between the CB2S module and TuyaMCU. I connected RX and TX on the module to TX and RX of my CH340 USB to TTL HW597 Converter. I powered the module with an external USB cable (phone charger wires). I connected 5V(+) wire to the AMS1117 input and (-) to GND. The (-) wire has to also be connected to the HW597's GND. I used a breadboard to make the connections. Using the breadboard makes it simple to disconnect and reconnect power which is part of the programming process.
    To flash the OpenBeken firmware I used hid_download_py. But first, I saved the original firmware for tuya-cloudcutter, so that this fan controller will be programmable OTA (over-the-air) and you will not have to do any wire connections or soldering!
    After flashing the firmware, I soldered wires to reconnect the RX and TX from CB2S to the TuyaMCU. The RF remote control continues to work. Now it's time to do the OpenBeken config.
    Mapping TuyaMCU to OpenBeken channels:
    TuyaMCU is a little tricky if you have to figure out for yourself the different dpId's, functions and data types. Fortunately for me, this had already been mostly done and available online in Tasmota's template page for this fan controller. One was missing which I found belongs to the controller's beep.
    This is the autoexec.bat script which maps the functions of the controller.
    // start MCU driver
    startDriver TuyaMCU
    // let's say that channel 1 is dpid1 - fan on/off
    setChannelType 1 toggle
    // map dpid1 to channel1, var type 1 (boolean)
    linkTuyaMCUOutputToChannel 1 1 1
    // let's say that channel 2 is dpid9 - light on/off
    setChannelType 2 toggle
    // map dpid9 to channel2, var type 1 (boolean)
    linkTuyaMCUOutputToChannel 9 1 2
    //channel 3 is dpid3 - fan speed
    setChannelType 3 LowMidHigh
    // map dpid3 to channel3, var type 4 (enum)
    linkTuyaMCUOutputToChannel 3 4 3
    //dpId 17 = beep on/off
    setChannelType 4 toggle
    linkTuyaMCUOutputToChannel 17 1 4
    //dpId 6, dataType 4-DP_TYPE_ENUM = set timer
    setChannelType 5 TextField
    linkTuyaMCUOutputToChannel 6 4 5
    //dpId 7, dataType 2-DP_TYPE_VALUE = timer remaining
    setChannelType 6 ReadOnly
    linkTuyaMCUOutputToChannel 7 2 6
    Home Assistant [version 2022.5.5] setup for reference:
    There are really many ways to set up the fan controller in Home Assistant. I have a ceiling fan that has three speeds (low, medium, high) and a light. The controller has a built-in countdown timer to automatically turn the fan off after a number of hours. Instead of using the built-in timer function like I did, you could easily create an automation using a Home Assistant timer.
    My Home Assistant config:
    fan:
      - platform: mqtt
        name: "Living Room Fan"
        state_topic: "living-room-fan/1/get"
        command_topic: "living-room-fan/1/set"
        payload_on: '1'
        payload_off: '0'
        percentage_state_topic: "living-room-fan/3/get"
        percentage_value_template: >-
          {% if value == '0' %}
          33
          {% elif value == '1' %}
          67
          {% elif value == '2' %}
          100
          {% else %}
          0
          {% endif %}
        percentage_command_topic: "living-room-fan/3/set"
        percentage_command_template: >-
          {% if value > 0 and value <= 33 %}
          0
          {% elif value > 33 and value <= 67 %}
          1
          {% elif value > 67 and value <= 100 %}
          2
          {% endif %}
        availability_topic: "living-room-fan/connected"
        payload_available: "online"
        payload_not_available: "offline"
        unique_id: "living-room-fan"
        qos: 1
        retain: true
    light:
      - platform: mqtt
        name: "Living Room Light"
        state_topic: "living-room-fan/2/get"
        command_topic: "living-room-fan/2/set"
        payload_on: '1'
        payload_off: '0'
        qos: 1
        retain: true
    sensor:
      - platform: mqtt
        name: "Living Room Fan Timer"
        state_topic: "living-room-fan/5/get"
        qos: 1
      - platform: mqtt
        name: "Living Room Fan Timer Remaining"
        state_topic: "living-room-fan/6/get"
        qos: 1
    switch:
      - platform: mqtt
        name: "Living Room Fan Beep"
        state_topic: "living-room-fan/4/get"
        command_topic: "living-room-fan/4/set"
        payload_on: '1'
        payload_off: '0'
        qos: 1
        retain: true
        icon: mdi:volume-high
      - platform: template
        switches:
          living_room_fan_speed_low:
            friendly_name: Living Room Fan Speed Low
            value_template: "{{ is_state('input_number.living_room_fan_speed', '0.0') and is_state('fan.living_room_fan', 'on') }}"
            turn_on:
              - service: fan.turn_on
                target:
                  entity_id: fan.living_room_fan
              - service: fan.set_percentage
                data:
                  percentage: 33
                target:
            turn_off:
              - service: fan.turn_off
                target:
          living_room_fan_speed_med:
            friendly_name: Living Room Fan Speed Med
            value_template: "{{ is_state('input_number.living_room_fan_speed', '1.0') and is_state('fan.living_room_fan', 'on') }}"
            turn_on:
                target:
                data:
                  percentage: 67
                target:
            turn_off:
                target:
          living_room_fan_speed_high:
            friendly_name: Living Room Fan Speed High
            value_template: "{{ is_state('input_number.living_room_fan_speed', '2.0') and is_state('fan.living_room_fan', 'on') }}"
            turn_on:
                target:
                data:
                  percentage: 100
                target:
            turn_off:
                target:
    Home Assistant automation to capture the fan speed:
    alias: Track Living Room Fan Speed
    description: ''
    trigger:
      - platform: mqtt
        topic: living-room-fan/3/get
    condition:
      - condition: template
        value_template: '{{ trigger.payload | int > -1 }}'
    action:
      - service: input_number.set_value
        data:
          value: '{{ trigger.payload | int }}'
        target:
          entity_id: input_number.living_room_fan_speed
    mode: single
    Home Assistant automation to set the fan timer:
    alias: Set Living Room Fan Timer
    description: ''
    trigger:
      - platform: state
        entity_id:
          - input_number.set_living_room_fan_timer
    condition:
      - condition: state
        state: 'on'
        value_template: '{{ trigger.to_state.state | int > 0 }}'
    action:
      - service: mqtt.publish
        data:
          topic: ceiling-fan/5/set
          qos: '1'
          payload_template: '{{ trigger.to_state.state | int }}'
    mode: restart
    Home Assistant automation to cancel the fan timer:
    alias: Cancel Living Room Fan Timer
    description: ''
    trigger:
      - platform: state
        entity_id:
        to: '0.0'
    condition:
      - condition: state
        state: 'on'
        value_template: '{{ states(''sensor.living_room_fan_timer_remaining'') | int > 0 }}'
    action:
        data: {}
        target:
      - wait_for_trigger:
          - platform: mqtt
            topic: ceiling-fan/1/get
            payload: '0'
      - delay:
          hours: 0
          minutes: 0
          seconds: 1
          milliseconds: 0
        data:
          percentage: >-
            {% if is_state('input_number.living_room_fan_speed','0') %} 33 {% elif
            is_state('input_number.living_room_fan_speed','1') %} 67 {% elif
            is_state('input_number.living_room_fan_speed','2') %} 100 {% else %} 33
            {% endif %}
        target:
    mode: single
    Two Home Assistant helpers:
    QIACHIP Universal WIFI Ceiling Fan Light Remote Control Kit - BK7231N - CB2S QIACHIP Universal WIFI Ceiling Fan Light Remote Control Kit - BK7231N - CB2S
    My lovelace cards in Home Assistant:
    When the fan timer is set:
    When the fan timer is not set:
    square: false
    columns: 1
    type: grid
    cards:
      - square: false
        columns: 5
        type: grid
        cards:
          - show_name: true
            show_icon: true
            type: button
            tap_action:
              action: toggle
            entity: light.living_room_light
            show_state: false
            icon: mdi:ceiling-fan-light
          - show_name: true
            show_icon: true
            type: button
            tap_action:
              action: toggle
            icon: mdi:fan-speed-1
            entity: switch.living_room_fan_speed_low
            name: Fan - Low
          - show_name: true
            show_icon: true
            type: button
            tap_action:
              action: toggle
            icon: mdi:fan-speed-2
            entity: switch.living_room_fan_speed_med
            name: Fan - Medium
          - show_name: true
            show_icon: true
            type: button
            tap_action:
              action: toggle
            icon: mdi:fan-speed-3
            entity: switch.living_room_fan_speed_high
            name: Fan - High
          - show_name: true
            show_icon: true
            type: button
            tap_action:
              action: toggle
            entity: switch.living_room_fan_beep
            icon: ''
      - type: horizontal-stack
        cards:
          - type: entities
            entities:
              - entity: input_number.set_living_room_fan_timer
                icon: ' '
            show_header_toggle: false
          - type: conditional
            conditions:
              - entity: sensor.living_room_fan_timer_remaining
                state_not: '0'
            card:
              type: entity
              unit: minutes
              name: Fan Timer Remaining
              icon: mdi:timer
          - type: conditional
            conditions:
                state_not: '0'
            card:
              show_name: true
              show_icon: false
              type: button
              tap_action:
                action: call-service
                service_data:
                  value: 0
                target:
                  entity_id: input_number.set_living_room_fan_timer
              icon: ''
          - type: conditional
            conditions:
                state: '0'
            card:
              type: markdown
              content: ' '
          - type: conditional
            conditions:
                state: '0'
            card:
              type: markdown
              content: ' '
    Alexa voice control via Node-RED [v2.2.2] for reference:
    echojjj
    Poziom 8  
    echojjj napisał 20 postów o ocenie 13. Jest z nami od 2022 roku.
  • #2 20043142
    p.kaczmarek2
    Moderator Smart Home
    Bardzo dobra robota! Cieszę się, że Twój fan w końcu działa.
    Warto wspomnieć, że dodałem też opcję ,,OffLowMidHigh", a więc zamiast tego:
    możesz to zrobić:
    setChannelType 3 OffLowMidHigh
    oczywiście w zależności od tego, czego oczekuje twój MCU TuyaMCU
  • #3 20231770
    daveproffer
    Dziękuję za ten wpis!
    Czy masz zdjęcie na tablicy, gdzie to zrobiłeś? Albo może wskazać mi lokalizację. Dzięki.
    "wytnij ślady RX i TX między modułem CB2S a TuyaMCU"
  • #4 20231795
    p.kaczmarek2
    Hej @daveproffer , na tym obrazku widać, które ślady to RX i TX:
    Możesz również spojrzeć na pinout CB2S, aby określić, które sygnały są RX/TX:
    PS: Jeśli nie chcesz przecinać śladów, możesz wylutować cały CB2S za pomocą knota lutowniczego, a następnie podłączyć tylko zasilanie 3.3V, GND, RX i TX i zaprogramować go poza płytą (zrestartuj go, odłączając zasilanie i ponownie podłączając podczas migające narzędzie czeka na ,,wejście na autobus")
  • #5 20466723
    rojoricardo
    Poziom 4  
    Czy udało Ci się uruchomić sterowanie RF?
  • #6 20466783
    p.kaczmarek2
    W tym urządzeniu odbiornik RF jest podłączony bezpośrednio do MCU, więc zawsze działa, nie ma na niego wpływu zmiana oprogramowania modułu WiFi.
  • #7 20984952
    tiredofit
    Zdałem sobie sprawę, że mam kilka takich w domu — wydaje mi się, że nie mogę uruchomić flashowania ręcznie, prawdopodobnie z powodu moich własnych niemożności, jednak mogę ustawić losową sieć Wi-Fi w trybie parowania. Widzę, że w Tuya Cloudcutter można to flashować, czy komuś się to udało? W fazie łączenia DHCP/Cloudcutter ssid nic się nigdy nie kończy, co sprawia, że myślę, że nie jest to możliwe.
  • #8 20985170
    p.kaczmarek2
    Która wersja jest wyświetlana w aplikacji Tuya? Nowsze kompilacje mogą być już załatane.
  • #9 21186936
    jjlange91
    Właśnie odebrałem jeden z nich i przygotowuję się do ponownego flashowania. Jedną z rzeczy, które zauważyłem w instrukcji, jest to, że powinien istnieć sposób na przełączenie go w tryb parowania WiFi poprzez przytrzymanie kombinacji przycisków na pilocie. Chciałbym zachować tę funkcjonalność w nowym oprogramowaniu, jeśli to możliwe. Opierając się na moim zrozumieniu, w jaki sposób ten konkretny moduł jest złożony, jedyne połączenie między modułem WiFi a pilotem odbywa się za pośrednictwem TuyaMCU, co sugeruje mi, że musi istnieć jakaś wiadomość wysłana za pośrednictwem protokołu TuyaMCU, aby wymusić moduł WiFi w trybie parowania, gdy te przyciski są przytrzymane. Czy jest to standardowa rzecz, która może być już obsługiwana przez OpenBeken, coś nowego, co wymagałoby inżynierii wstecznej, czy coś zupełnie innego, czego nie rozumiem? Dziękuję za wszelkie informacje.
  • #10 21187171
    divadiow
    Poziom 29  
    Wydaje mi się, że trzeba by sprawdzić, jaką wiadomość wysyła MCU do modułu WiFi po wykonaniu kombinacji zdalnego resetowania przycisków.
    OpenBeken nie będzie jednak wiedział, co zrobić z tą wiadomością. Domyślam się, że fabryczne oprogramowanie układowe zna tę wiadomość jako oznaczającą zresetowanie urządzenia, które następnie przełączy je w tryb parowania, aby oficjalna aplikacja mogła je wykryć.
    W jaki tryb ma przejść OpenBeken?
    Czyszczenie ustawień i nadawanie początkowego AP?
    Przejście w tryb bezpieczny?
