Czesc. Szukam pełnej pinologii cas3 bmw.
1Signal, terminal 30G Relay, terminal 30G
2 A Signal, terminal R Brake light switch
3 E Signal Clutch switch module Clutch switch module
4 A Signal, terminal R Passenger's seat occupancy detection
5 Not occupied
6 Not occupied
7 A Signal, terminal 15 Relay, fuel injectors M54 engine
8 A Signal, terminal 15 Relay, terminal 15
9 A Signal, terminal 15 Steering column switch cluster
10 Not occupied
11 Not occupied
12 M Ground Ground point
13 A Signal, terminal 15 OBDII socket
14 A Signal, terminal 15 Light module
15 Not occupied
16 Not occupied
17 Not occupied
18 A Wake-up signal, terminal 15 Active cruise control
19 A Wake-up signal, terminal 15 Connector , terminal 15 wake-up signal
20 A Signal, electronic vehicle immobilizer DME control module Digital diesel electronics control module
21 E Supply Fuse F7
22 A Signal, starter terminal 50 Starter
23 Not occupied
24 Not occupied
25 M Ground Ground point
26 A/E CAN bus low CAN-bus connector
27 Not occupied
28 A Signal, engine start DME control module Digital diesel electronics control module
29 E Signal, center lock Hazard warning/central locking switch
30 Not occupied
31 E Signal, rear left wheel speed Connector X1101 (rear left wheel speed)
32 E Brake light switch signal Brake light switch
33 E Signal, remote control services Antenna tuner with remote control receiver
34 E Supply Fuse F15
35 A/E Signal, CAN-bus CAN-bus connector
36 A Telephone ON signal TCU
37 Not occupied
38 E Signal, front lid contact Hood contact
39 E Rear lid open signal Rear lid release switch (interior)
40 E Signal, hotel switch Switch, trunk lid/tailgate lock
41 E Signal, parked position Transmission control
