Ma ktoś schemat licznika bmw e46 1999r ten z dwoma kościami 26pin i 18pin
ToNieKubaM10 04 Maj 2023 22:23 474 1
  • #1 20566963
    ToNieKubaM10
    Poziom 3  
    Witam potrzebuje schemat licznika e46 z dwoma kościami czarna 26pin i biała 18pin
  • #2 20567170
    CameR
    X11175 26-pin, black Plug connector Instrument cluster control unit
    X11176 18-pin, natural Plug connector Instrument cluster control unit
    Pin assignments at plug connector X11175
    Pin Type Description / Signal type Connection /
    Measuring notes
    1 M Ground Ground connector
    2 A Signal Battery charge indicator Connector terminal 61
    3 A Engine start signal feedback Digital diesel electronics control unit
    4 E Terminal 30 Fuse F43
    5 E Terminal 15 Fuse F34
    6 E Terminal R Fuse F10
    7 E Signal Locator lighting Connector, instrument and locator lighting
    8 A Speedometer (A) output signal Connector Speedometer (A) output signal
    9 E/A CAN bus high Connector CAN bus high
    10 E/A CAN bus low Connector CAN bus low
    11 A Signal, fuel tank sensor (right) Fuel supply sensor
    12 A Signal, fuel tank sensor ground (right) Fuel supply sensor
    13 A Signal, oil pressure switch Digital diesel electronics control unit
    14 E/A K-bus signal K-bus connector
    15 A Signal, fuel tank sensor (left) Electric fuel pump
    16 A Signal, fuel tank sensor ground (left) Electric fuel pump
    17 E Signal Oil level sensor Digital diesel electronics control unit
    18 E Signal, service interval indicator reset Diagnostic connector
    19 E Signal Processed wheel speed, rear left Connector Processed wheel speed, rear left
    20 E Signal Brake fluid level Connector Brake fluid level
    21 A Signal, airbag warning LED Multiple restraint system control unit
    22 A Signal Warning lamp ABS/ASC unit
    23 A Signal Parking brake Connector Parking brake
    24 M Signal, brake wear sensor Front left brake pad sensor
    25 E/A Diagnosis signal TXD Diagnostic connector
    26 A Signal, coolant level too low Coolant level switch
    Pin assignments at plug connector X11176
    Measuring notes
    1 A Ground, outside temperature Temperature sensor
    2 A Signal, outside temperature Temperature sensor
    3 Not used
    4 A Signal, washer fluid level low Wash water level switch
    5 A Signal, cruise control active LED Cruise control module
    6 Not used
    7 Not used
    8 Not used
    9 Not used
    10 Not used
    11 Not used
    12 A Signal, driver's seat belt contact Hall-effect sensor, seat belt buckle
    13 A Signal, steering column switch Turn indicator/low beam switch
    14 A Signal, gong T3 Gong
    15 Not used
    16 Not used
    17 Not used
    18 Not used
