3600 to oznaczenie serii ( tak mi się wydaje ) jeżeli masz model 3660 to można go uzywać jako rozbudowany organizer. Jeżeli jesto model poniżej 3660 daj sobie spokój.
jeszcze jedno, jeżeli bateria była długo nie ładowana jest duża szansa że nie wstanie będziesz musiał kupić nową.
jakie mam parametry i jak sie zachowuje
po angielsku ale podstawowe parametru masz ( pamiętaj 3600 - to seria, tu masz dane modelu 3650)
Item: Compaq iPAQ H3650 (3635 3630) Color 32MB PDA Note all three items are identical.
Manufacturer: Compaq
Buffer Time: PocketPC day(s)
Backlit Display: Yes
Installed Memory (RAM): 32 MB
Installed ROM: 16 MB
Operating System: Microsoft Windows CE
Input Method: Control Pad, Stylus, Touchscreen
Connectors: (1) Serial - 9 pin D-shell (RS-232/EIA 574), USB - Universal Serial Bus
Included Functions: Address Book, Audio Playback, Audio Recording, Calculator, Calendar, E-mail, Expense Tracker, Handwriting Recognition, Integrated MP3 Player, Note Pad, Phone Book, Scheduler, Spreadsheet, Web Browser, Word Processor
Included Devices: Connectivity Cable, Installation Software
Battery Life: 12 hour(s)
Color Depth: 4,096 Colors (12-bit)
Input Devices: Joystick, Touch Screen
Power Options: AC Input, Battery, Rechargeable Battery
Display Size: 3.77 in
Display Type: Active Matrix LCD (TFT)
Slots: Compact Flash Type I, Compact Flash Type II (via optional expansion sleeve)
Processor Speed: 206 MHz
Dimensions: 5.11" x 3.28" x 0.62"
Weight: 6 oz
Description: Of all the PDA devices out there, including both those from Palm and Pocket PC, none can match Compaq's iPAQ H3650 Pocket PC when it comes to audio and video. With its eye-catching and innovative design, a media player capable of playing MP3s and video, color TFT display, and powerful Pocket PC applications, the iPAQ Pocket PC sets the standard. It also covers the basics well, with all the tools you need to keep track of your appointments, notes, and contacts.
