Witam!
Przepisałem z "NE" program do sterownika akariowego,niestety podczas sprawdzania błędów,Bascom wyrzuca mi kilka.Bardzo proszę,gdyby ktos zechciał zerknąć jaka jest tego przyczyna.Z góry dziękuję za pomoc.
'Sterownik do akwarium
'Wersja Kompilatora Bascom-AVR V.1.11.7.4
'Programator Bascom-AVR Demo V.1.11.7.4
'stk200 \ Stk300
'Generator Zewnętrzny 8mhz(external)
'FusebitA9871110 : 1110external Osc
'Reset Wewnetrzny : Fusebit Kl 10
'6ck64mS Delay
$regfile = "m8def.dat"
$crystal = 8000000
Config Timer1 = Timer , Prescale = 8
Config Adc = Single , Prescaler = 16 , Reference = Avcc
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = Portb.5 , Db5 = Portb.4 , Db6 = Portb.3 , Db7 = Portb.2 , E = Portc.2 , Rs = Portc.4
'_______________________________________________________________________
Config Pinb.0 = Output
Config Pinb.1 = Input
Portb.1 = 1
Config Pinb.2 = Output
Config Pinb.3 = Output
Config Pinb.4 = Output
Config Pinb.5 = Output
Config Pinb.6 = Output
Config Pinb.7 = Output
'______________________________________________________________________________
Config Pinc.0 = Output
Config Pinc.1 = Input
Portc.1 = 1
Config Pinc.2 = Output
Config Pinb.3 = Input
Portc.3 = 0
Config Pinc.4 = Output
Config Pinb.5 = Input
Portc.5 = 1
Config Pinc.6 = Input
Config Pind.0 = Input
Config Pind.1 = Input
Config Pind.2 = Input
Config Pind.3 = Output
Config Pind.4 = Output
Config Pind.7 = Input
Portd.7 = 1
Config Pind.6 = Input
Portd.6 = 1
Config Pind.5 = Input
Portd.5 = 1
'PIN/PORT
#if_sim = 0
'przyciski
S1 Alias Pind.7
S2 Alias Pind.6
S3 Alias Pind.5
S4 Alias Pind.1
#else
'przyciski
S1 Alias Portd.7
S2 Alias Portd.6
S3 Alias Portd.5
S4 Alias Portd.1
#endif
Clock Alias Portc.0
Pk1 Alias Portd.3
Pk2 Alias Portd.4
Pk3 Alias Portb.0
Const Skok = 4883
Dim Adc_reg As Word
Dim Adc_buf As Word
Dim Temper As Byte
Dim Licznik As Byte
Dim Sekundy As Long
Dim Temp_time As Long
Dim Temp_degs As Long
Dim Temp As Long
Dim Degs As Integer
Dim W_on As Long
Dim W_off As Long
Dim P_on As Long
Dim P_off As Long
Dim Coun_time As Byte
Dim Fuse As Word
Dim Fuse_hi As Byte
Dim Fuse_lo As Byte
Dim S_s As Byte
Dim M_m As Byte
Dim H_h As Byte
Dim W_h_on As Byte
Dim W_m_on As Byte
Dim W_h_off As Byte
Dim W_m_off As Byte
Dim P_h_on As Byte
Dim P_m_on As Byte
Dim P_h_off As Byte
Dim P_m_off As Byte
Dim Flags As Byte
X1 Alias Flags.0
Xpk1 Alias Flags.1
Xpk2 Alias Flags.2
Xpk3 Alias Flags.2
Auto1 Alias Flags.4
Ls_edit Alias Flags.7
Dim Menu As Byte
'procedury pozycjonowania i wyswietlania
Declare Sub Lcd_temper()
Declare Sub Lcd_w_h_on()
Declare Sub Lcd_w_m_on()
Declare Sub Lcd_w_h_off()
Declare Sub Lcd_w_m_off()
Declare Sub Lcd_p_h_on()
Declare Sub Lcd_p_m_on()
Declare Sub Lcd_p_h_off()
Declare Sub Lcd_p_m_off()
Declare Sub Lcd_t_h()
Declare Sub Lcd_t_m()
Declare Sub Count_time()
Declare Sub Readkey()
Dim Key As Byte
Start Adc
On Timer1 Timer_1_sub
Enable Interrupts
Disable Int0
Disable Int1
Disable Timer0
Enable Timer1
Stop Timer0
Stop Timer1
'#####POCZĄTEK PROGRAMU############################################
Cursor Off
Cls
Lcd "NOWY ELEKTRONIK"
Locate 2 , 1
Lcd "AQUARIUM DRIVER"
Wait 2
Cls
'#######POCZĄTEK PĘTLI GŁÓWNEJ####################################
Readeeprom Temper , 10
Readeeprom W_h_on , 11
Readeeprom W_m_on , 12
Readeeprom W_h_off , 13
Readeeprom W_m_off , 14
Readeeprom P_h_on , 15
Readeeprom P_m_on , 16
Readeeprom P_h_off , 17
Readeeprom P_m_off , 18
If Temper < 10 Or Temper > 50 Then Temper = 30
If W_h_on > 23 Then W_h_on = 12
If W_m_on > 59 Then W_m_on = 30
If W_h_off > 23 Then W_h_off = 12
If W_m_off > 59 Then W_m_off = 30
If P_h_on > 23 Then P_h_on = 12
If P_m_on > 59 Then P_m_on = 30
If P_h_off > 23 Then P_h_off = 12
If P_m_off > 59 Then P_m_off = 30
Call Count_time()
Xpk1 = 0
Xpk2 = 0
Xpk3 = 0
Auto1 = 1
Sekundy = 43200
Fuse = 17221
Fuse_hi = 256 - High(fuse)
Fuse_lo = 256 - Low(fuse)
Count_time = 16
Tcnt1h = Fuse_hi
Tcnt1l = Fuse_lo
Start Timer1
'#a w przerwach między przerwaniami można sobie coś porobić#
Do
'odczyt sekund i zamiana na hh:mm:ss
Locate 1 , 2
Temp_degs = Sekundy
Temp_time = Temp_degs
Temp = Temp_degs Mod 60
S_s = Temp
Temp = Temp_degs / 60
Temp_degs = Temp / 60
H_h = Temp_degs
Temp_degs = Temp Mod 60
M_m = Temp_degs
'wyswietlanie czasu
If H_h < 10 Then Lcd "0";
Lcd H_h ; ":";
If M_m < 10 Then Lcd "0";
Lcd M_m ; ":";
If S_s < 10 Then Lcd "0";
Lcd S_s ; ""
'sprawdzanie czasów
If Temp_time = W_on Then Xpk2 = 1
If Temp_time = W_off Then Xpk2 = 0
If Temp_time = P_on Then Xpk3 = 1
If Temp_time = P_off Then Xpk3 = 0
'odczyt ADC - 50 razy na cykl
Adc_buf = 0
For Licznik = 1 To 50
Adc_reg = Getadc(3)
Adc_buf = Adc_buf + Adc_reg
Next Licznik
'przeliczanie napięcia na temp
Adc_reg = Adc_buf / 50
Temp_degs = Adc_reg * Skok
Temp_degs = Temp_degs / 10
Degs = Temp_degs - 273
'wyświetlanie temperatury
Locate 1 , 12
Lcd "T=" ; Degs ; ""
'sprawdzanie temperatury
If Degs < Temper Then
Xpk1 = 1
Elseif Degs > Temper Then
Xpk1 = 0
End If
'warunek dla przycisku s1
If Auto1 = 0 Then
Xpk1 = 0
End If
'aktywacja przekaźników
Pk1 = Xpk1
Pk2 = Xpk2
Pk3 = Xpk3
'wyświetlanie stanu przekaźników
Locate 2 , 1
Lcd "R1=" ; Xpk1 ; "R2=" ; Xpk2 ; "R3=" ; Xpk3
'obsługa klawiatury
If S1 = 0 Or S2 = 0 Or S3 = 0 Or S4 = 0 Then
Call Readkey()
Ls_edit = 0
Select Case Key
Case 1:
Toggle Auto1
Case 2:
Toggle Xpk2
Case 3:
Toggle Xpk3
Case 4:
Menu = 0
Cls
Lcd "Settings"
Pk1 = 0
Pk2 = 0
Pk3 = 0
Do
Call Readkey()
Select Case Key
Case 1:
Incr Menu
If Menu > 7 Then Menu = 1
Cls
Select Case Menu
Case 1 : Lcd "TempON R1"
Call Lcd_temper()
Case 2:
Lcd "TimeON R2:"
Call Lcd_w_h_on()
Call Lcd_w_m_on()
Locate 1 , 13
X1 = 0
Cursor On
Case 3:
Lcd "TimeOFF R2:"
Call Lcd_w_h_off()
Call Lcd_w_m_off()
Locate 1 , 13
X1 = 0
Case 4:
Lcd "TimeON R3:"
Call Lcd_p_h_on()
Call Lcd_p_m_on()
Locate 1 , 13
X1 = 0
Case 5:
Lcd "TimeOFF R3:"
Call Lcd_p_h_off()
Call Lcd_p_m_off()
Locate 1 , 13
X1 = 0
Case 6:
Lcd "CLOCK TIME:"
Call Lcd_t_h()
Call Lcd_t_m()
Locate 1 , 13
X1 = 0
Case 7:
Lcd "<EXIT>"
Cursor Off
End Select
Case 2:
Select Case Menu
Case 2 To 6
If X1 = 0 Then
X1 = 1
Locate 1 , 16
Elseif X1 = 1 Then
X1 = 0
Locate 1 , 13
End If
Case 7 : Menu = 100
End Select
Case 3:
Select Case Menu
Case 1:
Incr Temper
If Temper > 50 Then Temper = 10
Call Lcd_temper()
Case 2:
If X1 = 0 Then
Incr W_h_on
If W_h_on > 23 Then W_h_on = 0
Call Lcd_w_h_on()
Elseif X1 = 1 Then
Incr W_m_on
If W_m_on > 59 Then W_m_on = 0
Call Lcd_w_m_on()
End If
Case 3:
If X1 = 0 Then
Incr W_h_off
If W_h_off > 23 Then W_h_off = 0
Call Lcd_w_h_off()
Elseif X1 = 1 Then
Incr W_m_off
If W_m_off > 59 Then W_m_off = 0
Call Lcd_w_m_off()
End If
Case 4:
If X1 = 0 Then
Incr P_h_on
If P_h_on > 23 Then P_h_on = 0
Call Lcd_p_h_on()
Elseif X1 = 1 Then
Incr P_m_on
If P_m_on > 59 Then P_m_on = 0
Call Lcd_p_m_on()
End If
Case 5:
Incr P_h_off
If P_h_off > 23 Then P_h_off = 0
Call Lcd_p_h_off()
Elseif X1 = 1 Then
Incr P_m_off
If P_m_off > 59 Then P_m_off = 0
Call Lcd_p_m_off()
End If
Case 6:
Ls_edit = 1
If X1 = 0 Then
Incr H_h
If H_h > 23 Then H_h = 0
Call Lcd_t_h()
Elseif X1 = 1 Then
Incr M_m
If M_m > 59 Then M_m = 0
Call Lcd_t_m()
End If
Case 7 : Menu = 100
End Select
Case 4:
Select Case Menu
Case 1:
Decr Temper
If Temper < 10 Then Temper = 50
Call Lcd_temper()
Case 2:
If X1 = 0 Then
Decr W_h_on
If W_h_on > 23 Then W_h_on = 23
Call Lcd_w_h_on()
Elseif X1 = 1 Then
Decr W_m_on
If W_m_on > 59 Then W_m_on = 59
Call Lcd_w_m_on()
End If
Case 3:
If X1 = 0 Then
Decr W_h_off
If W_h_off > 23 Then W_h_off = 23
Call Lcd_w_h_off()
Elseif X1 = 1 Then
Decr W_m_off
If W_m_off > 59 Then W_m_off = 59
Call Lcd_w_m_off()
End If
Case 4:
If X1 = 0 Then
Decr P_h_on
If P_h_on > 23 Then P_h_on = 23
Call Lcd_p_h_on()
Elseif X1 = 1 Then
Decr P_m_on
If P_m_on > 59 Then P_m_on = 59
Call Lcd_p_m_on()
End If
Case 5:
Decr P_h_off
If P_h_off > 23 Then P_h_off = 23
Call Lcd_p_h_off()
Elseif X1 = 1 Then
Decr P_m_off
If P_m_off > 59 Then P_m_off = 59
Call Lcd_p_m_off()
End If
Case 6:
Ls_edit = 1
If X1 = 0 Then
Decr H_h
If H_h > 23 Then H_h = 23
Call Lcd_t_h()
Elseif X1 = 1 Then
Decr M_m
If M_m > 59 Then M_m = 59
Call Lcd_t_m()
End If
Case 7 : Menu = 100
End Select
End Select
Loop Until Menu = 100
Cls
If Ls_edit = 1 Then
Temp_degs = H_h * 60
Temp_degs = Temp_degs + M_m
Temp_degs = Temp_degs * 60
Stop Timer1
Count_time = 16
Tcnt1h = Fuse_hi
Tcnt1l = Fuse_lo
Sekundy = Temp_degs
Start Timer1
End If
Writeeeprom Temper , 10
Writeeeprom W_h_on , 11
Writeeeprom W_m_on , 12
Writeeeprom W_h_off , 13
Writeeeprom W_m_off , 14
Writeeeprom P_h_on , 15
Writeeeprom P_m_on , 16
Writeeeprom P_h_off , 17
Writeeeprom P_m_off , 18
Call Count_time()
Loop
'koniec pętli głównej################
Sub Lcd_temper()
Locate 1 , 14
If Temper < 10 Then Lcd "0"
Lcd Temper
End Sub
Sub Lcd_w_h_on()
Locate 1 , 12
If W_h_on < 10 Then Lcd "0"
Lcd W_h_on
Locate 1 , 13
End Sub
Sub Lcd_w_m_on()
Locate 1 , 15
If W_m_on < 10 Then Lcd "0"
Lcd W_m_on
Locate 1 , 16
End Sub
Sub Lcd_w_h_off()
Locate 1 , 12
If W_h_off < 10 Then Lcd "0"
Lcd W_h_off
Locate 1 , 13
End Sub
Sub Lcd_w_m_off()
Locate 1 , 15
If W_m_off < 10 Then Lcd "0"
Lcd W_m_off
Locate 1 , 16
End Sub
Sub Lcd_p_h_on()
Locate 1 , 12
If P_h_on < 10 Then Lcd "0"
Lcd P_h_on
Locate 1 , 13
End Sub
Sub Lcd_p_m_on()
Locate 1 , 15
If P_m_on < 10 Then Lcd "0"
Lcd P_m_on
Locate 1 , 16
End Sub
Sub Lcd_p_h_off()
Locate 1 , 12
If P_h_off < 10 Then Lcd "0"
Lcd P_h_off
Locate 1 , 13
End Sub
Sub Lcd_p_m_off()
Locate 1 , 15
If P_m_off < 10 Then Lcd "0"
Lcd P_m_off
Locate 1 , 16
End Sub
Sub Lcd_t_h()
Locate 1 , 12
Lcd H_h
Locate 1 , 13
End Sub
Sub Lcd_t_m()
Locate 1 , 15
Lcd M_m
Locate 1 , 16
End Sub
Sub Count_time()
W_on = W_h_on * 60
W_on = W_on + W_m_on
W_on = W_on * 60
W_off = W_h_off * 60
W_off = W_off + W_m_off
W_off = W_off * 60
P_on = P_h_on * 60
P_on = P_on + P_m_on
P_on = P_on * 60
P_off = P_h_off * 60
P_off = P_off + P_m_off
P_off = P_off * 60
End Sub
Sub Readkey()
Do
Key = 0
If S1 = 0 Then
Waitms 40
Do
Loop Until S1 = 1
Key = 1
Elseif S2 = 0 Then
Waitms 40
Do
Loop Until S2 = 1
Key = 2
Elseif S3 = 0 Then
Waitms 40
Do
Loop Until S3 = 1
Key = 3
Elseif S4 = 0 Then
Waitms 40
Do
Loop Until S4 = 1
Key = 4
End If
Loop Until Key > 0
End Sub
'####################################################3
Timer_1_sub:
Decr Count_time
If Count_time > 0 Then Goto No_1sek
Count_time = 16
Tcnt1h = Fuse_hi
Tcnt1l = Fuse_lo
Toggle Clock
Incr Sekundy
If Sekundy > 86399 Then
Sekundy = 0
End If
No_1sek:
Return
End
'stk200 \ Stk300
'6ck64mS Delay
$crystal = 8000000
Config Lcd = 16 * 2
Portb.1 = 1
Portc.1 = 1
Portc.3 = 0
Portc.5 = 1
Portd.7 = 1
Portd.6 = 1
Portd.5 = 1
'PIN/PORT
#if_sim = 0
'przyciski
S1 Alias Pind.7
S2 Alias Pind.6
S3 Alias Pind.5
S4 Alias Pind.1
#else
'przyciski
S1 Alias Portd.7
S2 Alias Portd.6
S3 Alias Portd.5
S4 Alias Portd.1
#endif
Clock Alias Portc.0
Pk1 Alias Portd.3
Pk2 Alias Portd.4
Pk3 Alias Portb.0
Const Skok = 4883
Dim Adc_reg As Word
Dim Adc_buf As Word
Dim Temper As Byte
Dim Licznik As Byte
Dim Sekundy As Long
Dim Temp As Long
Dim Degs As Integer
Dim W_on As Long
Dim W_off As Long
Dim P_on As Long
Dim P_off As Long
Dim Fuse As Word
Dim Fuse_hi As Byte
Dim Fuse_lo As Byte
Dim S_s As Byte
Dim M_m As Byte
Dim H_h As Byte
Dim W_h_on As Byte
Dim W_m_on As Byte
Dim W_h_off As Byte
Dim W_m_off As Byte
Dim P_h_on As Byte
Dim P_m_on As Byte
Dim P_h_off As Byte
Dim P_m_off As Byte
Dim Flags As Byte
X1 Alias Flags.0
Xpk1 Alias Flags.1
Xpk2 Alias Flags.2
Xpk3 Alias Flags.2
Auto1 Alias Flags.4
Dim Menu As Byte
Dim Key As Byte
Start Adc
Enable Interrupts
Disable Int0
Disable Int1
Disable Timer0
Enable Timer1
Stop Timer0
Stop Timer1
Cursor Off
Cls
Locate 2 , 1
Wait 2
Cls
Call Count_time()
Xpk1 = 0
Xpk2 = 0
Xpk3 = 0
Auto1 = 1
Sekundy = 43200
Fuse = 17221
Count_time = 16
Tcnt1h = Fuse_hi
Tcnt1l = Fuse_lo
Start Timer1
Do
Locate 1 , 2
Temp_degs = Sekundy
S_s = Temp
H_h = Temp_degs
M_m = Temp_degs
'wyswietlanie czasu
Lcd H_h ; ":";
Lcd M_m ; ":";
Lcd S_s ; ""
'sprawdzanie czasów
Adc_buf = 0
Adc_reg = Getadc(3)
Next Licznik
Locate 1 , 12
Xpk1 = 1
Xpk1 = 0
End If
If Auto1 = 0 Then
Xpk1 = 0
End If
Pk1 = Xpk1
Pk2 = Xpk2
Pk3 = Xpk3
Locate 2 , 1
'obsługa klawiatury
Call Readkey()
Ls_edit = 0
Select Case Key
Case 1:
Toggle Auto1
Case 2:
Toggle Xpk2
Case 3:
Toggle Xpk3
Case 4:
Menu = 0
Cls
Lcd "Settings"
Pk1 = 0
Pk2 = 0
Pk3 = 0
Do
Call Readkey()
Select Case Key
Case 1:
Incr Menu
Cls
Select Case Menu
Call Lcd_temper()
Case 2:
Lcd "TimeON R2:"
Call Lcd_w_h_on()
Call Lcd_w_m_on()
Locate 1 , 13
X1 = 0
Cursor On
Case 3:
Lcd "TimeOFF R2:"
Call Lcd_w_h_off()
Call Lcd_w_m_off()
Locate 1 , 13
X1 = 0
Case 4:
Lcd "TimeON R3:"
Call Lcd_p_h_on()
Call Lcd_p_m_on()
Locate 1 , 13
X1 = 0
Case 5:
Lcd "TimeOFF R3:"
Call Lcd_p_h_off()
Call Lcd_p_m_off()
Locate 1 , 13
X1 = 0
Case 6:
Lcd "CLOCK TIME:"
Call Lcd_t_h()
Call Lcd_t_m()
Locate 1 , 13
X1 = 0
Case 7:
Lcd "<EXIT>"
Cursor Off
End Select
Case 2:
Select Case Menu
Case 2 To 6
If X1 = 0 Then
X1 = 1
Locate 1 , 16
Elseif X1 = 1 Then
X1 = 0
Locate 1 , 13
End If
Case 7 : Menu = 100
End Select
Case 3:
Select Case Menu
Case 1:
Incr Temper
Call Lcd_temper()
Case 2:
If X1 = 0 Then
Incr W_h_on
Call Lcd_w_h_on()
Elseif X1 = 1 Then
Incr W_m_on
Call Lcd_w_m_on()
End If
Case 3:
If X1 = 0 Then
Incr W_h_off
Call Lcd_w_h_off()
Elseif X1 = 1 Then
Incr W_m_off
Call Lcd_w_m_off()
End If
Case 4:
If X1 = 0 Then
Incr P_h_on
Call Lcd_p_h_on()
Elseif X1 = 1 Then
Incr P_m_on
Call Lcd_p_m_on()
End If
Case 5:
Incr P_h_off
Call Lcd_p_h_off()
Elseif X1 = 1 Then
Incr P_m_off
Call Lcd_p_m_off()
End If
Case 6:
Ls_edit = 1
If X1 = 0 Then
Incr H_h
Call Lcd_t_h()
Elseif X1 = 1 Then
Incr M_m
Call Lcd_t_m()
End If
Case 7 : Menu = 100
End Select
Case 4:
Select Case Menu
Case 1:
Decr Temper
Call Lcd_temper()
Case 2:
If X1 = 0 Then
Decr W_h_on
Call Lcd_w_h_on()
Elseif X1 = 1 Then
Decr W_m_on
Call Lcd_w_m_on()
End If
Case 3:
If X1 = 0 Then
Decr W_h_off
Call Lcd_w_h_off()
Elseif X1 = 1 Then
Decr W_m_off
Call Lcd_w_m_off()
End If
Case 4:
If X1 = 0 Then
Decr P_h_on
Call Lcd_p_h_on()
Elseif X1 = 1 Then
Decr P_m_on
Call Lcd_p_m_on()
End If
Case 5:
Decr P_h_off
Call Lcd_p_h_off()
Elseif X1 = 1 Then
Decr P_m_off
Call Lcd_p_m_off()
End If
Case 6:
Ls_edit = 1
If X1 = 0 Then
Decr H_h
Call Lcd_t_h()
Elseif X1 = 1 Then
Decr M_m
Call Lcd_t_m()
End If
Case 7 : Menu = 100
End Select
End Select
Cls
If Ls_edit = 1 Then
Stop Timer1
Count_time = 16
Tcnt1h = Fuse_hi
Tcnt1l = Fuse_lo
Sekundy = Temp_degs
Start Timer1
End If
Call Count_time()
Loop
Sub Lcd_temper()
Locate 1 , 14
Lcd Temper
End Sub
Sub Lcd_w_h_on()
Locate 1 , 12
Lcd W_h_on
Locate 1 , 13
End Sub
Sub Lcd_w_m_on()
Locate 1 , 15
Lcd W_m_on
Locate 1 , 16
End Sub
Sub Lcd_w_h_off()
Locate 1 , 12
Lcd W_h_off
Locate 1 , 13
End Sub
Sub Lcd_w_m_off()
Locate 1 , 15
Lcd W_m_off
Locate 1 , 16
End Sub
Sub Lcd_p_h_on()
Locate 1 , 12
Lcd P_h_on
Locate 1 , 13
End Sub
Sub Lcd_p_m_on()
Locate 1 , 15
Lcd P_m_on
Locate 1 , 16
End Sub
Sub Lcd_p_h_off()
Locate 1 , 12
Lcd P_h_off
Locate 1 , 13
End Sub
Sub Lcd_p_m_off()
Locate 1 , 15
Lcd P_m_off
Locate 1 , 16
End Sub
Sub Lcd_t_h()
Locate 1 , 12
Lcd H_h
Locate 1 , 13
End Sub
Sub Lcd_t_m()
Locate 1 , 15
Lcd M_m
Locate 1 , 16
End Sub
Sub Count_time()
W_on = W_h_on * 60
W_on = W_on * 60
W_off = W_off * 60
P_on = P_h_on * 60
P_on = P_on * 60
P_off = P_off * 60
End Sub
Sub Readkey()
Do
Key = 0
If S1 = 0 Then
Waitms 40
Do
Loop Until S1 = 1
Key = 1
Elseif S2 = 0 Then
Waitms 40
Do
Loop Until S2 = 1
Key = 2
Elseif S3 = 0 Then
Waitms 40
Do
Loop Until S3 = 1
Key = 3
Elseif S4 = 0 Then
Waitms 40
Do
Loop Until S4 = 1
Key = 4
End If
Loop Until Key > 0
End Sub
Timer_1_sub:
Decr Count_time
Count_time = 16
Tcnt1h = Fuse_hi
Tcnt1l = Fuse_lo
Toggle Clock
Incr Sekundy
Sekundy = 0
End If
No_1sek:
Return
End
