[root@localhost seba]# dmesg
Bootdata ok (command line is BOOT_IMAGE=linux root=1607 resume=/dev/hdc8 splash=silent)
Linux version 2.6.17-5mdv (rtp@ramanujan.mandriva.com) (gcc version 4.1.1 20060724 (prerelease) (4.1.1-3mdk)) #1 SMP Wed Sep 13 14:28:02 EDT 2006
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001ffc0000 (usable)
BIOS-e820: 000000001ffc0000 - 000000001ffd0000 (ACPI data)
BIOS-e820: 000000001ffd0000 - 0000000020000000 (ACPI NVS)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000ff7c0000 - 0000000100000000 (reserved)
DMI 2.3 present.
ACPI: RSDP (v000 ACPIAM ) @ 0x00000000000f9ed0
ACPI: RSDT (v001 A M I OEMRSDT 0x08000523 MSFT 0x00000097) @ 0x000000001ffc0000
ACPI: FADT (v002 A M I OEMFACP 0x08000523 MSFT 0x00000097) @ 0x000000001ffc0200
ACPI: MADT (v001 A M I OEMAPIC 0x08000523 MSFT 0x00000097) @ 0x000000001ffc0390
ACPI: OEMB (v001 A M I OEMBIOS 0x08000523 MSFT 0x00000097) @ 0x000000001ffd0040
ACPI: DSDT (v001 A0128 A0128003 0x00000003 INTL 0x02002026) @ 0x0000000000000000
Scanning NUMA topology in Northbridge 24
Number of nodes 1
Node 0 MemBase 0000000000000000 Limit 000000001ffc0000
NUMA: Using 63 for the hash shift.
Using node hash shift of 63
Bootmem setup node 0 0000000000000000-000000001ffc0000
On node 0 totalpages: 127882
DMA zone: 2705 pages, LIFO batch:0
DMA32 zone: 125177 pages, LIFO batch:31
Nvidia board detected. Ignoring ACPI timer override.
ACPI: PM-Timer IO Port: 0x4008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 15:12 APIC version 16
ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 1, version 17, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: BIOS IRQ0 pin2 override ignored.
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
ACPI: IRQ9 used by override.
ACPI: IRQ14 used by override.
ACPI: IRQ15 used by override.
Setting APIC routing to physical flat
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 30000000 (gap: 20000000:dec00000)
Checking aperture...
CPU 0: aperture @ e0000000 size 256 MB
SMP: Allowing 1 CPUs, 0 hotplug CPUs
Built 1 zonelists
Kernel command line: BOOT_IMAGE=linux root=1607 resume=/dev/hdc8 splash=silent
bootsplash: silent mode.
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 16384 bytes)
time.c: Using 3.579545 MHz WALL PM GTOD PIT/TSC timer.
time.c: Detected 1808.818 MHz processor.
Console: colour dummy device 80x25
Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
Memory: 510660k/524032k available (2696k kernel code, 12984k reserved, 990k data, 220k init)
Calibrating delay using timer specific routine.. 3619.88 BogoMIPS (lpj=7239769)
Mount-cache hash table entries: 256
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 128K (64 bytes/line)
CPU 0/0(1) -> Node 0 -> Core 0
SMP alternatives: switching to UP code
Freeing SMP alternatives: 24k freed
checking if image is initramfs... it is
Freeing initrd memory: 360k freed
ACPI: Looking for DSDT in initramfs... error, file /DSDT.aml not found.
Using local APIC timer interrupts.
result 12561245
Detected 12.561 MHz APIC timer.
Brought up 1 CPUs
testing NMI watchdog ... OK.
migration_cost=0
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: Using configuration type 1
ACPI: Subsystem revision 20060127
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
ACPI: Power Resource [ISAV] (on)
ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *11
ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKE] (IRQs 16 17 18 19) *11
ACPI: PCI Interrupt Link [LUS0] (IRQs 20 21 22) *3
ACPI: PCI Interrupt Link [LUS1] (IRQs 20 21 22) *9
ACPI: PCI Interrupt Link [LUS2] (IRQs 20 21 22) *10
ACPI: PCI Interrupt Link [LKLN] (IRQs 20 21 22) *11
ACPI: PCI Interrupt Link [LAUI] (IRQs 20 21 22) *9
ACPI: PCI Interrupt Link [LKMO] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [LKSM] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [LTID] (IRQs 20 21 22) *0
ACPI: PCI Interrupt Link [LTIE] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [LATA] (IRQs 20 21 22) *14
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
agpgart: Detected AGP bridge 0
agpgart: Setting up Nforce3 AGP.
agpgart: AGP aperture is 256M @ 0xe0000000
PCI-DMA: Disabling IOMMU.
PCI: Bridge: 0000:00:0b.0
IO window: disabled.
MEM window: fc900000-fe9fffff
PREFETCH window: cc800000-dc7fffff
PCI: Bridge: 0000:00:0e.0
IO window: b000-bfff
MEM window: fea00000-feafffff
PREFETCH window: disabled.
PCI: Setting latency timer of device 0000:00:0e.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 3, 32768 bytes)
TCP established hash table entries: 16384 (order: 6, 262144 bytes)
TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
IA32 emulation $Id: sys_ia32.c,v 1.32 2002/03/24 13:02:28 ak Exp $
audit: initializing netlink socket (disabled)
audit(1168707720.352:1): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
vesafb: framebuffer at 0xd0000000, mapped to 0xffffc20000180000, using 3750k, total 32768k
vesafb: mode is 800x600x16, linelength=1600, pages=3
vesafb: scrolling: redraw
vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
bootsplash 3.1.6-2004/03/31: looking for picture...<6> silentjpeg size 124058 bytes,<6>...found (800x600, 124010 bytes, v3).
Console: switching to colour frame buffer device 93x31
fb0: VESA VGA frame buffer device
Real Time Clock Driver v1.12ac
Linux agpgart interface v0.101 (c) Dave Jones
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 32000K size 1024 blocksize
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
NFORCE3-250: IDE controller at PCI slot 0000:00:08.0
NFORCE3-250: chipset revision 162
NFORCE3-250: not 100% native mode: will probe irqs later
NFORCE3-250: 0000:00:08.0 (rev a2) UDMA133 controller
ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xffa8-0xffaf, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0...
hda: _NEC DVD_RW ND-4550A, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: SAMSUNG SP0802N, ATA DISK drive
ide1 at 0x170-0x177,0x376 on irq 15
hdc: max request size: 512KiB
hdc: 156368016 sectors (80060 MB) w/2048KiB Cache, CHS=16383/255/63, UDMA(33)
hdc: cache flushes supported
hdc: hdc1 hdc2 < hdc5 hdc6 hdc7 hdc8 >
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: bitmap version 4.39
TCP bic registered
ACPI wakeup devices:
PS2K PS2M UAR1 USB0 MAC USB1 USB2 P0P1
ACPI: (supports S0 S1 S3 S4 S5)
BIOS EDD facility v0.16 2004-Jun-25, 1 devices found
Freeing unused kernel memory: 220k freed
input: AT Translated Set 2 keyboard as /class/input/input0
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting. Commit interval 5 seconds
EXT3-fs: hdc7: orphan cleanup on readonly fs
ext3_orphan_cleanup: deleting unreferenced inode 360613
ext3_orphan_cleanup: deleting unreferenced inode 329759
EXT3-fs: hdc7: 2 orphan inodes deleted
EXT3-fs: recovery complete.
input: ImPS/2 Generic Wheel Mouse as /class/input/input1
EXT3-fs: mounted filesystem with ordered data mode.
ts: Compaq touchscreen protocol output
usbcore: registered new driver usbfs
usbcore: registered new driver hub
ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
ACPI: PCI Interrupt Link [LUS0] enabled at IRQ 22
GSI 16 sharing vector 0xB1 and IRQ 16
ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LUS0] -> GSI 22 (level, low) -> IRQ 177
PCI: Setting latency timer of device 0000:00:02.0 to 64
ohci_hcd 0000:00:02.0: OHCI Host Controller
ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
ohci_hcd 0000:00:02.0: irq 177, io mem 0xfebfd000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 4 ports detected
ACPI: PCI Interrupt Link [LUS1] enabled at IRQ 21
GSI 17 sharing vector 0xB9 and IRQ 17
ACPI: PCI Interrupt 0000:00:02.1[b] -> Link [LUS1] -> GSI 21 (level, low) -> IRQ 185
PCI: Setting latency timer of device 0000:00:02.1 to 64
ohci_hcd 0000:00:02.1: OHCI Host Controller
ohci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:02.1: irq 185, io mem 0xfebfe000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 4 ports detected
usb 1-1: new full speed USB device using ohci_hcd and address 2
ACPI: PCI Interrupt Link [LUS2] enabled at IRQ 20
GSI 18 sharing vector 0xC1 and IRQ 18
ACPI: PCI Interrupt 0000:00:02.2[C] -> Link [LUS2] -> GSI 20 (level, low) -> IRQ 193
PCI: Setting latency timer of device 0000:00:02.2 to 64
ehci_hcd 0000:00:02.2: EHCI Host Controller
ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 3
ehci_hcd 0000:00:02.2: debug port 1
PCI: cache line size of 64 is not supported by device 0000:00:02.2
ehci_hcd 0000:00:02.2: irq 193, io mem 0xfebffc00
ehci_hcd 0000:00:02.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 8 ports detected
usb 1-1: device descriptor read/8, error -110
usb 3-2: new high speed USB device using ehci_hcd and address 3
usb 3-2: configuration #1 chosen from 1 choice
ohci_hcd 0000:00:02.0: wakeup
SCSI subsystem initialized
Initializing USB Mass Storage driver...
usb 1-1: new full speed USB device using ohci_hcd and address 4
usb 1-1: configuration #1 chosen from 1 choice
powernow-k8: Found 1 AMD Athlon 64 / Opteron processors (version 1.60.2)
powernow-k8: 0 : fid 0x2 (1000 MHz), vid 0x12 (1100 mV)
powernow-k8: 1 : fid 0xa (1800 MHz), vid 0x6 (1400 mV)
cpu_init done, current fid 0xa, vid 0x6
scsi0 : SCSI emulation for USB Mass Storage devices
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 3
usb-storage: waiting for device to settle before scanning
drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 4 if 0 alt 0 proto 2 vid 0x03F0 pid 0x0904
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
device-mapper: 4.6.0-ioctl (2006-02-17) initialised: dm-devel@redhat.com
EXT3 FS on hdc7, internal journal
libata version 1.20 loaded.
sata_nv 0000:00:0a.0: version 0.8
ACPI: PCI Interrupt Link [LTID] BIOS reported IRQ 0, using IRQ 22
ACPI: PCI Interrupt Link [LTID] enabled at IRQ 22
ACPI: PCI Interrupt 0000:00:0a.0[A] -> Link [LTID] -> GSI 22 (level, low) -> IRQ 177
PCI: Setting latency timer of device 0000:00:0a.0 to 64
ata1: SATA max UDMA/133 cmd 0x9F0 ctl 0xBF2 bmdma 0xC800 irq 177
ata2: SATA max UDMA/133 cmd 0x970 ctl 0xB72 bmdma 0xC808 irq 177
ata1: SATA link down (SStatus 0)
scsi1 : sata_nv
ata2: SATA link down (SStatus 0)
scsi2 : sata_nv
Vendor: Kingston Model: DataTraveler 2.0 Rev: 1.04
Type: Direct-Access ANSI SCSI revision: 00
usb-storage: device scan complete
SCSI device sda: 501760 512-byte hdwr sectors (257 MB)
sda: Write Protect is off
sda: Mode Sense: 23 00 00 00
sda: assuming drive cache: write through
sda: unknown partition table
sd 0:0:0:0: Attached scsi removable disk sda
sd 0:0:0:0: Attached scsi generic sg0 type 0
Adding 1052216k swap on /dev/hdc8. Priority:-1 extents:1 across:1052216k
NTFS driver 2.1.27 [Flags: R/O DEBUG MODULE].
NTFS volume version 3.1.
Supermount version 2.0.4 for kernel 2.6
loop: loaded (max 8 devices, max 1 partitions per device)
hda: ATAPI 48X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
Netfilter messages via NETLINK v0.30.
ip_conntrack version 2.4 (2047 buckets, 16376 max) - 304 bytes per conntrack
Removing netfilter NETLINK layer.
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
end_request: I/O error, dev fd0, sector 0
ACPI: PCI Interrupt Link [LAUI] enabled at IRQ 21
ACPI: PCI Interrupt 0000:00:06.0[A] -> Link [LAUI] -> GSI 21 (level, low) -> IRQ 185
PCI: Setting latency timer of device 0000:00:06.0 to 64
intel8x0_measure_ac97_clock: measured 54652 usecs
intel8x0: clocking to 46984
NET: Registered protocol family 17
forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.54.
ACPI: PCI Interrupt Link [LKLN] enabled at IRQ 20
ACPI: PCI Interrupt 0000:00:05.0[A] -> Link [LKLN] -> GSI 20 (level, low) -> IRQ 193
PCI: Setting latency timer of device 0000:00:05.0 to 64
eth0: forcedeth.c: subsystem: 01043:80a7 bound to 0000:00:05.0
eth0: no link during initialization.
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
ADDRCONF(NETDEV_UP): eth0: link is not ready
IPv6 over IPv4 tunneling driver
ip_tables: (C) 2000-2006 Netfilter Core Team
parport0: PC-style at 0x378 (0x778) [PCSPP,TRISTATE]
parport0: irq 7 detected
lp0: using parport0 (polling).
lp0: console ready
ppdev: user-space parallel port driver
ppdev0: registered pardevice
ppdev0: unregistered pardevice
FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
ClusterIP Version 0.8 loaded successfully
ipt_recent v0.3.1: Stephen Frost <sfrost@snowman.net>. http://snowman.net/projects/ipt_recent/
netfilter PSD loaded - (c) astaro AG
IFWLOG: register target
bootsplash 3.1.6-2004/03/31: looking for picture...<6>...found (800x600, 12533 bytes, v3).
bootsplash: status on console 0 changed to on
bootsplash: status on console 1 changed to on
bootsplash: status on console 2 changed to on
bootsplash: status on console 3 changed to on
bootsplash: status on console 4 changed to on
bootsplash: status on console 5 changed to on
ieee80211_crypt: registered algorithm 'NULL'
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
acx_pci: Unknown parameter `use_eth_name'
acx: compiled to use 32bit I/O access. I/O timing issues might occur, such as non-working firmware upload. Report them
running on a little-endian CPU
PCI module v0.4.7 initialized, waiting for cards to probe...
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 19
GSI 19 sharing vector 0xC9 and IRQ 19
ACPI: PCI Interrupt 0000:02:0a.0[A] -> Link [LNKA] -> GSI 19 (level, low) -> IRQ 201
acx: found ACX100-based wireless network card at 0000:02:0a.0, irq:201, phymem1:0xFEAFF000, phymem2:0xFEAE0000, mem1:0xffffc2000007a000, mem1_size:4096, mem2:0xffffc20000160000, mem2_size:65536
initial debug setting is 0x000A
using IRQ 201
requesting firmware image 'tiacx100c0D'
acx: firmware image 'tiacx100c0D' was not provided. Check your hotplug scripts
requesting firmware image 'tiacx100'
acx: firmware image 'tiacx100' was not provided. Check your hotplug scripts
acx: reset_dev() FAILED
ACPI: PCI interrupt for device 0000:02:0a.0 disabled
acx_pci: probe of 0000:02:0a.0 failed with error -5
