  • #1 337373
    klostazy
    Gdzie mogę znaleść opis wtyczki euro do telewizora, chodzi mi o wszystkie piny.
  • #4 337579
    Hrabol
    tak ogolnie wpisz w onecie hwb i masz pelno strron z roznymi opisami kabli przejsciowek wtyczek i innych ciekawych rzeczy jak magistrale procki itp itd
  • #5 337590
    TadeuszZ
    SCART - EURO
    (at the video/TV)
    (at the cable)
    21 PIN SCART FEMALE at the Video/TV.
    21 PIN SCART MALE at the Cable.
    Pin Name Description Signal Level Impedance
    1 AOR Audio Out Right 0.5 V rms <1k ohm
    2 AIR Audio In Right 0.5 V rms >10k ohm
    3 AOL Audio Out Left + Mono 0.5 V rms <1k ohm
    4 AGND Audio Ground
    5 B GND RGB Blue Ground
    6 AIL Audio In Left + Mono 0.5 V rms >10k ohm
    7 B RGB Blue In 0.7 V 75 ohm
    8 SWTCH Audio/RGB switch / 16:9 0-2 V=TV, 5-8 V=WideScreen, 9.5-12 V=AV Mode >10 kohm
    9 G GND RGB Green Ground
    10 CLKOUT Data 2: Clockpulse Out (Unavailable ??)
    11 G RGB Green In 0.7 V 75 ohm
    12 DATA Data 1: Data Out (Unavailable ??)
    13 R GND RGB Red Ground
    14 DATAGND Data Ground
    15 R RGB Red In / Chrominance 0.7 V (Chrom.: 0.3 V burst) 75 ohm
    16 BLNK Blanking Signal 1-3 V=RGB, 0-0.4 V=Composite 75 ohm
    17 VGND Composite Video Ground
    18 BLNKGND Blanking Signal Ground
    19 VOUT Composite Video Out 1 V 75 ohm
    20 VIN Composite Video In / Luminance 1 V 75 ohm
    21 SHIELD Ground/Shield (Chassis)
