Ma ktoś może jakiś kodzik w VB umożliwiający odczyt temeperatury z DS1820?
Czy wolisz polską wersję strony elektroda?
Nie, dziękuję Przekieruj mnie tamOption Explicit
' clsComReader
' 1. instantiate
' 2. set timer & (optional) Interval
' 3. set comm (that will start the first measurement)
' 4. handle GotData or read Measurement & MeasurementTime
' does one measurement only when interval not set or set to 0
' you can force next measurement calling RequestMeasurement
' use GotData callback or wait for MeasurementTime <> "" to get the first value
Public Event GotData()
Private Const MEASUREMENT_DELAY = 1400
Private buffer As Variant
Private mTemperature As String
Private mMeasurementTime As Date
Private mInterval As Long ' milliseconds
Private mSendRequest As Boolean
Private WithEvents otimer As Timer
Private WithEvents oComm As MSComm
Public Property Set Timer(ByVal Value As Timer)
Set otimer = Value
End Property
Public Property Set CommControl(ByVal Value As MSComm)
Set oComm = Value
' 9600 baud, no parity, 8 data, and 1 stop bit.
oComm.Settings = "9600,N,8,1"
' Tell the control to read entire buffer when Input is used.
oComm.InputLen = 0
oComm.DTREnable = False
oComm.PortOpen = True
RequestMeasurement
End Property
Public Property Let Interval(ByVal Value As Long)
If Value > 0 Then
mInterval = Value - MEASUREMENT_DELAY
If mInterval < 0 Then
mInterval = 10
End If
Else
mInterval = 0
End If
End Property
Public Property Get Interval() As Long
If mInterval > 0 Then
Interval = mInterval + MEASUREMENT_DELAY
Else
Interval = 0
End If
End Property
Public Property Get Measurement() As String
Measurement = mTemperature
End Property
Public Property Get MeasurementTime() As String
MeasurementTime = mMeasurementTime
End Property
Public Sub RequestMeasurement()
otimer.Interval = MEASUREMENT_DELAY
oComm.Output = buffer
mSendRequest = False
End Sub
Private Sub Class_Initialize()
buffer = "D0" & vbCr
mInterval = 0
End Sub
Private Sub oCom_OnComm()
End Sub
Private Sub oTimer_Timer()
If mSendRequest Then
RequestMeasurement
Else
otimer.Interval = mInterval
mMeasurementTime = Now()
mTemperature = oComm.Input
mSendRequest = True
RaiseEvent GotData
End If
End Sub
Private Sub oComm_OnComm()
Select Case oComm.CommEvent
' Handle each event or error by placing
' code below each case statement
' Errors
Case comEventBreak ' A Break was received.
' Me.Label1.Caption = "br"
Case comEventFrame ' Framing Error
' Me.Label1.Caption = "fr"
Case comEventOverrun ' Data Lost.
' Me.Label1.Caption = "ov"
Case comEventRxOver ' Receive buffer overflow.
' Me.Label1.Caption = "rx"
Case comEventRxParity ' Parity Error.
' Me.Label1.Caption = "pa"
Case comEventTxFull ' Transmit buffer full.
' Me.Label1.Caption = "full"
Case comEventDCB ' Unexpected error retrieving DCB]
' Me.Label1.Caption = "dcb"
' Events
Case comEvCD ' Change in the CD line.
'' Me.Label1.Caption = "cd " & MSComm1.Input
Case comEvCTS ' Change in the CTS line.
'' Me.Label1.Caption = "cts " & MSComm1.Input
Case comEvDSR ' Change in the DSR line.
'' Me.Label1.Caption = "dts"
Case comEvRing ' Change in the Ring Indicator.
'' Me.Label1.Caption = "ring"
Case comEvReceive ' Received RThreshold # of
' chars.
' Me.Label1.Caption = "R " & MSComm1.Input
Case comEvSend ' There are SThreshold number of
' characters in the transmit
' buffer.
' Me.Label1.Caption = "send"
Case comEvEOF ' An EOF charater was found in
' the input stream
' Me.Label1.Caption = "E " & MSComm1.Input
End Select
End Sub
Private Sub Class_Terminate()
otimer.Interval = 0
oComm.PortOpen = False
Set otimer = Nothing
Set oComm = Nothing
End Sub
