Poszukuje procedur do obsługi AVR w trybie slave(raczej TWI)
Balu 17 Wrz 2007 16:12 1544 2
  • #1 4292620
    Balu
    Ocena: 48
    Witam, jeżeli ktoś posiada dostęp do wyżej wymienionych procedur, prosiłbym o podzielenie się:)
    Albo pokierowanie na konkretny adres - szukajka i google nic konkretnego dla mnie nie znajdują:(
    Procedurki najchętniej ASM, ale C też przerobię na własne potrzeby.
    Pozdrawiam Łukasz.
    xbaj
    Ocena: 16
    Proszę:
    static void I2C_Slave_Initialise(u8_t I2C_ownAddress)
    	TWAR = I2C_ownAddress;			// set own I2C slave address
    	TWAMR = MASK_ADDRESS; //<<I2C_ADR_BITS;
    	// I2C Interface enabled
    	TWCR = (1<<TWEN)|
    	// enable I2C Interupt and clear the flag
    	(1<<TWIE)|(1<<TWINT)|
    	// prepare to ACK next time the Slave is addressed
    	(1<<TWEA)|(0<<TWSTA)|(0<<TWSTO)|
    	(0<<TWWC);
    static u8_t Process_I2C(void)
    	u8_t I2C_WriteCompleted = 0;
    	if(TWCR & (1<<TWINT)) {
    	switch (TWSR & 0xF8)
    		// own SLA+R has been received; ACK has been returned
    		case I2C_STX_ADR_ACK:
    			I2C_BufferIndex = 0;
    			SlaveAddress = TWDR & 0xFE;
    			if(SlaveAddress == EEPROM_I2C_SLAVE_ADDRESS) {
    				TWDR = EEPROM_read();
    			} else if(SlaveAddress == CONTROL_I2C_SLAVE_ADDRESS) {
    				TWDR = REGS_Read();
    			TWCR = (1<<TWEN)|
    			// Enable I2C Interupt and clear the flag to send byte
    			(0<<TWWC);
    			break;
    		// Data byte in TWDR has been transmitted; ACK has been received
    		case I2C_STX_DATA_ACK:
    				TWDR = REGS_Read();
    			TWCR = (1<<TWEN)|
    			(0<<TWWC);
    			break;
    		// Data byte in TWDR has been transmitted; NACK has been received.
    		case I2C_STX_DATA_NACK:
    			// Put I2C Transceiver in passive mode.
    			// Enable I2C-interface and release I2C pins
    			TWCR = (1<<TWEN)|
    			// disable Interupt
    			// do not acknowledge on any new requests
    			(0<<TWWC);
    			break;
    		// General call address has been received; ACK has been returned
    		case I2C_SRX_GEN_ACK:
    		// Own SLA+W has been received ACK has been returned
    		case I2C_SRX_ADR_ACK:
    			SlaveAddress = TWDR;
    			// Set buffer pointer to first data location
    			// Reset the I2C Interupt to wait for a new event.
    			TWCR = (1<<TWEN)|
    			// enable I2C Interupt and clear the flag to send byte
    			// expect ACK on this transmission
    			(0<<TWWC);
    			break;
    		case I2C_SRX_ADR_DATA_ACK:
    		case I2C_SRX_GEN_DATA_ACK:
    				u8_t tmp = TWDR;
    				TWCR = (1<<TWEN)|
    				// enable I2C Interupt and clear the interrupt flag
    				// send ACK after next reception
    				(0<<TWWC);
    					I2C_Buffer[I2C_BufferIndex++] = tmp;
    					if(I2C_BufferIndex == 0) {
    						REGS_SetCurrentAddress(tmp);
    					} else {
    						REGS_WriteRegister(tmp);
    					I2C_BufferIndex++;
    			break;
    		// A STOP condition or repeated START condition has been
    		// received while still addressed as Slave
    		case I2C_SRX_STOP_RESTART:
    			TWCR = (1<<TWEN)|
    			(0<<TWWC);
    			if(I2C_BufferIndex && (SlaveAddress == EEPROM_I2C_SLAVE_ADDRESS)){
    				I2C_WriteCompleted = 1;
    			break;
    		case I2C_SRX_ADR_DATA_NACK:
    		case I2C_SRX_GEN_DATA_NACK:
    		// Last data byte in TWDR has been transmitted (TWEA = 0);
    		// ACK has been received
    		case I2C_STX_DATA_ACK_LAST_BYTE:
    		case I2C_BUS_ERROR:
    		default:
    			// Store TWSR and automatically sets clears noErrors bit.
    			// Reset I2C Interface
    			TWCR = (1<<TWEN)|
    			(0<<TWWC);
    			break;
    	return I2C_WriteCompleted;
    W kodzie pozostałości od zapisu/odczytu z EEPROM należy usunąć ;) -zostało z mojego projektu.
