Naprawde fajna zmywarka
mam conajmiej 50 biuletynow online na jej temat co 2 dotyczy problemow z optyka pompa itd... oto skrocona ich versja.
1 . - Drain pump runs permanently
NTC defect or out of tolerance, or connection at the control board is not sufficient.
Indication for customer: Start LED flashes
Indication in Service test program:
PS1 flashes, or F1 flashes at the 7-segment-display
2. - Drain pump runs permanently
Water in drip tray
Indication for customer: Alarm LED flashes / Start LED flashes
Indication in service test program: PS2 flashes, or F2 at the 7-segment-display
3. - Drain pump runs with interruption
Reason: water runs in, permanently
Indication f. customer: Start LED flashes / Alarm LED flashes (water in drip tray)
Indication f. service test program: PS1 + PS3 flashes, or F2 at the 7-segment-display
i jeszcze jedno:
1. Check if the appliance is empty
2. If the appliance is empty (main switch ON), check on the main plug the isolation resistance both poles to grounding. Reading should be higher than 500MOhm. If any failure occurs the value is approx. 10 times lower than 500MOhms.
3. After this test, open the bottom tray and release the two cables from the motor capacitor and check the capacitor in the same way as described before. If the capacitor is ok, check the circulation pump motor on all connectors to the grounding. The isolation value for capacitor and motor should be approx. 500Mohm.
4. Change the defective component
5. Usually it is enough to turn the main plug (to change the polarity) as a solution in the interim
dzisiaj naprawialem ta usterke w whirlpoolowskim odpowiedniku... po prostu cisnieniowy czujnik zapchany byl brudem... ciepla woda i szczotka zalatwily sprawe.
a tu servisowka do twojego cuda:
http://artm.pl/4033.pdf
