Mam do was prośbę, szukam kogoś kto mi obliczy skrzynkę pod ten głośnik(projekt), ja nie biorę się za to bo nie bardzo kumam , chodzi mi o skrzynkę do db drag , czyli pewnie strojenie z 50-60hz, i pewnie br, jeśli ktoś ma czasu trochę to bym prosił szanownych kolegów
Poniżej Parametry:
Model Number ORION H2 10.4
Thiele/Small Parameters
Fs (free-air resonance, Hz) 39.06
Vas (equivalent compliance, cu. ft.) 0.37
Vas (equivalent compliance, liters) 10.7
Qms (Q, mechanical) 6.73
Qes (Q, electrical) 0.68
Qts (total driver Q) 0.62
Re (DC resistance, ohms) 7.05
Z (nominal impedance, ohms) 8
Le (inductance, mh) 2.6
Efficiency (2.83v/1M, dB) 82
Xmax (one way linear excursion, in.) 1.14
Xmax (one way linear excursion, mm) 29
Pe (continuous power handling, watts) 2000
Peak power handling (music, watts) 2500
Mms (total moving mass, grams) 186.63
Cms (mechanical compliance, mm/N) 79
Bl (motor strength, Tesla-M) 21.51
Sd (effective radiating area, sq. m.) 0.029
Sd (effective radiating area, sq. in.) 44.95
Frequency range (Hz) 30-2.5k
Energy Bandwidth Product (EBP) 55.41
Model Number H2 10.4
Driver Physical Dimension
Speaker Displacement (cu. ft) 0.28
Mounting hole diameter (inches) 9.25
Mounting depth (inches *) 7.5
Basket diameter (inches) 11
Recommended Enclosures
1500 watt Sealed enclosure (cu. ft.) 0.66
2500 watt Sealed enclosure (cu. ft.) 0.33
1500 watt Vented enclosure (cu. ft.) 0.65
Port tuning frequency (Hz) 30
Port diameter (inside, in.) 3
Equivalent square port (in.) 2.65x2.65
Port length (in.) 24.7
2500 watt Vented enclosure (cu. ft.) 0.5
Port tuning frequency (Hz) 34
Port length (in.) 27.5
Poniżej Parametry:
