DDS VFO with AD9850 / AD9851 and PIC16F877A
vu3wij 02 Paź 2007 21:30 11163 13
  • DDS VFO with AD9850 / AD9851 and PIC16F877A
    Hi
    I Have successfully completed a DDS with the following facilities. It uses Mcrocontroller PIC16F877A and AD 9850/9851 DDS chip. The main facility in this DDS VFO is any settings including chip type and DDS clock can be changed even after programming the Microcontroller CHIP.
    1) DUAL VFO, that is VFO A, VFO B and A=B facilities.
    2) UP to 50 RX frequency storage on MEMORY.
    3) The Software allows 2 modes of operation,
    a) VFO MODE, where the encoder is used to adjust the frequency.
    While in this mode, VFO A or B is displayed on the top line of the LCD.
    b) MEMORY MODE, where the encoder is used to select a previously saved frequency. While in this mode, MEM is displayed on the top line of the LCD.
    4) KEYPAD Frequency entry and additional 7 Press buttons for other functions.
    The remaining Functions included in the KEYPAD itself.
    5) UP/DOWN fast search in three different steps using KEYPAD which is user selective.
    6) SCAN and quick UP/DOWN search in three different steps with auto Repeat on PTT.
    7) Frequencies are entered in MHz, the * is used to enter a decimal point,
    and the # is used to ENTER the completed frequency.
    If the first digit entered is the #, the number entered will be negative.
    8) S- Meter reading from S0 to S9+40db in logarithmic db range.
    9) Variable rate tuning to use the cheep mechanical encoder.
    10) Step size can be changed from 1Hz to MHz range.
    11) RIT facility.
    12) VFO copy to MEMORY and from MEMORY to any VFO (A/B) facility.
    13) AM/LSB/USB/CW modes Operation with PIC pin outputs for switching.
    14) Allows -Ve and +Ve IF OFFESTS. Offset frequency = any value from min RX frequency to Max 999MHz
    15) 10 RX BANDPASS filter selection for RX coverage from 1.5MHz to 30MHz. Usefull to set up an All band RX.
    16) BAND PASS filter switching selectivity 1Hz and 1ms switching speed, which allows cross band Operation.
    17) CW OFFSET adds to TX Frequency when transmitting thus avoids modulated CW.
    18) Save to MEMORY and Copy from MEMORY functions.
    19) Scan VFO frequency and Scan MEMORY facility
    20) Time out function for ignoring any wrong entry in system settings.
    21) Auto repeat function for respective keys.
    22) Display Multiplier Option to use with VHF rigs
    23) Menu screen allows user to change any settings in the setup screen.
    24) All settings can be changed in the SETUP screen at any time even when the DDS is in working mode including DDS chip type and Reference Clock.
    25) LBS/USB/CW Crystal switching (USB is treated as CW).
    26) CW OFFSET adds to TX Frequency when transmitting thus avoids modulated CW.
    http://img184.imageshack.us/my.php?image=newimage11ry0.jpg
    http://img180.imageshack.us/my.php?image=newimage12oi3.jpg
    Interested homebrewers may Email me for Circuit and other details.
    DDS PCB ( Double sided PTH, FR4 grade, SMOBC,HAL,BBT, size = 7.5cm*15cm ) + KEYPAD PCB + PIC16F877A programmed available
    KEYPAD Pcb is 6.5cm*13cm glass epoxy.
    Each PCB set carries all the circuits and operating instructions.
    SHAJI.
    vu3wij
    vu3wij napisał 1 postów o ocenie 2. Mieszka w mieście POLISH. Jest z nami od 2007 roku.
  • #2 4343384
    Pth
    You shouldn't start two identical topics. Erase the second one in your own language. Let stay this one in english.
    I think that your project is fine. The PCB is very good and the casing looks very nice.
    Nice work.
    Sorry za ewentualne błędy ale niestety nie ma sprawdzania pisowni w firefoxie dla języka ang...
  • #3 4344082
    -M-Ł-O-D-Y-
    Uważam że z uwagi na to że jest to strona w języku polskim opisy powinny być zamieszczane w tym języku. Miałem to nieszczęście że niestety mnie w szkole uczyli jedynego słusznego języka.
  • #4 4344442
    daro9925
    Hello
    This is beatiful construction. Very good. Super.
    The PCB is nice.
  • #5 4344452
    Decado
    How much is it :?:
    Profesional make. Very good!!
  • #6 4344569
    kiler129
    O man !
    Great job .... beutiful job !
  • #7 4344936
  • #8 4344953
    bb84
    Nie no brzydkie to to nie jest. Ale co to właściwie jest ?
  • #9 4345187
    siewcu
    Co to jest? Dla mnie to radio firmy HAM model DDS VFO... buczkog masz rację opisując to w ten sposób - nie dziwię Ci się, sam miałem podobne odczucia. Ja też przyłączam się do wypowiedzi kolegów -M-Ł-O-D-Y- i buczkog... Skoro strona jest po polsku to niech lepiej nie będzie opisu a jak ma być to po polsku. Ja się uczę angielskiego ale nie jestem w stanie rozczytać tego, co jest napisane w opisie.
    Siewcu
  • #10 4345191
    harnasx
    "the pcb is very good" "nice work" bla bla bla - może kolega zilustruje nam jak w Indiach się robi takie płytki? zamawia sie pewnie przez Internet :) Gdzie są zdjęcia środka i "lutów". Jak dla mnie to jedna wielka ściema!!! Jak na międzynarodowy projekt to tragicznie udokumentowany, porażka!
    I nie napiszę tego po angielsku - chociaż mógłbym ;)
  • #11 4345213
    panmechanik
    will be giving the software FREE along with the PCB. Interested homebrewers may Email me for Circuit and other details
    Jest to oferta sprzedaży tych płytek!Facet będzie dawał oprogramowanie jak ktoś zamówi u niego płytke PCB!Temat powinien wylądować w koszu
  • #12 4345228
    markosik20
    Poziom 33  
    Gość poprostu szuka klientów na swoje urządzenie. I nie jest to żadne DIY tylko produkt na sprzedaż (kit do samodzielnego montażu). Płytka, klawiatura (i obudowa pewnie też) są wykonane na zamówienie w firmach które się tym specjalizują.
  • #13 4345397
    Pth
    1. No wiadomo, że szuka klientów... Inaczej nie dawał by tego
    Courier Charge will be Rs. 50/- ( DTDC or DHL or Professional courier, only in INDIA). I can send the PCB anywhere in the world using Registered INDIA POST. For international Fright, please follow the link.
    http://www.indiapost.gov.in/Netscape/SpeedPost.html#International%20Tariff
    etc...
    Skoro chce się interesować elektroniką to TRZEBA (TAK TAK, TRZEBA!!!! I napiszę to jeszcze kilak razy : TRZEBA, TRZEBA, TRZEBA) znać angielski... Ja nieznając angielskiego nawet bym się do tego nie przyznawał! W dzisiejszych czasach nieznając najpopularniejszego (no może poza chińskim :P) języka, czyli angielskiego to wstyd... To po pierwsze. A po drugie wydaje mi się, że nie ma się co zabierać za elektronikę nieznając angielskiego ( i terminologii naukowej dla elektroniki ( no terminologii to się można akurat nauczyć podczas samej praktycznej pracy z elektroniką)).
    W ogóle denerwują mnie ludzie na tym forum, którzy piszą, że nie znają angielskiego i chcą specjalnie polskich opisów, pdf'ów, etc...
    vu3wij -> Look for naive people in other place... !Good luck!
    Pzdr :]
  • #14 4345423
