Witam niedawno sprowadziłem sobie golfa 4 1.9TDI 130konnego - 6 biegów.
Autko nie odpala - silnik kreci zapali na chwilkę i gaśnie - mryga kontrolka immo. Posiadam kabelek obd2 i programik vag-com wersja 3.
Zdiagnozowałem go lecz nie udało mi sie połączyć ze sterownikiem silnika i airbagu. oto dane :
VAG-COM Version: Release 311.2-N
Control Module Part Number: 1J5 920 826 C
Component and/or Version: KOMBI+WEGFAHRSP VDO V13
Software Coding: 01114
Work Shop Code: WSC 00050
Additional Info: WVWZZZ1JZ3P394963 VWZ7Z0C7286032
7 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to B+
01176 - Key
07-00 - Signal to Low
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
01314 - Engine Control Module
49-00 - No Communications
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00028
3 Faults Found:
004 - No Signal/Communication - Intermittent
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 00028
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J5 920 826 C
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 01114
Shop #: WSC 00050
7 Faults Found:
01176 - Key
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
4 Faults Found:
00778 - Steering Angle Sensor (G85)
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 1E Komfortgerát HLO 0003
Coding: 00065
Shop #: WSC 00028
End -------------------------------------------------------
Dlaczego nie mogę połączyć sie z tymi dwoma sterownikami tym kabelkiem i czy awaria czujnika w misce olejowe może blokować start silnika.
Proszę o pomoc.
7 Faults Found:
01176 - Key
Coding: 0019970
Shop #: WSC 00028
3 Faults Found:
Coding: 11000
Shop #: WSC 00028
Coding: 01114
Shop #: WSC 00050
7 Faults Found:
01176 - Key
Coding: 00006
Shop #: WSC 00028
4 Faults Found:
Coding: 00065
Shop #: WSC 00028
Proszę o pomoc.
