Opóźnienie przy łączeniu z FTP ( NND, ProFtpd )
MES Mariusz 11 Lut 2008 15:16 1520 4
  • #1 11 Lut 2008 15:16
    MES Mariusz
    Poziom 36  
    Na postawionym przez siebie serwerze FTP ( na dystrybucji NND ) mam nieprzyjemne około 3 sekundowe oczekiwanie po tym czasie serwer pyta o użytkownika i hasło i od tej pory wszystko już działa jak burza.
    Skąd takie opóźnienie jeszcze przed zapytaniem o użytkownika?
    0 4
    #2 11 Lut 2008 15:28
    mbo
    Stawiam na sprawdzanie nazwy DNS klienta i Ident - wyłącz oba a problem zniknie.
    0
  • #3 11 Lut 2008 15:34
    MES Mariusz
    Poziom 36  
    Mój proftpd.conf ma zawartość:
    Code:
    # This is a basic ProFTPD configuration file (rename it to
    # 'proftpd.conf' for actual use.  It establishes a single server
    # and a single anonymous login.  It assumes that you have a user/group
    # "nobody" and "ftp" for normal operation and anon.
    ServerName         "FTP"
    ServerType         standalone
    DefaultServer         on
    DefaultAddress 127.0.0.1
    RequireValidShell off
    # Port 21 is the standard FTP port.
    Port            21
    # Umask 022 is a good standard umask to prevent new dirs and files
    # from being group and world writable.
    Umask            022
    # To prevent DoS attacks, set the maximum number of child processes
    # to 30.  If you need to allow more than 30 concurrent connections
    # at once, simply increase this value.  Note that this ONLY works
    # in standalone mode, in inetd mode you should use an inetd server
    # that allows you to limit maximum number of processes per service
    # (such as xinetd).
    MaxInstances         30
    # Set the user and group under which the server will run.
    User            nobody
    Group            nobody
    # To cause every FTP user to be "jailed" (chrooted) into their home
    # directory, uncomment this line.
    DefaultRoot ~
    # Normally, we want files to be overwriteable.
    AllowOverwrite      on
    # Bar use of SITE CHMOD by default
    <Limit SITE_CHMOD>
      DenyAll
    </Limit>
    # A basic anonymous configuration, no upload directories.  If you do not
    # want anonymous users, simply delete this entire <Anonymous> section.
    <Anonymous ~ftp>
      User            ftp
      Group            ftp
      AnonRequirePassword       on
      # We want clients to be able to login with "anonymous" as well as "ftp"
      UserAlias         anonymous ftp
      # Limit the maximum number of anonymous logins
      MaxClients         10
      # We want 'welcome.msg' displayed at login, and '.message' displayed
      # in each newly chdired directory.
      DisplayLogin         welcome.msg
      DisplayFirstChdir      .message
      # Limit WRITE everywhere in the anonymous chroot
      <Limit WRITE>
        DenyAll
      </Limit>
    </Anonymous>
    Nie odnajduję tu niczego, co podpowiadasz.
    0
    #4 11 Lut 2008 15:52
    gothye
    Poziom 33  
    dopisz do konfigu :
    Code:
    UseReverseDNS               off
    IdentLookups                off
    0
  • #5 11 Lut 2008 16:47
    MES Mariusz
    Poziom 36  
    gothye napisał:
    dopisz do konfigu :
    Code:
    UseReverseDNS               off
    IdentLookups                off
    Pomogło :-). Zamykam temat :-)
    0
