Zastanawiam się nad wzmacniaczem do napędzania moich dwóch Alpine SWR-1222R.
Myślałem nad kupnem:
Alpine PDX-1.1000
RMS 2ohms @1**.4V 1%THD: 1000W x 1 (20Hz - 200Hz)
RMS 4ohms @1**.4V 1%THD: 1000W x 1 (20Hz - 200Hz)
Crossover Frequency Adjustment: 50Hz-200Hz, -24dB oct (LP)
4Layer Glass Epoxy PC Board
Class-D
Layered Installation
1 Channel (Mono) Operation
Thermal Management Processor
Subsonic Filter
Adjustable Crossover (LP)
MOSFET Power Supply
DC-DC PWM Power Supply
Discrete Pre-Amp Stage
MOSFET Final Outputs
STAR Circuitry
Auto Over-Current Protection
Top Mounted Blue LED Power/Status Indicator
Integrated Wire and Mounting Screw Terminals
One Side Terminal Layout
Gold Plated RCA Input Connectors
Continuously Adjustable Gain Control
Gold Plated Power Screw Terminals
Non-Fading Pre-Amp Output
Dimensions: 257mm x 192mm x 62mm
Jednak ostatnio znalazłem w podobnej cenie
Orion HCCA-D5000
Max Power 5000W
4 Ohm Rating 1000W x 1 RMS
2 Ohm Rating 1600W x 1 RMS
1 Ohm Rating 2500W x 1 RMS
Freq. Resp. 20Hz - 250Hz
THD+N < 1%
Damping factor > 50
Signal to noise ratio -59dBA
Crossover range/scope LP 30 - 250hz 12/24 db octave
Input sensitivity 200mV - 5V
Safe load impedance 1 ohm
Equalization Circuit Intelli Q 10 db
Remote level control Included
Amplifier protection
Dimensions 22.8” x 10.2” x 2.4” (plus end caps)
Co o tym sądzicie który według was jest ciekawszą propozycją??
Alpine PDX-1.1000
Class-D
Subsonic Filter
MOSFET Power Supply
STAR Circuitry
Orion HCCA-D5000
Max Power 5000W
THD+N < 1%
Damping factor > 50
