witam,posiadam głsnik rainbow hammer 12 cali 400 watt rms moze mi ktos pomóc w doborze skrzyni???najlepiej bass reflex...wymiary rurki terz bym prosił...oto parametry:
12" Hammer
12 inch
Peak power handling 750 Watt
Nominal power handling 400 Watt
Frequency response 25 - 200 Hz
Impedance 2 x 2 Ohm @ 100Hz
Max. SPL (in car, ported) 146 dB @ 35-120Hz
Magnet weight 3650 Gramme
External diameter 316 mm
Installation diameter 286 mm
Basket rim height without / with ring 10 / 18 mm
Mounting depth 146 mm
Overall depth 161 mm
Magnet diameter 186 mm
Displacement 4.3 Litre
Suitable for... enclosures
Fs 28.00 Hz
Redc* 4.20 Ohm
Qms 4.80
Qes 0.34
Qts 0.32
Le* 3.21 mH
Vas 60.00 Litre
Sd 510.00 cm^2
Z @ 100 Hz* 5.70 Ohm
Z @ 1 kHz* 28.40 Ohm
Z @ 10 kHz* 109.00 Ohm
Rms 7.40 kg/s
Xmax 23.00 mm
słucham troszke techno,trance i czarnej nuty
z góry dzieki!!!ps:i jak wzmacniaczyk do tego głosniczka,aktualnie gram na sony x plod monoblock 400w rms...nie rusza mnie a i widac ze głosnik moze wiecej..
12" Hammer
12 inch
Fs 28.00 Hz
Redc* 4.20 Ohm
Qms 4.80
Qes 0.34
Qts 0.32
Le* 3.21 mH
Vas 60.00 Litre
Sd 510.00 cm^2
Rms 7.40 kg/s
Xmax 23.00 mm
