Alarm Fiat Multipla - Rozpiska
Cichy_vtec 23 Kwi 2008 17:23 3191 4
  • #1 5069375
    Cichy_vtec
    Witam ! Koledzy na może ktoś z was rozpiske Fiata Multipli, bo szukałem na forum i nie mogę nic znaleźć na ten temat. Także będe bardzo wdzięczny.
  • #2 5069814
    carrier
    Specjalista - Alarmy Samochodowe
    Multipla - Rozpiska
    pkhenr
    Poziom 32  
    Takie coś pomoże ?
    SPECIFIC VEHICLE ALARM FITTING INSTRUCTIONS REV. 00
    www.cobra.it
    Note: This information is not binding, therefore it must be considered only an example for installation purposes that must be executed
    as per the instructions given on the product installation manual.
    fimul99gbd.doc
    MAKE FIAT MOD. MULTIPLA YEAR 99 ® PETROL
    DIESEL
    ALARM/SIREN
    POSITION
    Position the compact alarms and the sirens on the left side of the engine
    compartment between the steering column and the bulkhead that divides the
    engine compartment and the passenger’s compartment.
    CENTRAL UNIT POSITION The modular systems and the modules should be positioned under the
    dashboard, driver’s side.
    POWER SUPPLY + 30: connect to the 4 mm2 RED wire located at the entrance of the fuse box.
    - 31: connect to one of the 2 mm2 BROWN wires located in the coming out of the
    original power supply behind the bulkhead of the driver’s side.
    IGNITION WIRE + 15/54: connect to the 0,5 mm2 LIGHT BLUE/WHITE wire located in the 18 way
    white connector in the front part of the fuse box.
    DIRECTION INDICATORS Connect to the LIGHT BLUE wire located in the 12 way WHITE/BROWN
    connector and to the LIGHT BLUE/BLACK wire located in the 14 way white/brown
    CENTRAL DOORS LOCKING Negative control signal
    Connect to the WHITE wire (lock) and light BLUE wire (unlock) located in the
    wiring harness coming out of the driver’s side door.
    IMMOBILISATION POINT 1 Gasoil pump
    Cut the 1 mm2 BROWN/WHITE wire located in the 14 way brown connector in the
    STARTER +50: Cut the RED wire located in the 3 way white connector coming out of the
    ignition switch.
    BONNET SWITCH Install an additional switch on the front headlamp plate, near the bonnet stop
    rubber.
    DOORS SWITCH Connect to the GREY and GREY/BROWN wires located in the 14 way
    white/brown connector in the front part of the fuse box.
    BOOT SWITCH Connect to the GREY/BLUE wire located in the 12 way white connector in the
    boot, driver’s side.
  • #4 5069822
    pkhenr
    Poziom 32  
    Wyglad ana to że wysłaliśmy w tym samym momencie
  • #5 5070821
    Cichy_vtec
    Dzieki wielkie Panowie. POZDROO
