PSD:2002 eminence
SPECIFICATION
Throat Size 1", 25.4mm
Nominal Impedance* 8 or 16 ohms*
Power Rating 80W
Resonance 550Hz
Usable Frequency Range 1.2kHz - 20kHz
Sensitivity*** 105dB
Magnet Weight 34 oz.
Voice Coil Diameter 2", 51mm
THIELE & SMALL PARAMETERS
DC Resistance (Re) 6.1
Coil Inductance (Le) 1.6 mH
MOUNTING INFORMATION
Overall Diameter 5.25", 133mm
Mounting Holes Diameter 2X 1/4-20 or 3" M6
Mounting Holes B.C. D. 3" or 2.25"
Mounting Thread 1 3/8" 18 NEF ext.
Depth 2.2", 56mm
Weight 5 lbs, Gross 5.76 lbs
MATERIALS OF CONSTRUCTION
Diaphragm Material Titanium
Selenium
Throat diameter mm (in) - 25 (1)
RMS (W) - 80
Musical program power -(W)- 160
Impedance (Ohm) - 8
SPL 1 W @ 1m (dB) - 109
Frequency Resp @-10 dB (Hz) - 1000 to 21,000
Magnet weight g (oz) - 675 (24)
Voice coil diameter mm (in) - 44 (1.7)
Cut freq at 12 dB/Oct (Hz)- 1,500
Testing Horn - HL14-25
Diaphragm material - Titanium
Horn connection - Thread
Cover/base material - Plastic
cena eminence 308 zł
selenium 200 zł
??????? - ozdobnik?
"pomoc" - kolega potrzebuje pomocy, czy ogłasza się, że potrafi jej udzielić? Jeśli to drugie, to nie ten dział, a jeśli to pierwsze to proszę napisać o jaką pomoc chodzi.
Regulamin p.11
Proszę użyć "zmień" i poprawić post.
[Art]
SPECIFICATION
Power Rating 80W
Resonance 550Hz
Depth 2.2", 56mm
Selenium
RMS (W) - 80
Impedance (Ohm) - 8
selenium 200 zł
??????? - ozdobnik?
Regulamin p.11
[Art]
