Gdzie znaleźć schemat elektryki do Peugeota 405?
ptys 02 Gru 2002 19:51 3623 3
  • #1 61689
    ptys
    Proszę o pomoc w znalezieniu schematu. Z góry dziękuję.
  • #2 62626
    LUCOM
    Ocena: 72
    XU5M3Z ENGINE
    MMFD - G6 MONOPOINT INJECTION-IGNITION
    WIRING DIAGRAMS
    COMPONENTS
    BB0 Battery
    BB1 Battery plus unit
    CA Ignition switch
    PSF Connection board - Fuse box
    C1300 Injection ignition test connector
    V1300 Injection ignition test warning lamp
    1000 Starter inhibitor switch (automatic transmission)*
    1135 Ignition coil
    1205 Fuel pump fuse
    1210 Fuel pump
    1215 Canister purge solenoid valve*
    1220 Coolant thermistor
    1225 Idle regulation stepper motor
    1240 Inlet air thermistor
    1302 Injector supply relay
    1304 Double relay
    1312 Inlet manifold pressure sensor
    1313 Engine speed sensor
    1317 Throttle potentiometer
    1320 Injection-ignition control unit
    1330 Injector
    1348 Oxygen sensor heater fuse
    1350 Oxygen sensor
    4 Instrument panel
    8000 Air conditioning control switch*
    8005 Compressor supply relay*
    8020 Compressor*
    * According to equipment
    HARNESSES
    FSC 10 AV : Front harness
    FSC 20 MOT : Engine harness
    FSC 50 P/B : Fascia harness
    FSC 51 J : Fuel gauge harness
    FSC 54 P : Fuel pump harness
    INTER-HARNESS CONNECTIONS
    MC2 13V NR Black 13 way connector
    MC3 13V MR Brown 13 way connector
    HC23 9V GR Grey 9 way connector
    HC27 13V BA White 13 way connector
    HC28 13V GR Grey 13 way connector
    HC40 6V MR Brown 6 way connector
    HC43 2V BA White 2 way connector
    HC48 2V GR Grey 2 way connector
    HC3B BV MR Brown 13 way connector
    CONNECTION BOARD - FUSE BOX
    13V BA: White 13 way connector
    13V MR: Brown 13 way connector
    EARTH POINTS
    MM1: Engine earth on gearbox
    MM2: Body earth on battery tray bracket
    MM4: Body earth on wiper motor
    MM9: Body earth on wiper motor
    HM21: Body earth on RH door pillar
    CONNECTOR COLOUR CODE
    BA White
    BE Blue
    GR Grey
    JN Yellow
    MR Brown
    NR Black
    VE Green
    • xu5m3z-1.zip (111.99 KB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #3 63602
    ptys
    Dziękuję za schemat. Sorry że tak późno ale były problemy z elektrodą. :D
  • #4 70573
    psenny
    Ocena: 23
    Jeżeli interesuje Cię schemat reszty samochodu to daj znać na e-maila.
