Mam podlaczony do Atmegi16 LCD HD44780 i DS18B20 (pod pin PD0). Nie dziala mi poprawnie transmisja 1-wire. Caly czas na wyswietlaczu wyswietlona temperatura to -16.1 (a powinno wskazywac ok. 25). Prosze o jakas podpowiedz
Proszę używać znaczników [code] - uzupełniłem.
[zumek]
#include <avr/io.h>
#include <avr/delay.h>
#include <stdlib.h>
//LCD
#define LCD PORTA
#define E 3
#define RS 2
#define SET_E LCD |= _BV(E)
#define CLR_E LCD &= ~_BV(E)
#define SET_RS LCD |= _BV(RS)
#define CLR_RS LCD &= ~_BV(RS)
//1-WIRE
#define WE 0
#define SET_1wire DDRD&=~_BV(WE)
#define CLEAR_1wire DDRD|=_BV(WE)
#define PORT_1wire PIND
#define F_CPU 16000000UL
float temp=0;
char buf[8];
void write_to_lcd(char x){
SET_E;
LCD = ((LCD & 0x0F) | (x & 0xF0));
CLR_E;
SET_E;
LCD = ((LCD & 0x0F) | ((x & 0x0F) << 4));
CLR_E;
void write_command(char x){
CLR_RS;
write_to_lcd(x);
void write_char(char x){
SET_RS;
write_to_lcd(x);
void write_text(char * s){
write_command(0x01); //1 czysci
_delay_ms (10);
while(*s){
write_char(*s);
s++;
_delay_ms (1);
void lcd_init(void){
int x;
int i;
for(i = 0; i < 3; i++){
write_command(0x3F);
_delay_ms (10);
for(i = 0; i < 2; i++){
write_command(0x2E);
_delay_ms (10);
write_command(0x2C); //DL=0, N=1, F=0, 101100
_delay_ms (10);
write_command(0x06); // i/d=1,s=0, 110
_delay_ms (10);
_delay_ms (10);
write_command(0x0C); //d=1.c=1,b=0, 1110
_delay_ms (10);
write_command(0x80); //d=1.c=1,b=0, 1110
_delay_ms (10);
//---------------------------------1-WIRE-----------------------------
unsigned char RESET_PULSE(void){
unsigned char PRESENCE;
CLEAR_1wire;
//opoznienie(500);
_delay_us (500);
SET_1wire;
//opoznienie(30);
_delay_us (30);
if(bit_is_clear(PORT_1wire, WE)){PRESENCE=1;} else {PRESENCE=0;}
//opoznienie(470);
_delay_us (470);
if(bit_is_set(PORT_1wire, WE)){PRESENCE=1;} else {PRESENCE=0;}
return PRESENCE;
void send(char bit){
CLEAR_1wire;
//opoznienie(5);
_delay_us (5);
if(bit==1)
SET_1wire;
_delay_us (80);
SET_1wire;
unsigned char read (void){
unsigned char PRESENCE=0;
CLEAR_1wire;
// opoznienie(2);
_delay_us (2);
SET_1wire;
//opoznienie(15);
_delay_us (15);
if(bit_is_set(PORT_1wire, WE)) PRESENCE=1; else PRESENCE=0;
return (PRESENCE);
void send_byte(char wartosc){
unsigned char i;
unsigned char pom;
for(i=0;i<8;i++){
pom=wartosc>>i;
pom&=0x01;
send(pom);
// opoznienie(100);
_delay_us (100);
unsigned char read_byte(void){
unsigned char i;
unsigned char wartosc=0;
for(i=0;i<8;i++){
if(read()) wartosc|=0x01<<i;
// opoznienie(15);
_delay_us (15);
return (wartosc);
int main(void){
unsigned char sprawdz;
char temp1=0, temp2=0;
int e;
char buf[8];
_delay_ms (40);
DDRA = 0xFF;
PORTA = 0xFF;
lcd_init();
_delay_ms (200);
while(1){
sprawdz=RESET_PULSE();
if(sprawdz==1){
send_byte(0xCC);
send_byte(0x44);
for(e=0;e<25;e++)
_delay_ms (30);
send_byte(0xCC);
send_byte(0xBE);
temp1=read_byte();
temp2=read_byte();
temp=0;
temp=(float)(temp1+(temp2*256))/16;
dtostrf(temp,1,1,buf);
write_text(buf);
_delay_ms (200);
}else{
write_text("NICZ");
}Proszę używać znaczników [code] - uzupełniłem.
[zumek]
