GSA-4163B - nie nagrywa płyt DVD+/- DL mimo aktualizacji firmware A105
sxo 21 Gru 2009 20:39 2693 3
  • #1 7419660
    sxo
    Witam, mam problem z nagrywaniem plyt DL wszystkie inne ok, firmware wgrany.
    Nagrywarka HL-DT-ST DVDRAM GSA-4163B A105 (ATA)
    Kod z ImgBurn
    I 20:26:25 ImgBurn Version 2.5.0.0 started!
    I 20:26:25 Microsoft Windows XP Professional (5.1, Build 2600 : Dodatek Service Pack 2)
    I 20:26:25 Total Physical Memory: 523 764 KB - Available: 321 600 KB
    W 20:26:25 SPTD can have a detrimental effect on drive performance.
    I 20:26:25 Initialising SPTI...
    I 20:26:25 Searching for SCSI / ATAPI devices...
    I 20:26:26 Found 1 DVD±RW/RAM and 1 BD-ROM/HD DVD-ROM!
    I 20:30:01 Operation Started!
    I 20:30:01 Source File: D:\Call of duty 3\cod3.dvd
    I 20:30:01 Source File Sectors: 3 697 696 (MODE1/2048)
    I 20:30:01 Source File Size: 7 572 881 408 bytes
    I 20:30:01 Source File Volume Identifier: XBOX360
    I 20:30:01 Source File Volume Set Identifier: 33479a57
    I 20:30:01 Source File Implementation Identifier: Daikin U.S. Comtec Lab
    I 20:30:01 Source File File System(s): ISO9660; UDF (1.02)
    I 20:30:01 Destination Device: [1:1:0] HL-DT-ST DVDRAM GSA-4163B A105 (I:) (ATA)
    I 20:30:01 Destination Media Type: DVD+R DL (Disc ID: RICOHJPN-D01-67) (Speeds: 2,4x)
    I 20:30:01 Destination Media Sectors: 4 173 824
    I 20:30:01 Write Mode: DVD
    I 20:30:01 Write Type: DAO
    I 20:30:01 Write Speed: 2,4x
    I 20:30:01 Link Size: Auto
    I 20:30:01 Lock Volume: Yes
    I 20:30:01 Test Mode: No
    I 20:30:01 OPC: No
    I 20:30:02 BURN-Proof: Enabled
    I 20:30:02 Book Type Setting: DVD-ROM
    I 20:30:02 Optimal L0 Data Zone Capacity: 1 848 848
    I 20:30:02 Optimal L0 Data Zone Method: ECC Block Boundary
    E 20:30:13 Set L0 Data Zone Capacity Failed! - Reason: Write Error
    E 20:30:13 Operation Failed! - Duration: 00:00:11
    I 20:30:13 Average Write Rate: N/A - Maximum Write Rate: N/A
    I 20:31:56 Operation Started!
    I 20:31:56 Source File: D:\Call of duty 3\cod3.dvd
    I 20:31:56 Source File Sectors: 3 697 696 (MODE1/2048)
    I 20:31:57 Source File Size: 7 572 881 408 bytes
    I 20:31:57 Source File Volume Identifier: XBOX360
    I 20:31:57 Source File Volume Set Identifier: 33479a57
    I 20:31:57 Source File Implementation Identifier: Daikin U.S. Comtec Lab
    I 20:31:57 Source File File System(s): ISO9660; UDF (1.02)
    I 20:31:57 Destination Device: [1:1:0] HL-DT-ST DVDRAM GSA-4163B A105 (I:) (ATA)
    I 20:31:57 Destination Media Type: DVD+R DL (Disc ID: RICOHJPN-D01-67) (Speeds: 2,4x)
    I 20:31:57 Destination Media Sectors: 3 697 696
    I 20:31:57 Write Mode: DVD
    I 20:31:57 Write Type: DAO
    I 20:31:57 Write Speed: 2,4x
    I 20:31:57 Link Size: Auto
    I 20:31:57 Lock Volume: Yes
    I 20:31:57 Test Mode: No
    I 20:31:57 OPC: No
    I 20:31:57 BURN-Proof: Enabled
    I 20:31:57 Book Type Setting: DVD-ROM
    I 20:31:57 Optimal L0 Data Zone Capacity: 1 848 848
    I 20:31:57 Optimal L0 Data Zone Method: ECC Block Boundary
    I 20:31:57 Set L0 Data Zone Capacity Succeeded!
    I 20:32:06 Filling Buffer... (20 MB)
    I 20:32:07 Writing LeadIn...
    W 20:32:07 Potential 'ReadBufferCapacity' Deferred Error - Write Error
    W 20:32:07 Failed to Write Sectors 32 - 63 - Reason: Invalid Address For Write
    W 20:32:07 Retrying (1 of 20)...
    W 20:32:07 Retry Failed - Reason: Invalid Address For Write
    W 20:32:07 Retrying (2 of 20)...
    W 20:32:07 Retrying (3 of 20)...
    W 20:32:07 Retrying (4 of 20)...
    W 20:32:07 Retrying (5 of 20)...
    W 20:32:07 Retrying (6 of 20)...
    W 20:32:07 Retrying (7 of 20)...
    W 20:32:07 Retrying (8 of 20)...
    W 20:32:07 Retrying (9 of 20)...
    W 20:32:07 Retrying (10 of 20)...
    W 20:32:07 Retrying (11 of 20)...
    W 20:32:07 Retrying (12 of 20)...
    W 20:32:07 Retrying (13 of 20)...
    W 20:32:07 Retrying (14 of 20)...
    W 20:32:07 Retrying (15 of 20)...
    W 20:32:07 Retrying (16 of 20)...
    W 20:32:07 Retrying (17 of 20)...
    W 20:32:07 Retrying (18 of 20)...
    W 20:32:07 Retrying (19 of 20)...
    W 20:32:07 Retrying (20 of 20)...
    W 20:32:12 Retrying (21)...
    W 20:32:12 Retry Failed - Reason: Invalid Address For Write
    W 20:32:13 Retrying (22)...
    W 20:32:13 Retry Failed - Reason: Invalid Address For Write
    W 20:32:14 Retrying (23)...
    W 20:32:14 Retry Failed - Reason: Invalid Address For Write
    E 20:32:16 Failed to Write Sectors 32 - 63 - Reason: Invalid Address For Write
    E 20:32:16 Next Writable Address: 0
    I 20:32:16 Synchronising Cache...
    W 20:32:24 User opted to skip the 'Close Track/Session/Disc' functions.
    E 20:32:24 Failed to Write Image!
    E 20:32:24 Operation Failed! - Duration: 00:00:27
    I 20:32:24 Average Write Rate: 0 KB/s (0.0x) - Maximum Write Rate: 0 KB/s (0.0x)
  • #3 7426017
    sxo
    f/w A106
    tak jak podsunąłeś.
    Dalej jest problem podczas wykrywania nagrywarki w ImgBurn:
    W 11:00:20 SPTD can have a detrimental effect on drive performance.
    A podczas wypalania:
    W 11:03:13 Set L0 Data Zone Capacity Failed! - Reason: Write Error
    I 11:03:24 Filling Buffer... (20 MB)
    I 11:03:24 Writing LeadIn...
    W 11:03:24 Potential 'ReadBufferCapacity' Deferred Error - Write Error
    W 11:03:24 Failed to Write Sectors 32 - 63 - Reason: Invalid Address For Write
    W 11:03:24 Retrying (1 of 20)...
    Nagrywam na Płytach Verbatim lub EMTEC
  • #4 7432869
    WojtasJD
    Ocena: 1587
    To nie problem wykrywania, tylko obecność SCSI Pass-Through Direct - pewnie masz Daemon Tools albo Alcohol... albo to i to :wink:
    Ogólnie czy DVD+R_DL też był od Verbatima?
    https://www.elektroda.pl/rtvforum/topic1247674.html#6238211
