1. 22222222
2. FFFF9xxxx
3. 0000D303 / 5555FFBC
4. 5C:FFFFFFC1
5. 33333333
6. 11:FFFF8200
7. 9xxxx
8. DE:3451
1. [22222222]
Caused by:
Wrong setting of griffin (Folder settings (C:\Program Files\Nokia\Phoenix\Products\NHL-1/2/3/4/5/6 etc) try unistall and then reinstall everything.
Phone hardware problem.
BAd FIA file structure
Solution posted by: microstargsm, syed
2. FFFF9xxxx
Caused by:
All FFFF9xxxx error got to do with the connection.
Solution posted by: maxking
Tip: Try bending the battery connectors upwards, sometimes the connection is not good enough.
Caused by:
No connection to the phone or halt button was pressed (I think)
Solution posted by: The_deViL
4. 5C:FFFFFFC1
Caused by:
Don't know, appears on 9210's. Try reflashing in safe mode
Mybe is your flash ic is corrupted...or you need to reball the flash ic and tryto reflash again.
Solution posted by: lonegunman
5. 33333333
Caused by:
Using a un-activated box. If your box is V2.42 and unregistered you will get this error code
Solution posted by: microstargsm, Odia
6. 11:FFFF8200
Caused by:
Not sure
7. 91xxx
Caused by:
Cable error
8. DE:3451
Caused by:
Not sure.
Solution: Use Griffin v1.988 or v1.989. And check the "Skip Bluetooth Flashing"
