witam
to jest wyciąg z Sisandry ,czy ktoś mi powie jaka jest płyta główna?
Chipset 1
Model : Intel Corporation 82815/EP/P Solano Host-Hub Interface Bridge (GMCH/MCH A2-step)
Bus(es) : ISA X-Bus PCI IMB USB i2c/SMBus
Front Side Bus Speed : 1x 133MHz (133MHz data rate)
Maximum FSB Speed / Max Memory Speed : 1x 133MHz / 1x 133MHz
Width : 64-bit
IO Queue Depth : 4 request(s)
Chipset 1 Hub Interface
Type : Hub-Interface
Version : 1.00
Number of Ports : 1
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Logical/Chipset 1 Memory Banks
Bank 0 : 64MB SDRAM 3-3-3-0CL
Bank 1 : 64MB SDRAM 3-3-3-0CL
Bank 2 : 128MB SDRAM 3-3-3-0CL
Bank 3 : 128MB SDRAM 3-3-3-0CL
Shared Memory : 1MB
Width : 64-bit
Refresh Rate : 15.60µs
Power Save Mode : Yes
Fixed Hole Present : No
APIC 1
Version : 2.00
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module(s)
Memory Module 1 : MOSEL V436416S04VCTG-75 55E50110 128MB 16x(8Mx8) SDRAM PC133U-333-542 (CL3 up to 133MHz)
Memory Module 2 : Transcend Information TS32MLS64V8D 000037DB 256MB 16x(16Mx8) SDRAM PC100-322-622 (CL3 up to 100MHz) (CL2 up to 83MHz)
Environment Monitor 1
Model : SMSC M10x/14x LPC
Version : 0.01
Mainboard Specific Support : No
PCI Bus(es) on Hub 1
Version : 2.10
Number of Bridges : 1
PCI Bus 0 : PCI (1/1x PCIClk)
PCI Bus 1 : PCI (1/1x PCIClk)
LPC Hub Controller 1
Model : Intel Corporation 82801BA LPC Interface (ICH2 B1 step)
ACPI Power Management Enabled : Yes
Random Number Generator Enabled : Yes
Delayed Transaction Supported : Yes
Delayed Transaction Enabled : No
LPC Legacy Controller 1
Type : SMSC LPC v1
Version : 59.01
Number of Enabled Devices : 6
USB Controller 1
Model : IBM 82801BA/BAM USB Controller #1 (ICH2/ICH2-M B1/B1' steps)
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
System SMBus Controller 1
Model : Intel 801xx/63xx SMBus
Version : 0.02
Specification : 1.00
Advanced TCO Mode Enabled : No
Slave Device Enabled : No
PEC Support : No
Speed : 100kHz
Performance Tips
Warning 2544 : System/Video shared memory greatly reduces performance. Use external video card.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Chipset 1
Width : 64-bit
Version : 1.00
Number of Ports : 1
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Shared Memory : 1MB
Width : 64-bit
APIC 1
Version : 2.00
Multiplier : 1/2x
Memory Module(s)
Version : 0.01
Version : 2.10
Type : SMSC LPC v1
Version : 59.01
USB Controller 1
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Version : 0.02
PEC Support : No
Speed : 100kHz
Performance Tips
