[Sprzedam] Trochę scalaków do sprzedania
czopik2004 01 Lut 2011 21:13 2641 3
  • #1 9089386
    czopik2004
    Ocena: 3
    Witam!
    Do sprzedania mam troszkę scalaków.
    SMD:
    DS2401 Silicon Serial Number
    GD75232 MULTIPLE RS-232 DRIVERS AND RECEIVERS 2szt.
    MAX7219CWG
    NFA220 7szt
    OPA343UA Single-Supply, Rail-to-Rail Operational Amplifiers MicroAmplifier(TM) Series
    PCM3001E Stereo Audio CODEC 18-BITS, SERIAL INTERFACE TM
    TDA1027AT
    TDA1387
    TDA1596T
    TDA6190X
    TDA73118D
    TDA7420
    TDA7437
    TDA8763AM/4
    YM7128B-F
    Przewlekane:
    4AC22 Power Transistor Arrays
    AD7581LN CMOS 8-Bit 8-Channel Data Acquisition System
    ADC0809N CMOS ANALOG-TO-DIGITAL CONVERTERS WITH 8-CHANNEL MULTIPLEXERS
    ADC2311E Audio A/D Converter Europe (24-Pin Plastic Package) 2szt
    ADL-020SH Active Delay Line
    AN6881 Programmable Frequency Divider
    BA5406 Audio LSIs > Power amplifier 2szt
    BTS410G2 Smart Highside Power Switch
    C520D A/D z wyjściem BCD
    CA3140E 4.5MHz, BiMOS Operational Amplifier with MOSFET Input/Bipolar Output 2szt
    CA3193E 1.2MHz, BiCMOSPrecision Operational Amplifiers 2szt
    CA3300D 6-Bit General-Purpose Binary-Output ADC - Binary Output
    CCU-AMAC-02
    CCU-TFR-033/8K
    CCU-VT-02
    CS3842A Off-Line Current Mode PWM Control Circuit with Undervoltage Lockout
    CSG 8565R2 Graphic chip.
    CSG 8580R5 Sound chip
    CXA1238S FM/AM stereo receiver
    D2030 14W Hi-Fi AUDIO AMPLIFIER 7szt
    D7002C 12-Bit Binary A/D Converter
    DMA2281 C/D/D2-MAC Decoder
    DMA2286 C/D/D2-MAC Descrambler
    DMPAL10L8NC Progammable Array Logic Series 24 (PAL Series 24)
    DMPAL12L6NC Fuse-Programmable Array Logic Device (FPAL) - Security Fuse 4szt
    DS3695N Multipoint RS485/RS422 Transceivers/Repeaters 3szt
    GAL16V8B HIGH PERFORMANCE E2CMOS PLD 3szr
    HA1377A Dual 5.8W Audio Power Amplifiers
    KA2209 Dual Low Voltage Power Amplifier
    KA2220STK Equalizer Amplifier with ALC
    KA22427 I-CHIP AM/FM RADIO IC
    KDA0316N D/A CONVERTER
    L4960 2.5A POWER SWITCHING REGULATOR 2szt
    LA1186N FM Front End for Radio-Cassette Recorders, Music Centers
    LA1837N Single-Chip Home Stereo IC with Electronic Tuning Support
    LA4440 6W 2-Channel, Bridge 19W typ Power Amplifier
    LA4445 5.5W 2-Channel AF Power Amplifier 2szt
    LA5601 Low Dropout Regulator with Reset
    LA7220 Electronic Switch for VCR/Audio Use
    LC7185 CB Transceiver PLL Frequency Synthesizer and Controller
    LC7215 MW/LW PLL Frequency Synthesizers
    LC7522 ELECTORONIC VOLUME CONTROL FOR GRAPHIC EQUALIZER
    LM1894N Dynamic Noise Reduction System DNR
    LM308N Super Gain Operational Amplifier
    LM336 2.5V VOLTAGE REFERENCES
    LM385 1.2 & 2.5V MICROPOWER VOLTAGE REFERENCE 3szt
    LP2951 Series of Adjustable Micropower Voltage Regulators
    M51954A VOLTAGE DETECTING, SYSTEM RESETTING IC SERIES
    M5230L VARIABLE OUTPUT VOLTAGE REGULATOR(DUAL TRACKING TYPE)
    M5290P +-5V TRACKING REGULATOR WITH RESET CIRCUIT
    M62358P 8-BIT 12CH D-A CONVERTER WITH BUFFER AMPLIFIERS
    MB3771 Power Supply Monitor
    MC1408L8 EIGHT-BIT MULTIPLYING DIGITAL-TO-ANALOG CNOVERTER
    MC3423P OVERVOLTAGE SENSING CIRCUIT
    PBL3717A STEPPER MOTOR DRIVER 3szt
    PCM56P Serial Input 16-Bit Monolithic DIGITAL-TO-ANALOG CONVERTER 2szt
    SAB6456 Sensitive 1 GHz divide-by-64/divide-by-256 switchable prescaler
    SDA3302 GHz PLL with I2C Bus and Four Chip Addresses
    SM5807FP 4 FOLD OVER SAMPLING DIGITAL FILTER FOR DIGITAL AUDIO
    SP973T8C 30MHz 8-BIT FLASH ADC (TTL/CMOS OUTPUTS)
    STA471A NPN Darlington With built-in avalanche diode 7szt
    STV8130 ADJUSTABLE AND +3.3 V DUAL VOLTAGE REGULATOR WITH DISABLE AND RESET FUNCTIONS
    TA7222AP 5.8W AUDIO POWER AMPLIFIER
    TDA1220B AM-FM QUALITY RADIO
    TDA1311A Stereo Continuous Calibration DAC CC-DAC
    TDA1510Q 24 W BTL or 2 x 12 W stereo car radio power amplifier
    TDA1516Q24 W BTL or 2 x 12 watt stereo car radio power amplifier 2szt
    TDA1521 2 x 12 W hi-fi audio power amplifier
    TDA2002 8W Car Radio Audio Amplifier 3szt
    TDA2003 10W CAR RADIO AUDIO AMPLIFIER
    TDA2005 20W BRIDGE AMPLIFIER FOR CAR RADIO
    TDA2009
    TDA2040 20W Hi-Fi AUDIO POWER AMPLIFIER
    TDA7073A Dual BTL power driver 2szt
    TDA7265 18W+18W STEREO AMPLIFIER WITH MUTE & ST-BY 4szt
    TDA7295 80V-80W DMOS AUDIO AMPLIFIER WITH MUTE/ST-BY 4szt
    TDA7350 22W BRIDGE-STEREO AMPLIFIER FOR CAR RADIO 3szt
    TDA7350A 22W BRIDGE-STEREO AMPLIFIER FOR CAR RADIO 2szt
    TDA7375A 2szt
    TDA7377A 2 x 30W DUAL/QUAD POWER AMPLIFIER FOR CAR RADIO
    TDA7384A
    TDA7385 4 x 30W QUAD BRIDGE CAR RADIO AMPLIFIER
    TDA7439 THREE BANDS DIGITALLY CONTROLLED AUDIO PROCESSOR
    TDA8405 13.2V 1W TV and VTR stereo/dual sound processor with I2C bus control
    TDA8421 Hi-fi stereo audio processor, I2C bus
    TDA8703 8-bit high-speed analog-to-digital converter
    TSA5511 1.3 GHz Bidirectional I2C-bus controlled synthesizer
    UAF2115 Speedometer and Mileage Indicator
    UL1402 Wzmacniacz mocy m.cz.
    UL1481 Wzmacniacz mocy m.cz. 3szt
    UL1482 Wzmacniacz mocy m.cz.
    YM2151 FM operator type-M (OPM)
    YM3012 2-Channel Serial Input Floating D/A Converter (DAC-MS)
    Hybrydy:
    STK4432 Stereo amplifier
    STK5342
    STK5392
    STK5471
    STK6711BMK4 4-Phase Stepping Motor Driver Unipolar Self-Excitation Type 4szt
    STK6713BMK4 Unipolar fixed-current chopper-type 4-phase stepping motor driver
    STK681-050
    STK7226
    STK73410 II Voltage Regulator for TV / VTR Use
    Scalaków mam więcej. Wymieniłem te ciekawsze. Cen na razie nie jestem w stanie wymienić. Nawet nie wiem, ile to jest warte.
    Pozdrawiam: Kamil
  • #2 9496973
    DARODFF
    Ocena: 52
    Witam :)
    czy posiadasz jeszcze TDA7375A 2szt ? na sprzedaż
    i jaki stan nowe czy wylut
    sprawne i za ile ?
  • #3 9497323
    ANUBIS
    Poziom 32  
    Ocena: 63
    Proszę uzupełnić post , edytując podać cenę .
    Zasady pisania w tym dziale:
    https://www.elektroda.pl/rtvforum/topic1944865.html
    /zasady są identyczne dla obu działów ogłoszeń/
    ANUBIS
  • #4 9497331
    czopik2004
    Ocena: 3
    Proszę o usunięcie tematu...
