Jak ustawić WL-5460AP v2, by uniknąć częstego rozłączania PPPoE?
przemal 02 Lut 2011 14:06 2666 3
  • #1 9092058
    przemal
    Witam mam kłopot z routerem ponieważ często sie rozłącza może ktoś zerknąć na mojego loga, może mam coś źle ustawione. Necik dostaje po radiu przez PPPoE na WL-5460AP v2 siłę sygnału pokazuje miedzy 34 a 37.
    0day 00:00:56 (none) syslog.info syslogd started: BusyBox v1.00-pre8 (2009.07.09-07:51+0000)
    0day 00:00:56 (none) kern.notice klogd: klogd started: BusyBox v1.00-pre8 (2009.07.09-07:51+0000)
    0day 00:00:56 (none) kern.warn klogd: Linux version 2.4.18-MIPS-01.00 (root@Joyce 00000000 (usable)
    0day 00:00:56 (none) kern.warn klogd: On node 0 totalpages: 4096
    0day 00:00:56 (none) kern.warn klogd: zone(0): 4096 pages.
    0day 00:00:56 (none) kern.warn klogd: zone(1): 0 pages.
    0day 00:00:56 (none) kern.warn klogd: zone(2): 0 pages.
    0day 00:00:56 (none) kern.warn klogd: Kernel command line: root=/dev/mtdblock1 console=0 single
    0day 00:00:56 (none) kern.warn klogd: Calibrating delay loop... 178.99 BogoMIPS
    0day 00:00:56 (none) kern.warn klogd: Memory: 14272k/16384k available (1564k kernel code, 2112k reserved, 92k data, 52k init, 0k highmem)
    0day 00:00:56 (none) kern.warn klogd: Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes)
    0day 00:00:56 (none) kern.warn klogd: Inode-cache hash table entries: 1024 (order: 1, 8192 bytes)
    0day 00:00:56 (none) kern.warn klogd: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    0day 00:00:56 (none) kern.warn klogd: Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
    0day 00:00:56 (none) kern.warn klogd: Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
    0day 00:00:56 (none) kern.warn klogd: check_wait... unavailable.
    0day 00:00:56 (none) kern.warn klogd: POSIX conformance testing by UNIFIX
    0day 00:00:56 (none) kern.info klogd: Linux NET4.0 for Linux 2.4
    0day 00:00:56 (none) kern.info klogd: Based upon Swansea University Computer Society NET3.039
    0day 00:00:56 (none) kern.warn klogd: Initializing RT netlink socket
    0day 00:00:56 (none) kern.warn klogd: Starting kswapd
    0day 00:00:56 (none) kern.info klogd: squashfs: version 3.1 (2006/08/19) Phillip Lougher
    0day 00:00:56 (none) kern.info klogd: Serial driver version 6.02 (2003-03-12) with no serial options enabled
    0day 00:00:56 (none) kern.info klogd: ttyS00 at 0x00c3 (irq = 3) is a rtl_uart1
    0day 00:00:56 (none) kern.warn klogd: state->flags=00000000
    0day 00:00:56 (none) kern.warn klogd: Realtek GPIO Driver for Flash Reload Default
    0day 00:00:56 (none) kern.warn klogd: block: 64 slots per queue, batch=16
    0day 00:00:56 (none) kern.info klogd: SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
    0day 00:00:56 (none) kern.warn klogd: CSLIP: code copyright 1989 Regents of the University of California.
    0day 00:00:56 (none) kern.info klogd: PPP generic driver version 2.4.1
    0day 00:00:56 (none) kern.info klogd: MPPE/MPPC encryption/compression module registered
    0day 00:00:56 (none) kern.notice klogd: RealTek E-Flash System Driver. (C) 2002 RealTek Corp.
    0day 00:00:56 (none) kern.notice klogd: Found 1 x 2M Byte MXIC MX29LV160CB at 0xbe000000
    0day 00:00:56 (none) kern.notice klogd: Creating 2 MTD partitions on "DiskOnChip Millennium":
    0day 00:00:56 (none) kern.notice klogd: 0x00000000-0x00100000 : "boot+cfg+linux"
    0day 00:00:56 (none) kern.notice klogd: 0x00100000-0x00200000 : "root fs"
    0day 00:00:56 (none) kern.warn klogd: RTL8185 driver version 1.14 (2007-05-14)
    0day 00:00:56 (none) kern.warn klogd: rtl8186_init: Loading new ethernet driver!!
    0day 00:00:56 (none) kern.info klogd: 8186NIC Ethernet driver v0.0.4 (Sep 23, 2005)
    0day 00:00:56 (none) kern.info klogd: eth0: RTL8186-NIC at 0xbd200000, 00:01:02:03:04:05, IRQ 4
    0day 00:00:56 (none) kern.info klogd: eth1: RTL8186-NIC at 0xbd300000, 04:05:06:07:08:09, IRQ 5
    0day 00:00:56 (none) kern.warn klogd: fast_nat v1.3i-2-abc
    0day 00:00:56 (none) kern.info klogd: NET4: Linux TCP/IP 1.0 for NET4.0
    0day 00:00:56 (none) kern.info klogd: IP Protocols: ICMP, UDP, TCP
    0day 00:00:56 (none) kern.warn klogd: IP: routing cache hash table of 512 buckets, 4Kbytes
    0day 00:00:56 (none) kern.warn klogd: TCP: Hash tables configured (established 1024 bind 2048)
    0day 00:00:56 (none) kern.warn klogd: ip_conntrack version 2.1 (128 buckets, 1024 max) - 312 bytes per conntrack
    0day 00:00:56 (none) kern.warn klogd: ip_nat_h323: cannot initialize the module!
    0day 00:00:56 (none) kern.warn klogd: ip_nat_ftp: error registering helper for port 21
    0day 00:00:56 (none) kern.warn klogd: ip_tables: (C) 2000-2002 Netfilter core team
    0day 00:00:56 (none) kern.info klogd: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
    0day 00:00:56 (none) kern.info klogd: NET4: Ethernet Bridge 008 for NET4.0
    0day 00:00:56 (none) kern.warn klogd: VFS: Mounted root (squashfs filesystem) readonly.
    0day 00:00:56 (none) kern.warn klogd: Freeing unused kernel memory: 52k freed
    0day 00:00:56 (none) kern.warn klogd: mount /proc file system ok!
    0day 00:00:56 (none) kern.warn klogd: mount /var file system ok!
    0day 00:00:56 (none) kern.info klogd: device eth0 entered promiscuous mode
    0day 00:00:56 (none) kern.warn klogd: eth0:phy is 8201
    0day 00:00:56 (none) kern.info klogd: device eth1 entered promiscuous mode
    0day 00:00:56 (none) kern.warn klogd: eth1:phy is 8201
    0day 00:00:56 (none) kern.info klogd: br0: port 2(eth1) entering listening state
    0day 00:00:56 (none) kern.info klogd: br0: port 1(eth0) entering listening state
    0day 00:00:56 (none) kern.info klogd: br0: port 2(eth1) entering learning state
    0day 00:00:56 (none) kern.info klogd: br0: port 2(eth1) entering forwarding state
    0day 00:00:56 (none) kern.info klogd: br0: topology change detected, propagating
    0day 00:00:56 (none) kern.info klogd: br0: port 1(eth0) entering learning state
    0day 00:00:56 (none) kern.info klogd: br0: port 1(eth0) entering forwarding state
    0day 00:00:56 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    0day 00:01:04 (none) kern.info udhcpd: udhcp server (v0.9.9-pre) started
    0day 00:01:18 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    0day 00:01:22 (none) kern.info pppd[2461]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
    0day 00:01:22 (none) kern.notice pppd[2461]: pppd 2.4.2b1 started by root, uid 0
    0day 00:01:23 (none) kern.info pppd[2461]: PPP session is 472
    0day 00:01:23 (none) kern.info pppd[2461]: Using interface ppp0
    0day 00:01:23 (none) kern.notice pppd[2461]: Connect: ppp0 <--> wlan0
    0day 00:01:23 (none) kern.warn pppd[2461]: Couldn't increase MTU to 1500
    0day 00:01:23 (none) kern.err pppd[2461]: Couldn't increase MRU to 1500
    0day 00:01:23 (none) kern.warn pppd[2461]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
    0day 00:01:23 (none) kern.warn pppd[2461]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
    0day 00:01:23 (none) kern.err pppd[2461]: CHAP authentication failed
    0day 00:01:25 (none) kern.info pppd[2461]: Terminating on signal 15.
    0day 00:01:25 (none) kern.notice pppd[2461]: Connection terminated.
    0day 00:01:25 (none) kern.info pppd[2461]: Exit.
    0day 00:01:35 (none) kern.info pppd[2749]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
    0day 00:01:35 (none) kern.notice pppd[2749]: pppd 2.4.2b1 started by root, uid 0
    0day 00:01:40 (none) kern.info pppd[2749]: PPP session is 176
    0day 00:01:40 (none) kern.info pppd[2749]: Using interface ppp0
    0day 00:01:40 (none) kern.notice pppd[2749]: Connect: ppp0 <--> wlan0
    0day 00:01:40 (none) kern.warn pppd[2749]: Couldn't increase MTU to 1500
    0day 00:01:40 (none) kern.err pppd[2749]: Couldn't increase MRU to 1500
    0day 00:01:40 (none) kern.warn pppd[2749]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
    0day 00:01:40 (none) kern.warn pppd[2749]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
    0day 00:01:40 (none) kern.info pppd[2749]: Remote message: Access granted
    0day 00:01:41 (none) kern.warn pppd[2749]: ipup......
    0day 00:01:41 (none) kern.notice pppd[2749]: local IP address 172.51.2.245
    0day 00:01:41 (none) kern.notice pppd[2749]: remote IP address 10.8.8.80
    0day 00:01:41 (none) kern.notice pppd[2749]: primary DNS address 194.204.152.34
    0day 00:01:41 (none) kern.notice pppd[2749]: secondary DNS address 208.67.222.222
    Jan 27 17:04:50 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:04:51 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:07:57 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:08:08 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:14:19 (none) kern.info udhcpd: Received a SIGUSR1
    Jan 27 17:18:09 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:18:10 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:18:28 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:18:29 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:20:41 (none) syslog.info -- MARK --
    Jan 27 17:22:31 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:22:32 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:23:42 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:23:50 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:24:34 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:24:36 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:25:16 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:25:22 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:25:28 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:25:57 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:26:06 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:26:07 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:26:16 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:26:41 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:27:05 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:27:06 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:27:18 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:27:19 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:27:21 (none) kern.info pppd[2749]: No response to 3 echo-requests
    Jan 27 17:27:21 (none) kern.notice pppd[2749]: Serial link appears to be disconnected.
    Jan 27 17:27:21 (none) kern.warn pppd[2749]: ipdown......
    Jan 27 17:27:22 (none) kern.info pppd[2749]: Terminating on signal 15.
    Jan 27 17:27:22 (none) kern.warn pppd[2749]: Couldn't increase MTU to 1500
    Jan 27 17:27:22 (none) kern.err pppd[2749]: Couldn't increase MRU to 1500
    Jan 27 17:27:26 (none) kern.info pppd[2749]: Terminating on signal 15.
    Jan 27 17:27:26 (none) kern.notice pppd[2749]: Connection terminated.
    Jan 27 17:27:26 (none) kern.info pppd[2749]: Connect time 5824345.7 minutes.
    Jan 27 17:27:26 (none) kern.info pppd[2749]: Sent 822452 bytes, received 11950548 bytes.
    Jan 27 17:27:26 (none) kern.info pppd[2749]: Exit.
    Jan 27 17:27:35 (none) kern.info pppd[3530]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
    Jan 27 17:27:35 (none) kern.notice pppd[3530]: pppd 2.4.2b1 started by root, uid 0
    Jan 27 17:27:35 (none) kern.info pppd[3530]: PPP session is 444
    Jan 27 17:27:35 (none) kern.info pppd[3530]: Using interface ppp0
    Jan 27 17:27:35 (none) kern.notice pppd[3530]: Connect: ppp0 <--> wlan0
    Jan 27 17:27:35 (none) kern.warn pppd[3530]: Couldn't increase MTU to 1500
    Jan 27 17:27:35 (none) kern.err pppd[3530]: Couldn't increase MRU to 1500
    Jan 27 17:27:35 (none) kern.warn pppd[3530]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
    Jan 27 17:27:35 (none) kern.warn pppd[3530]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
    Jan 27 17:27:35 (none) kern.info pppd[3530]: Remote message: Access granted
    Jan 27 17:27:36 (none) kern.warn pppd[3530]: ipup......
    Jan 27 17:27:36 (none) kern.notice pppd[3530]: local IP address 172.51.2.245
    Jan 27 17:27:36 (none) kern.notice pppd[3530]: remote IP address 10.8.8.80
    Jan 27 17:27:36 (none) kern.notice pppd[3530]: primary DNS address 194.204.152.34
    Jan 27 17:27:36 (none) kern.notice pppd[3530]: secondary DNS address 208.67.222.222
    Jan 27 17:27:48 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:27:54 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:28:04 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:28:15 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:28:23 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:28:34 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:28:52 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:28:53 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:29:00 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:29:01 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:29:26 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:29:27 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:29:34 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:29:35 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:29:40 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:29:41 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:29:46 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:29:48 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:30:05 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:30:26 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:30:32 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:30:38 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:30:46 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:30:47 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:30:52 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:30:53 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:30:56 (none) kern.info pppd[3530]: LCP terminated by peer (Peer not responding)
    Jan 27 17:30:56 (none) kern.warn pppd[3530]: ipdown......
    Jan 27 17:30:57 (none) kern.info pppd[3530]: Terminating on signal 15.
    Jan 27 17:30:57 (none) kern.warn pppd[3530]: Couldn't increase MTU to 1500
    Jan 27 17:30:57 (none) kern.err pppd[3530]: Couldn't increase MRU to 1500
    Jan 27 17:30:57 (none) kern.notice pppd[3530]: Modem hangup
    Jan 27 17:31:00 (none) kern.info pppd[3530]: Terminating on signal 15.
    Jan 27 17:31:00 (none) kern.notice pppd[3530]: Connection terminated.
    Jan 27 17:31:00 (none) kern.info pppd[3530]: Connect time 3.4 minutes.
    Jan 27 17:31:00 (none) kern.info pppd[3530]: Sent 84858 bytes, received 308761 bytes.
    Jan 27 17:31:00 (none) kern.info pppd[3530]: Exit.
    Jan 27 17:31:07 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:31:10 (none) kern.info pppd[4149]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
    Jan 27 17:31:10 (none) kern.notice pppd[4149]: pppd 2.4.2b1 started by root, uid 0
    Jan 27 17:31:10 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:31:15 (none) kern.info pppd[4149]: PPP session is 613
    Jan 27 17:31:15 (none) kern.info pppd[4149]: Using interface ppp0
    Jan 27 17:31:15 (none) kern.notice pppd[4149]: Connect: ppp0 <--> wlan0
    Jan 27 17:31:15 (none) kern.warn pppd[4149]: Couldn't increase MTU to 1500
    Jan 27 17:31:15 (none) kern.err pppd[4149]: Couldn't increase MRU to 1500
    Jan 27 17:31:15 (none) kern.warn pppd[4149]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
    Jan 27 17:31:15 (none) kern.warn pppd[4149]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
    Jan 27 17:31:15 (none) kern.err pppd[4149]: CHAP authentication failed
    Jan 27 17:31:17 (none) kern.info pppd[4149]: Terminating on signal 15.
    Jan 27 17:31:17 (none) kern.notice pppd[4149]: Connection terminated.
    Jan 27 17:31:17 (none) kern.info pppd[4149]: Exit.
    Jan 27 17:31:26 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:31:27 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:31:27 (none) kern.info pppd[4323]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
    Jan 27 17:31:27 (none) kern.notice pppd[4323]: pppd 2.4.2b1 started by root, uid 0
    Jan 27 17:31:27 (none) kern.info pppd[4323]: PPP session is 850
    Jan 27 17:31:27 (none) kern.info pppd[4323]: Using interface ppp0
    Jan 27 17:31:27 (none) kern.notice pppd[4323]: Connect: ppp0 <--> wlan0
    Jan 27 17:31:27 (none) kern.warn pppd[4323]: Couldn't increase MTU to 1500
    Jan 27 17:31:27 (none) kern.err pppd[4323]: Couldn't increase MRU to 1500
    Jan 27 17:31:27 (none) kern.warn pppd[4323]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
    Jan 27 17:31:27 (none) kern.warn pppd[4323]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
    Jan 27 17:31:27 (none) kern.err pppd[4323]: CHAP authentication failed
    Jan 27 17:31:29 (none) kern.info pppd[4323]: Terminating on signal 15.
    Jan 27 17:31:29 (none) kern.notice pppd[4323]: Connection terminated.
    Jan 27 17:31:29 (none) kern.info pppd[4323]: Exit.
    Jan 27 17:31:38 (none) kern.info pppd[4497]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
    Jan 27 17:31:38 (none) kern.notice pppd[4497]: pppd 2.4.2b1 started by root, uid 0
    Jan 27 17:31:44 (none) kern.info pppd[4497]: PPP session is 948
    Jan 27 17:31:44 (none) kern.info pppd[4497]: Using interface ppp0
    Jan 27 17:31:44 (none) kern.notice pppd[4497]: Connect: ppp0 <--> wlan0
    Jan 27 17:31:44 (none) kern.warn pppd[4497]: Couldn't increase MTU to 1500
    Jan 27 17:31:44 (none) kern.err pppd[4497]: Couldn't increase MRU to 1500
    Jan 27 17:31:44 (none) kern.warn pppd[4497]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
    Jan 27 17:31:45 (none) kern.warn pppd[4497]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
    Jan 27 17:31:45 (none) kern.err pppd[4497]: CHAP authentication failed
    Jan 27 17:31:45 (none) kern.warn pppd[4497]: Couldn't increase MTU to 1500
    Jan 27 17:31:45 (none) kern.err pppd[4497]: Couldn't increase MRU to 1500
    Jan 27 17:31:47 (none) kern.info pppd[4497]: Terminating on signal 15.
    Jan 27 17:31:47 (none) kern.notice pppd[4497]: Connection terminated.
    Jan 27 17:31:47 (none) kern.info pppd[4497]: Exit.
    Jan 27 17:31:52 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:31:57 (none) kern.info pppd[4671]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
    Jan 27 17:31:57 (none) kern.notice pppd[4671]: pppd 2.4.2b1 started by root, uid 0
    Jan 27 17:32:16 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:0E:8E:1E:B6:6C
    Jan 27 17:32:21 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:32:22 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:0E:8E:1E:B6:6C
    Jan 27 17:32:27 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:32:32 (none) kern.err pppd[4671]: Timeout waiting for PADO packets0
    Jan 27 17:32:42 (none) kern.info pppd[4802]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
    Jan 27 17:32:42 (none) kern.notice pppd[4802]: pppd 2.4.2b1 started by root, uid 0
    Jan 27 17:32:43 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:0E:8E:1E:B6:6C
    Jan 27 17:32:49 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:33:02 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:0E:8E:1E:B6:6C
    Jan 27 17:33:08 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:33:17 (none) kern.err pppd[4802]: Timeout waiting for PADO packets0
    Jan 27 17:33:19 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:0E:8E:1E:B6:6C
    Jan 27 17:33:27 (none) kern.info pppd[4933]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
    Jan 27 17:33:27 (none) kern.notice pppd[4933]: pppd 2.4.2b1 started by root, uid 0
    Jan 27 17:33:32 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:33:38 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:0E:8E:1E:B6:6C
    Jan 27 17:33:44 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:33:45 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:0E:8E:1E:B6:6C
    Jan 27 17:33:50 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:33:53 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:0E:8E:1E:B6:6C
    Jan 27 17:33:58 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:34:02 (none) kern.err pppd[4933]: Timeout waiting for PADO packets0
    Jan 27 17:34:11 (none) kern.info pppd[4988]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
    Jan 27 17:34:11 (none) kern.notice pppd[4988]: pppd 2.4.2b1 started by root, uid 0
    Jan 27 17:34:37 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:34:46 (none) kern.err pppd[4988]: Timeout waiting for PADO packets0
    Jan 27 17:34:56 (none) kern.info pppd[5119]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
    Jan 27 17:34:56 (none) kern.notice pppd[5119]: pppd 2.4.2b1 started by root, uid 0
    Jan 27 17:35:03 (none) kern.info pppd[5119]: PPP session is 495
    Jan 27 17:35:03 (none) kern.info pppd[5119]: Using interface ppp0
    Jan 27 17:35:03 (none) kern.notice pppd[5119]: Connect: ppp0 <--> wlan0
    Jan 27 17:35:03 (none) kern.warn pppd[5119]: Couldn't increase MTU to 1500
    Jan 27 17:35:03 (none) kern.err pppd[5119]: Couldn't increase MRU to 1500
    Jan 27 17:35:03 (none) kern.warn pppd[5119]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
    Jan 27 17:35:04 (none) kern.warn pppd[5119]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
    Jan 27 17:35:05 (none) kern.err pppd[5119]: CHAP authentication failed
    Jan 27 17:35:05 (none) kern.warn pppd[5119]: Couldn't increase MTU to 1500
    Jan 27 17:35:05 (none) kern.err pppd[5119]: Couldn't increase MRU to 1500
    Jan 27 17:35:07 (none) kern.info pppd[5119]: Terminating on signal 15.
    Jan 27 17:35:07 (none) kern.notice pppd[5119]: Connection terminated.
    Jan 27 17:35:07 (none) kern.info pppd[5119]: Exit.
    Jan 27 17:35:16 (none) kern.info pppd[5293]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
    Jan 27 17:35:16 (none) kern.notice pppd[5293]: pppd 2.4.2b1 started by root, uid 0
    Jan 27 17:35:17 (none) kern.info pppd[5293]: PPP session is 509
    Jan 27 17:35:17 (none) kern.info pppd[5293]: Using interface ppp0
    Jan 27 17:35:17 (none) kern.notice pppd[5293]: Connect: ppp0 <--> wlan0
    Jan 27 17:35:17 (none) kern.warn pppd[5293]: Couldn't increase MTU to 1500
    Jan 27 17:35:17 (none) kern.err pppd[5293]: Couldn't increase MRU to 1500
    Jan 27 17:35:17 (none) kern.warn pppd[5293]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
    Jan 27 17:35:18 (none) kern.warn pppd[5293]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
    Jan 27 17:35:18 (none) kern.info pppd[5293]: Remote message: Access granted
    Jan 27 17:35:19 (none) kern.warn pppd[5293]: ipup......
    Jan 27 17:35:19 (none) kern.notice pppd[5293]: local IP address 172.51.2.245
    Jan 27 17:35:19 (none) kern.notice pppd[5293]: remote IP address 10.8.8.80
    Jan 27 17:35:19 (none) kern.notice pppd[5293]: primary DNS address 194.204.152.34
    Jan 27 17:35:19 (none) kern.notice pppd[5293]: secondary DNS address 208.67.222.222
    Jan 27 17:35:38 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:35:41 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:37:10 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:37:11 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:39:58 (none) kern.warn klogd: wlan0: Deauthenticated by AP - 00:02:6F:4B:E5:5F
    Jan 27 17:40:02 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:40:41 (none) syslog.info -- MARK --
    Jan 27 17:42:07 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:42:18 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:44:58 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:45:02 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:45:28 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:45:36 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:46:26 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:46:27 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:48:12 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:48:13 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:48:19 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:48:29 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:51:49 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:51:50 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:51:56 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:51:57 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:56:31 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:56:32 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:56:38 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:56:45 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 17:56:54 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 17:57:08 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 18:00:41 (none) syslog.info -- MARK --
    Jan 27 18:01:25 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 18:01:26 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 18:01:31 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 18:01:45 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 18:15:10 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 18:15:11 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Jan 27 18:15:41 (none) kern.warn klogd: wlan0: Roaming...
    Jan 27 18:15:42 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:0w
  • #2 9092345
    kafart
    Na moj gust sprawdz jakie masz MTU wpisane w routerze oraz czy nie musisz miec wlaczonej autoryzacji CHAP przy polaczeniu ppp
  • #3 9093368
    przemal
    Zmieniłem autoryzacje na CHAP, ale nie wiele to dało. Jeżeli chodzi o MTU to admin sieci podał mi wartość 1400, tylko jak ja sprawdziłem to powinno być 1372 max, ale na routerze nie mogę wpisać wartości poniżej 1400 i tyle mam wpisane.
    Feb  2 17:25:36 (none) kern.warn klogd: wlan0: Roaming...
    Feb  2 17:25:37 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Feb  2 17:28:25 (none) kern.warn klogd: wlan0: Roaming...
    Feb  2 17:28:27 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Feb  2 17:33:38 (none) kern.warn klogd: wlan0: Roaming...
    Feb  2 17:33:39 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Feb  2 17:44:27 (none) syslog.info -- MARK --
    Feb  2 17:45:06 (none) kern.warn klogd: wlan0: Roaming...
    Feb  2 17:45:07 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Feb  2 18:04:27 (none) syslog.info -- MARK --
    Feb  2 18:07:08 (none) kern.warn klogd: wlan0: Roaming...
    Feb  2 18:07:10 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Feb  2 18:09:32 (none) kern.warn klogd: wlan0: Roaming...
    Feb  2 18:09:34 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Feb  2 18:13:00 (none) kern.warn klogd: wlan0: Roaming...
    Feb  2 18:13:03 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
    Feb  2 18:16:15 (none) kern.warn klogd: wlan0: Roaming...
    Feb  2 18:16:16 (none) kern.warn klogd: wlan0: Associate to AP successfully - 00:02:6F:4B:E5:5F
  • #4 9095791
    Jakub_Lech
    Ocena: 19
    Kolego, kontaktuj się z administratorem sieci.
    Masz problem z stabilnym połączeniem się z anteną bazową sieci.
