Nieudane flashowanie Sony Ericsson J105i Naite - komunikat błędu w logu setool
cygan689 21 Lut 2011 13:44 3221 8
  • #1 9182435
    cygan689
    Ocena: 8
    Witam, jak w temacie nie mogę w żaden sposób przeflashować nie uruchamiającego się SE J105i Naite.Softy mam z supportu setoola i na końcu wywala mi komunikat jak w logu:
    RUNNING v 1.01/UNI
    CARD SERIAL 00088xxx
    USBFLASH DRIVER VERSION 02.02.00.05
    CFG:000000000000
    ChipID:D900,EMP protocol:0401
    PHONE STATE: "RETAIL"
    FLASH CID: 0053
    OTP LOCKED:1 CID:53 PAF:1 IMEI:0xxxxxxxxxxxxx CERT:RED
    LDR:2009-07-31 10:42 1207-6250_DB3200_CS_LOADER_ACC_SDRAM_R2A084
    LDR:2009-07-31 10:44 1207-6251_DB3200_CS_LOADER_APP_SDRAM_R2A084
    Model (from GDFS):J105i
    MAPP CXC article: R1HA035 prg1224-1526_GENERIC_LV
    MAPP CXC version: R1HA035
    Language Package: CENTRAL-EUROPE
    CDA article: 1232-8325
    CDA version: R2A
    Default article: 1224-1575
    Default version: R1HA035
    PROVIDER: 000-00
    SIMLOCKS NOT DETECTED
    SECURITY UNITS BACKUP CREATED.
    Elapsed: 9 secs.
    SIGNED MODE (USING SERVER)
    ALTERNATIVE SECURITY BYPASS ENABLED
    PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
    CFG:110000000000
    BOOTROM MODE DETECTED
    OTP DBG: [1,53,1,01224900501492]
    OTP LOCKED:1 CID:53 PAF:1 IMEI:01xxxxxxxxxxxxx CERT:RED
    GOT SEED:23039AD33580D92F00406F7A
    P96 AUTH PASSED
    RESTARTING...
    DEVICE KEY:37D35E9C6CC5AA819248152060313E45 (1)
    LDR:2009-04-21 18:27 1207-6247_DB3200_RESET_LOADER_ACC_SDRAM_R2A081
    LDR:2009-04-21 18:28 1207-6248_DB3200_RESET_LOADER_APP_SDRAM_R2A081
    GOT SEED:AA6140343580D92F00406F7A
    P96 AUTH PASSED
    RESETTING SECURITY TO FACTORY STATE...
    RESTARTING...
    OTP LOCKED:1 CID:53 PAF:1 IMEI:01xxxxxxxxxxxxxxx CERT:BROWN
    LDR:2009-07-31 10:49 1207-6245_DB3200_PRODUCTION_LOADER_ACC_SDRAM_R2A084
    LDR:2009-07-31 10:50 1207-6246_DB3200_PRODUCTION_LOADER_APP_SDRAM_R2A084
    WRITING SEMCBOOT...
    PREPARING SECURITY...
    CHANGING DOMAIN TO "BROWN"
    SIGNING...
    DEVICE KEY RESTORED
    writing "D:\FLASHE\SONY ERICSSON\J105naite\R1HA035_APP_SW_1224_1526_GENERIC_LV_REDBROWNBLUE_CID_53_52_49_DB3200.software"
    bad file, will not flash it.
    Elapsed: 43 secs.
    opcje w setool 1 i 2 i na forum setoola laser pisał żeby zmienić też w Set domain na Brown i ciągle wywala błąd flasha, możecie coś poradzić?
  • #2 9182460
    ebry
    Poziom 30  
    Ocena: 91
    Masz coś nie tak z plikiem. Ściągnij jeszcze raz.
  • #3 9182622
    cygan689
    Ocena: 8
    Ściągnąłem jeszcze raz i nic, ciągle bad file:cry:
  • #4 9182698
    siudziu
    Ocena: 113
    Pobierz inną wersje. Zaznacz Signed Mode + Alternative security + complete phone after flash i spróbój.
  • #5 9182718
    Adrian4477
    Ocena: 184
    A po co "alternative security"? Jak flash to signed mode i complete .
  • #6 9182748
    siudziu
    Ocena: 113
    Pewnie masz racje ale miałem jedengo cedara który bez alternative wyrzucał różne dziwne bledy po zanzaczeniu 2 opcji sie zflshował bez problemu.
  • #7 9182806
    cygan689
    Ocena: 8
    Próbuje na R1GA026 i na R1Ha035 cid 53 i nici, z zazn.signed mode i complete,to samo, coś jest nie tak z tymi softami..
    Na support.setool.net odpowiedzieli mi że kość flasha do przegrzania ,spróbujemy przegrzać...
    Przegrzałem kość flasha i teraz zapala się tylko podświetlenie lcd, i mogę wykręcić alarmowy-to już coś. Komunikat z próby flash taki sam jak na początku.
  • #8 19494395
    laik_komp
    Poziom 4  
    A próbowałeś a2uploader-em?
  • #9 19494469
    marcin7904
    Ocena: 258
    Kolego to teraz odgrzebałeś kotleta z przed 10lat. cygan689 już pewnie dawno zapomniał że taki telefon posiadał lub miał do zrobienia.
Użytkownik ma problem z flashowaniem telefonu Sony Ericsson J105i Naite, który nie uruchamia się. Podczas próby flashowania z użyciem plików z supportu setoola pojawia się komunikat o błędzie "bad file". Użytkownik próbował różnych wersji oprogramowania (R1GA026 i R1HA035) oraz zaznaczał opcje "Signed Mode" i "Complete", jednak bez skutku. Otrzymał sugestię, aby spróbować z inną wersją oprogramowania oraz użyć opcji "Alternative security". Po przegrzaniu kości flasha telefon reaguje, ale problem z flashowaniem nadal występuje. Inny użytkownik zasugerował użycie a2uploader-a, jednak temat wydaje się być stary, co może sugerować, że problem nie jest nowy.
