Aficio 1022 - sprawdzanie sprawności ID sensora
Kubeczeeek 05 Kwi 2011 19:00 1023 1
  • #1 9364131
    Kubeczeeek
    Ocena: 11
    Jak sprawdzić czy jest sprawny ID sensor ???
  • #2 9364300
    Janusz.P
    Specjalista - kserokopiarki
    Ocena: 224
    na początek proponuje lekture kawałka dokumentacji
    ID sensor
    Readings are abnormal if any of the following conditions occur:
    • Vsg ≤ 2.5V
    • Vsg < 3.5V when maximum power (254) is applied
    • Vsp ≥ 2.5V
    • (Vsg – Vsp) < 1.0V
    • ID sensor power required to make the standard output reaches the maximum
    value (254)
    The above ID sensor values can be checked using SP2-220.
    When this is detected, the machine changes the value of Vref to the previous value
    then does the toner density control process (in a similar way to sensor control
    mode 2).
    No SC code is generated if the ID sensor is defective.
