Storlink CIR Initialization
Please reboot now.
found magic num
found magic num
found magic num
bootLoader made time: 1258962533
bootLoader version: 1.04b03
Waiting for disk ready & detect ...
IDE 0 Detect disk 0
Disk Drive: IDE-0, Device-0, 3907029168 Sectors [UDMA6] 2000 GB 526 MB
Partition 1: Linux Swap
Partition 2: HPFS/NTFS
Partition 3: Linux 1012095 Sectors 518 MB
Partition 4: Linux 401625 Sectors 205 MB
foun file zImage
Processor: SL3512c2
CPU Rate: 300000000
AHB Bus Clock:150MHz Ratio:2/1
MAC 1 Address: 00:1E:58:96:7F:E5
MAC 2 Address: 00:50:C2:22:22:22
inet addr: 0.0.0.0/255.255.255.0
Kernel RAM Location: 0x00600000 Filename: /.boot/zImage
Initrd RAM Location: 0x00800000 Filename: /.boot/ramdisk.bin.gz
PHY 0 Addr 1 Vendor ID: 0x001cc912
==> enter ^C to abort booting within 2 seconds ......
boot from ide
checked model name : DNS-313v2
Load rd.gz 840814 ,fileSize is 840814...tftp model name : DNS-313v2
made time: 1258962544
version: 1.04b08
Load zImage 1068108 ,fileSize is 1068108...tftp model name : DNS-313v2
made time: 1258962543
version: 1.04b08
Uncompressing Linux.............................................................
........ done, booting the kernel.
Linux version 2.6.15 (root@CentServer) (gcc version 3.4.4) #179 Mon Nov 23 15:48
:00 CST 2009
CPU: FA526id(wb) [66015261] revision 1 (ARMv4)
Machine: GeminiA
Ignoring unrecognised tag 0x00000000
Memory policy: ECC disabled, Data cache writeback
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 2, 16 byte lines, 512 sets
CPU0: D cache: 8192 bytes, associativity 2, 16 byte lines, 256 sets
Built 1 zonelists
Kernel command line: root=/dev/ram0 rw mem=32M console=ttySL0,19200 initrd=0x008
00000,4M ramdisk_size=4096
PID hash table entries: 256 (order: 8, 4096 bytes)
Bus: 150MHz(2/1)
Console: colour dummy device 80x30
sl2312 console setup :
Disable IDE...config to SATA mode
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 32MB = 32MB total
Memory: 25812KB available (1743K code, 590K data, 84K init)
Mount-cache hash table entries: 512
*** Page_chain_cachep Init!***
CPU: Testing write buffer coherency: ok
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 4096K
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
NetWinder Floating Point Emulator V0.97 (double precision)
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
io scheduler noop registered
io scheduler deadline registered
Real Time Clock Driver v0.10
Gemini Gpio init
g751 init
flash probe init
Register Gemini Power control
Power event by Unknow Source
Watchdog Timer Initialized
ttySL0 at MMIO 0x42000000 (irq = 18) is a SL2312
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: loaded (max 8 devices)
VSC-switch not found
---> phy_vendor = 0x1CC912
SL351x Giga Ethernet driver 0.1.6 built at Nov 23 2009 15:46:40
sata_lepus1 version 0.1
ata1: SATA max UDMA/133 cmd 0xC2800020 ctl 0xC2800036 bmdma 0xC2800000 irq 5
scsi0 : sata_lepus1
sata_lepus0 version 0.1
ata2: SATA max UDMA/133 cmd 0xC2804020 ctl 0xC2804036 bmdma 0xC2804000 irq 4
ata2: dev 0 ATA-8, max UDMA/133, 3907029168 sectors: LBA48
HD speed:U6 (0x46)
ata2: dev 0 configured for UDMA/133
scsi1 : sata_lepus0
Vendor: ATA Model: WDC WD20EARS-22M Rev: 51.0
Type: Direct-Access ANSI SCSI revision: 05
SCSI device sda: 3907029168 512-byte hdwr sectors (2000399 MB)
SCSI device sda: drive cache: write back
sda: sda1 sda2 sda3 sda4
sd 1:0:0:0: Attached scsi disk sda
sd 1:0:0:0: Attached scsi generic sg0 type 0
SL2312 MTD Driver Init.......
Not find EN29LV400A.
Search for id:(01 22ba) interleave(1) type(2)
Found: S29AL004DB
SL2312 CFI Flash: Found 1 x16 devices at 0x0 in 16-bit bank
number of JEDEC chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Creating 3 MTD partitions on "SL2312 CFI Flash":
0x00000000-0x00040000 : "RedBoot"
0x00040000-0x00060000 : "MTD1"
0x00060000-0x00080000 : "MTD2"
SL2312 MTD Driver Init Success ......
FTC_FOTG2XX : Init FOTG2XX Driver
Init FOTG2xx driver
FTC_FOTG2XX : >>> Found FOTG2XX ...
pFTC_OTG c0bb83e0
hcd->self.controller c0bbd400
hcd end
hcd_buffer_create
ehci-hcd-FOTG2XX ehci-hcd-FOTG2XX: new USB bus registered, assigned bus number 1
usb_register_bus
ghcd_FOTG2XX hcd c0bbd400
hcd_irq_For_OTG
ehci->caps->length 10, hcd->regs f6800000 , ehci->regs f6800010
udev->state 1
drivers/usb/host/ehci-hcd-FOTG2XX.c: USB support enabled, EHCI rev 101. 0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
FTC_FOTG2XX : >>> +FOTG2XX_get_otg_transceiver
FTC_FOTG2XX : registered host c0bbd400
OTG2XX act as HOST only (don't need to wait gadget driver)
+(OTGC_Init)
pFTC_OTG->otg.default_a=1
+(OTGC_Init)
OTG_enable_VBUS
FTC_FOTG2XX : >>> Drive VBUS ok...
+OTGP_Close()
OTG2XX act as HOST only (remove gadget function)
+OTGH_Open()(0x30=0x0)
OTG_enable_VBUS
mdwOTGC_Control_A_VBUS_VLD_Rd 80000
+OTGP_Close()
ehci otg_set_host status 0
FTC_FOTG200_udc_1 : Init USB device Lower driver
FOTG200_BASE_ADDRESS = 0xf6900000
******reg_val = c0422037
FTC_FOTG200_udc_1 : ***** FOTG200 Peripheral 2.0 Test program *****
FTC_FOTG200_udc_1 : L0: System initial, Please wait...
FTC_FOTG200_udc_1 : L1: System is ready(dev->EPUseDMA=0xff)...
FTC_usb_probe_1 end
Initializing USB Mass Storage driver...
connect_change 1
clear_bit
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
NET: Registered protocol family 2
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
Freeing init memory: 84K
init started: BusyBox v1.00-pre1 (2008.03.07-06:35+0000) multi-call binary
start S00
Adding 506008k swap on /dev/sda1. Priority:-1 extents:1 across:506008k
EXT2-fs warning: mounting fs with errors, running e2fsck is recommended
swapoff
End of /linuxrc -- transfer to /sbin/init
Link /var/spool to /tmp/spool
Link /sys
Link slboot.img
Link web
Link modules
Link etc/hotplug
======= Run old shell script =======
** Johnson Poweron the system
mount: Mounting /proc on /proc failed: Device or resource busy
mount: Mounting none on /dev/pts failed: Device or resource busy
mount tmpfs for hibernation
mount: Mounting tmpfs on /var/spool failed: No such file or directory
Check MTD block device V2.03.04242009
MTDC: Mount MTD1 done.
MTDC: Mount MTD2 done.
MTDC: No need to copy file.
** copy mtd1 files
cp: /sys/mtd1/firmwareupdate: No such file or directory
cp: /sys/mtd1/codepage: No such file or directory
cp: /sys/mtd1/hd_magic_num: No such file or directory
cp: /sys/mtd1/onedisk: No such file or directory
cp: /sys/mtd1/MountError: No such file or directory
mv: /sys/mtd1/firmwareupdate: No such file or directory
mv: /sys/mtd1/restore: No such file or directory
mv: /sys/mtd1/format_ok: No such file or directory
mv: /sys/mtd1/pls_sync: No such file or directory
mv: /sys/mtd1/pls_chmod_a2: No such file or directory
mv: /sys/mtd1/pls_chmod_b2: No such file or directory
mv: /tmp/hd_magic_num: No such file or directory
** link lib **
** link web **
** link /usr/bin **
** link /usr/sbin **
** link /usr/local/LPRng **
cp: /sys/crfs/default/server-key-nopassword.pem: No such file or directory
** set loopback interface
ALPHA Networks Incorporation, setmacid V1.00 program start ...
found magic num
found magic num
found magic num
Storlink egiga0 address = 001E58967FE5
** Johnson check the bootloader's version and update it
tar: Invalid tar magic
killapp: No such file or directory
found magic num
found magic num
found magic num
found magic num
the file is /slboot.img
found magic num
found magic num
found magic num
now update slboot
the firmware is not new than the board
** execute rc.init.sh
SIOCADDRT: Network is unreachable
Setting hostname .... dns313
Starting DHCP client ....
*****8192.168.0.32
info, udhcpc (v0.9.9-pre) started
Can't find version control
GMAC-0 Addr 1 Vendor ID: 0x001cc912
Link Up (0x796d) MII Link status: 0000796d Phy status: 0000002f
MII REG 10 = 0x3800
1000M/Full
Flow Control Enable.
Enable MAC Flow Control...
interfaces: No such file or directory
unix: No such file or directory
get IP = [NONE SET]
dos: No such file or directory
display: No such file or directory
workgroup: No such file or directory
netbios: No such file or directory
server: No such file or directory
hosts: No such file or directory
security: No such file or directory
encrypt: No such file or directory
max: No such file or directory
socket: No such file or directory
create: No such file or directory
directory: No such file or directory
force: No such file or directory
use: No such file or directory
comment: No such file or directory
path: No such file or directory
valid: No such file or directory
---------- SATA-1 STANDBY -----------
