EasyJailbreakBatch Tool: Automatyzacja jailbreaka iOS z redsn0w i iTunes
zeezoo 28 Maj 2011 16:37 6153 3
  • Witam serdecznie.
    Kiedys troche sie nudzilem i zrobilem takie male narzedzie ulatwiajace zrobienie jailbreaka w iPhonie, iPodzie oraz iPadzie 1.
    Narzedzie samo pobiera potrzebne pliki zarowno redsn0w jak i odpowiedni iOS. Mozna tez ustawic recznie katalog, w ktorym mamy pliki ipsw jesli wczesniej je pobralismy. Oczywiscie jesli sa one w domyslnym katalogu iTunes program rowniez je znajdzie i uzyje. Jesli jakikolwiek plik ma nieprawidlowy rozmiar program usunie go i pobierze nowa kopie prosto z serwera apple.
    Wrzucilem programik na z-franka, cieszy sie dosc duza popularnoscia, wiec wydaje mi sie, ze kazdemu sie przyda. Czesto nie wiemy jaka wersje redsn0w uzyc. Ten malutki batch zrobi wiekszosc za nas :)
    Pozdrowienia.
    zeezoo
    changelog:
    1.4
    -hosts file editor added
    will check if gs.apple.com line exist in hosts file and if not will add otherwise will ask to remove it.
    after any operation will ping gs.apple.com to test if it's changed correctly.
    after first run will make backup of hosts file, can be restored any time
    1.3
    changes:
    -batch didn't work properly if Windows was non-english language. That's fixed now.
    -batch is using latest redsn0w_win_0.9.6rc17 for 4.3.3 firmware
    anyway you can still use rc16 if you use manual mode
    -added option to start redsn0w manually
    of course if it's not on the hdd will download selected version
    -added option to set ipsw folder manually
    if you have ipsw files downloaded already and you don't want to move them to ipsw folder just type c [enter] and set the correct folder
    That will be saved in config file to use in the future. Of course can be changed anytime.
    version 1.2 available.
    changes:
    -added support for iPod 2G 4.2.1
    -added support for iPod 3G 4.2.1/4.3.1/4.3.2/4.3.3
    -added support for iPod 4G 4.2.1/4.3.1/4.3.2/4.3.3
    -added support for iPad 1 4.2.1/4.3.1/4.3.2/4.3.3
    1.1
    - I didn't notice before that iTunes keeps only the latest software in default ipsw folder. From now my program is checking default folder and if it doesn't find correct file it will check ipsw folder located in iPhone folder on desktop and if it doesn't find it there it will get it from apple server.
    To get new executable please use upd8.exe or type "u" in batch window and press enter. Anyway program will show that there is update available and give you instructions.
    1.0 initial version
    - iPhone iOS supported models and versions
    2G 3.1.2/3.1.3
    3G 4.2.1
    3GS 4.2.1/4.3.1/4.3.2/4.3.3
    4 4.2.1/4.3.1/4.3.2/4.3.3
    -f0recast version 1.2
    download:
    upd8.exe will download always the latest version. Then use exe file from iPhone folder on your desktop.
    • upd8.zip (278.11 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    zeezoo
    zeezoo napisał 984 postów o ocenie 19, pomógł 77 razy. Mieszka w mieście Ostrow Wielkopolski. Jest z nami od 2005 roku.
  • #2 9611583
    zeezoo
    Ocena: 19
    version 1.5 available
    -iOS 5b1 support added for:
    iPhone 3GS
    iPhone 4
    iPod Touch 3G
    iPod Touch 4G
    iPad 1
    [tethered jb only]
    -program will check for update once a day, not everytime when opened/closed
    -some little changes in code - should work faster now
    !!!CAUTION!!!:
    STRONGLY advise - please download ipsw files manually [torrent?] and put them in iPhone/ipsw folder or custom folder. My script is using imzdl.com server to get required ipsw but unfortunately this server is very busy and most of the time it's not working properly.
    version 1.6 available
    fixes
    - iPhone 3G 4.2.1 and 3GS 4.2.1 didn't work properly. That's fixed now.
    - there was a little problem if date was in different format than yyyy/mm/dd
    now should work fine even if it's dd-mm-yyyy
    new
    - micro Apache web server added for following phones:
    iPhone 3G 4.2.1
    iPhone 3GS 4.2.1,4.3.1,4.3.2,4.3.3
    It will save you time and bandwith. You just have to put iPad1,1_3.2.2_7B500_Restore.ipsw in ipsw folder. If you don't have that file on you hdd script will get it for you automatically.
    And then...
    1. Will add special line in hosts file - it will be deleted when redsn0w operations are finished.
    2. Will download micro Apache from my server with all required settings.
    3. micro Apache server will start on port 13000 (if this port is used with another application will not work properly - please let me know if you have any problems with that. I will change it to different one)
    4. Script will start rinetd service to bind port 80 to 13000. If you see any errors please let me know. In my case there was a problem with teamviewer on one of 5 computers which I've used for tests. I've closed it any works fine.
    5. redsn0w will start and will think that is downloading iPad baseband from appldnld.apple.com but it will be your private http server
    6. After redsn0w finished work hosts file will be restored and micro Apache server will be terminated.
    You and your files are safe
    to update please type u and press [enter] from main menu.
    Have fun and please report any errors. It was fully tested on 3 computers with Windows XP but it should work on Win7/Vista as well. I will test it later on today.
    Best regards
    zeezoo
  • #3 9930456
    slawko_k
    Ocena: 234
    Gdzie znajduje się ten exe file from iPhone folder on your desktop? bo ja na pulpicie nie mam nic takiego.
  • #4 9933485
    zeezoo
    Ocena: 19
    To zalezy gdzie zainstalujesz. Standardowo jest to pulpit. Powinien byc tam folder "iPhone", a w nim EasyJailbreakBatch.exe i tego exe'ka uzywasz do uruchomienia programu.
    To najnowsza wersja upd8.exe, w ktorej jest instalator z mozliwoscia wyboru folderu, w ktorym chcesz zainstalowac aplikacje:
    http://www.mediafire.com/download.php?6uio2zc8ofotexo
    W razie problemow pisz.
    Pozdrowienia
    zeezoo
