00:00.0 Host bridge: Advanced Micro Devices [AMD] RS880 Host Bridge
Subsystem: Sony Corporation Device 9077
Flags: bus master, 66MHz, medium devsel, latency 0
Capabilities: [c4] HyperTransport: Slave or Primary Interface
Capabilities: [54] HyperTransport: UnitID Clumping
Capabilities: [40] HyperTransport: Retry Mode
Capabilities: [9c] HyperTransport: #1a
Capabilities: [f8] HyperTransport: #1c
00:01.0 PCI bridge: Sony Corporation Device 9602 (prog-if 00 [Normal decode])
Flags: bus master, 66MHz, medium devsel, latency 64
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000a000-0000afff
Memory behind bridge: d4100000-d42fffff
Prefetchable memory behind bridge: 00000000c0000000-00000000cfffffff
Capabilities: [44] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [b0] Subsystem: Sony Corporation Device 9077
Kernel modules: shpchp
00:04.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=02, subordinate=07, sec-latency=0
I/O behind bridge: 00006000-00009fff
Memory behind bridge: d3100000-d40fffff
Prefetchable memory behind bridge: 00000000d0000000-00000000d0ffffff
Capabilities: [50] Power Management version 3
Capabilities: [58] Express Root Port (Slot+), MSI 00
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [b8] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [110] Virtual Channel
Kernel driver in use: pcieport
00:07.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 3) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
Memory behind bridge: d3000000-d30fffff
00:11.0 SATA controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode] (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 11
I/O ports at b038
I/O ports at b04c
I/O ports at b030
I/O ports at b048
I/O ports at b010
Memory at d4308000 (32-bit, non-prefetchable)
Capabilities: [50] MSI: Enable+ Count=1/8 Maskable- 64bit+
Capabilities: [70] SATA HBA v1.0
Capabilities: [a4] PCI Advanced Features
Kernel driver in use: ahci
Kernel modules: ahci
00:12.0 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB OHCI0 Controller (prog-if 10 [OHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 10
Memory at d4307000 (32-bit, non-prefetchable)
Kernel driver in use: ohci_hcd
00:12.2 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB EHCI Controller (prog-if 20 [EHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 5
Memory at d4308600 (32-bit, non-prefetchable)
Capabilities: [c0] Power Management version 2
Capabilities: [e4] Debug port: BAR=1 offset=00e0
Kernel driver in use: ehci_hcd
00:13.0 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB OHCI0 Controller (prog-if 10 [OHCI])
Memory at d4306000 (32-bit, non-prefetchable)
00:13.2 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB EHCI Controller (prog-if 20 [EHCI])
Memory at d4308500 (32-bit, non-prefetchable)
00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 41)
Flags: 66MHz, medium devsel
Kernel driver in use: piix4_smbus
Kernel modules: sp5100_tco, i2c-piix4
00:14.1 IDE interface: ATI Technologies Inc SB7x0/SB8x0/SB9x0 IDE Controller (rev 40) (prog-if 8a [Master SecP PriP])
I/O ports at <unassigned>
I/O ports at b000
Capabilities: [70] MSI: Enable- Count=1/1 Maskable- 64bit-
Kernel driver in use: pata_atiixp
Kernel modules: pata_atiixp
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA) (rev 40)
Flags: bus master, slow devsel, latency 64, IRQ 7
Memory at d4300000 (64-bit, non-prefetchable)
Capabilities: [50] Power Management version 2
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
00:14.3 ISA bridge: ATI Technologies Inc SB7x0/SB8x0/SB9x0 LPC host controller (rev 40)
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge (rev 40) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=0a, subordinate=0a, sec-latency=64
00:14.5 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB OHCI2 Controller (prog-if 10 [OHCI])
Memory at d4305000 (32-bit, non-prefetchable)
00:15.0 PCI bridge: ATI Technologies Inc SB700/SB800/SB900 PCI to PCI bridge (PCIE port 0) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=0b, subordinate=10, sec-latency=0
I/O behind bridge: 00002000-00005fff
Memory behind bridge: d2000000-d2ffffff
Prefetchable memory behind bridge: 00000000d1000000-00000000d1ffffff
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [b0] Subsystem: ATI Technologies Inc Device 0000
00:16.0 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB OHCI0 Controller (prog-if 10 [OHCI])
Memory at d4304000 (32-bit, non-prefetchable)
00:16.2 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB EHCI Controller (prog-if 20 [EHCI])
Memory at d4308400 (32-bit, non-prefetchable)
00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor HyperTransport Configuration
Flags: fast devsel
Capabilities: [80] HyperTransport: Host or Secondary Interface
00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Address Map
Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor DRAM Controller
Flags: fast devsel
Kernel modules: amd64_edac_mod
00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Miscellaneous Control
Flags: fast devsel
Capabilities: [f0] Secure device <?>
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Link Control
Flags: fast devsel
01:05.0 VGA compatible controller: ATI Technologies Inc M880G [Mobility Radeon HD 4200] (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 10
Memory at c0000000 (32-bit, prefetchable)
I/O ports at a000
Memory at d4200000 (32-bit, non-prefetchable)
Memory at d4100000 (32-bit, non-prefetchable)
Kernel driver in use: fglrx_pci
Kernel modules: fglrx, radeon
01:05.1 Audio device: ATI Technologies Inc RS880 Audio Device [Radeon HD 4200]
Flags: bus master, fast devsel, latency 0, IRQ 11
Memory at d4210000 (32-bit, non-prefetchable)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
Flags: bus master, fast devsel, latency 0, IRQ 7
I/O ports at 6000
Memory at d0004000 (64-bit, prefetchable)
Memory at d0000000 (64-bit, prefetchable)
Expansion ROM at fffe0000 [disabled]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
Capabilities: [d0] Vital Product Data
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number 01-00-00-00-68-4c-e0-00
Kernel driver in use: r8169
Kernel modules: r8169
09:00.0 Network controller: Atheros Communications Inc. AR9285 Wireless Network Adapter (PCI-Express) (rev 01)
Subsystem: Foxconn International, Inc. Device e017
Memory at d3000000 (64-bit, non-prefetchable)
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [60] Express Legacy Endpoint, MSI 00
Capabilities: [160] Device Serial Number 00-15-17-ff-ff-24-14-12
Capabilities: [170] Power Budgeting <?>
Kernel driver in use: ath9k
Kernel modules: ath9k
