[Sprzedam] Drukarka mobilna Zebra RW420 z Bluetooth - tylko 2000 pln
spaced 24 Cze 2012 14:05 1433 0
  • #1 11036591
    spaced
    Nowa cena 1800 pln.
    Posiadam do sprzedania drukarkę mobilna Zebra RW420 z bluetooth
    Nieużywana, kila razy pokazywana w demonstracji.
    Mogę śmiało powiedziec ze jest nowa - dlatego wystawiam jako nowa.
    Zalega na półce wiec chce ja sprzedac.
    cena w sieci to ok 3500 pln
    moja cena do negocjacji!)
    parametry techniczne:
    Standard Features
    Print method: Direct thermal
    Construction: Impact-modified polycarbonate with fused oil-and-abrasion-resistant rubber overmold (six-foot drop protection)
    Smart battery management (monitors battery for longer life and performance)
    More Standard Features
    4 button angled LCD (standard)
    Resident scalable fonts
    Media sensors: Bar, gap
    Advanced 32 bit architecture for high-speed processing
    Standard Serial and USB interfaces
    Programming Language: Native CPCL, ZPL, EPL and XML support(standard)
    Auto-detect firmware load
    Printer Specifications
    Resolution 203 dpi (8 dots/mm)
    Memory
    8 MB Flash
    16 MB RAM
    Print width 4.09" (104 mm) maximum
    Print length Maximum print length at least 36" (914 mm) - actual length depends upon total memory usage
    Print speed 3" (76 mm)/sec
    Optional Features
    BT
    802.11b/g
    Dual radio
    Card readers
    Fanfold slot
    Media Characteristics
    Maximum label and liner width 4.12"/105 mm
    Minimum label and liner width 2"/51 mm
    Media width 2" x 4.12"
    Maximum roll diameter 2.25" (57 mm)
    Core diameter .75" (19 mm) or 1.38" (34.9 mm)
    Media thickness .002" (.05 mm) to .0063" (0.16 mm)
    Media types receipt, tag, gap, continuous receipt, continuous, linerless
    Operating Characteristics
    Operating temperature DT: Operating temperature -4° F (-20° C) to 131° F (55° C) Direct thermal
    Storage temperatures -22° F (-30° C) to 149° F (65° C)
    Operating humidity 10-90% non-condensing
    Storage humidity 10-90% non-condensing
    Electrical
    External charging options
    Shock mounted internal components
    Standard cable connection: RS-232, RJ-45 10 pin
    Selectable baud rate: 9600 to 115.2 Kbps
    Xon/Xoff or hardware flow control (RTS/CTS)
    USB full speed support, 12 Mbits/second
    Optional Bluetooth, 802.11g or 802.11b
    Lithium Ion
    4.0 Ah
    7.4 V
    Agency approvals
    FCC Part 15 Class B
    Canadian ICES-003
    VCCI
    NOM/NYCE
    CE compliance (Class B)
    C-Tick
    CSA
    Physical Characteristics
    Width 6.3" (160 mm)
    Height 6.9" (175 mm)
    Depth 3.0" (76 mm)
    Weight 2.0 lbs (0.907 kg)
    Orientation Center
    RELATED PRODUCTS
    Options
    Magnetic stripe reader and EMV™ level one certified smart card reader
    Lithium ion fast AC charger
    Lithium ion quad charger
    Lithium ion DC charger with cigarette lighter adapter
    Fanfold bin
    Vehicle cradle for docking and charging
    Ram mount kit
    Shoulder strap/ hand strap
    Environmental soft case
    Fanfold media support
    Linerless label support
    Wireless Security Support (ie. 802.11i, VPN, WPA or WPA2)
    Communication and Interface Capabilities
    Bluetooth v. 2.0, 802.11g or 802.11b (Optional)
    Standard USB 2.0 full speed
    PROGRAMMING LANGUAGES
    Core programming languages CPCL-native, ZPL, EPL, EPL2, XML
    Bar Codes/ Symbologies
    Linear Code 39
    Code 93
    UCC/EAN-128
    Code 128
    UPC-E
    UPC-A
    EAN-8
    EAN-13
    EAN-14
    UPC and EAN 2 or 5 digit extensions
    Plessey
    FIM
    Postnet
    Interleaved 2-of-5
    MSI
    Codabar
    2-dimensional PDF417
    Data Matrix
    MaxiCode
    RSS / GS1 DataBar family (12 barcodes)
    QR Code
    Fonts and Graphics
    Standard Fonts: 25 bitmapped, 1 smooth, scalable (CG Triumvirate Bold Condensed); Contains UFST from Agfa Monotype Corporation
    Optional Fonts: downloadable bitmapped and scalable fonts
    International Character Sets (optional):
    Chinese 16x16 (trad), 16x16 (simplified), 24x24 (simplified)
    Japanese 16x16, 24x24
    Hebrew/Arabic
    Supports user-defined fonts and graphics--including custom logos
    kontakt:
    spaced @ gmail. com
