Szczegółowy schemat gniazd telefonów 5110, T10 i A1018
sqnhead 11 Mar 2005 10:15 1065 2
  • #1 1305492
    sqnhead
    Ocena: 39
    Witam. Potrzebuje bardzo dokładny rozpis gniazd tych telefonów. konkretnie kazdego po kolei a nie tylko co można znaleśc gdzie sa TX RX i inne. Całe gniazdo mnie inetersuje.
    5110
    A1018
    T10
    saiblling
    Ocena: 3
    5110:
    1 VIN CHARGER INPUT VOLTAGE 8.4V 0.8A
    2 CHRG CTRL CHARGER CONTROL PWM 32Khz
    3 XMIC MIC INPUT 60mV - 1V
    4 SGND SIGNAL GROUND
    5 XEAR EAR OUTPUT 80mV - 1V
    6 MBUS 9600 B/S
    7 FBUS_RX 9.6 - 230.4 KB/S
    8 FBUS_TX 9.6 - 230.4 KB/S
    9 L_GND CHARGER / LOGIC GND
    T10s i A1018s:
    1 Audio Out
    2 Audio In
    3 Accessory Sense. GND to enable External Mic and Speaker (Analog)
    4 Audio Signal GND
    5 Portable handsfree In. Internal/external mic and ear (0=External - open=Internal)
    6 Music Mute Out, High when phone is used.
    7 In Flash Memory Voltage and Service Voltage,
    In 0V=normal,+5V=test, +12V=test+flash Test. Switch phone off and provide +5V and switch back on. (set comms at 9600, n,8,1)
    8 Logic Out, Status On. Sources over 100mA. +5V output
    9 TX (Data Out) from Mobile Station. Debug messages appear here at 112KBaud when in debug mode. TTL
    10 Digital Ground and DC return
    11 Rx (Data in) TTL
    12 DC in for battery charging, DC out for accessory power + external power supply 7.2Volt - 600mA
