Zawatrość pliku hs_err_pid528 to :
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000084c1, pid=528, tid=1736
# JRE version: Java(TM) SE Runtime Environment (7.0_51-b13) (build 1.7.0_51-b13)
# Java VM: Java HotSpot(TM) Client VM (24.51-b03 mixed mode, sharing windows-x86 )
# Problematic frame:
# C 0x000084c1
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0085a800): JavaThread "Minecraft main thread" [_thread_in_native, id=1736, stack(0x00940000,0x00990000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x000084c1
Registers:
EAX=0x00000000, EBX=0x00000000, ECX=0x694bb870, EDX=0x000001c0
ESP=0x0098f840, EBP=0x0098f878, ESI=0x0098f864, EDI=0x100088ab
EIP=0x000084c1, EFLAGS=0x00010202
Top of Stack: (sp=0x0098f840)
0x0098f840: 0085a930 0098f864 000084c1 43500000
0x0098f850: 43600000 69345e70 00000000 00000000
0x0098f860: 1fa41628 1f3eebe0 0000000e bff9eb85
0x0098f870: 1f3d4d90 0098f898 0098fa9c 00d9b0cc
0x0098f880: 69345e70 00000000 00000000 3f800000
0x0098f890: 167d45c8 ffffff80 1566e2c8 1566e2d8
0x0098f8a0: 00000020 40204d00 00000000 40204000
0x0098f8b0: 20000000 40435137 1ed64320 40438cdd
Instructions: (pc=0x000084c1)
0x000084a1:
[error occurred during error reporting (printing registers, top of stack, instructions near pc), id 0xc0000005]
Register to memory mapping:
EAX=0x00000000 is an unknown value
EBX=0x00000000 is an unknown value
ECX=0x694bb870 is an unknown value
EDX=0x000001c0 is an unknown value
ESP=0x0098f840 is pointing into the stack for thread: 0x0085a800
EBP=0x0098f878 is pointing into the stack for thread: 0x0085a800
ESI=0x0098f864 is pointing into the stack for thread: 0x0085a800
EDI=0x100088ab is an unknown value
Stack: [0x00940000,0x00990000], sp=0x0098f840, free space=318k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x000084c1
J bjd.a(Lasp;F)V
j bfe.b(F)V+510
J atv.S()V
j net.minecraft.client.main.Main.main([Ljava/lang/String;)V+768
v ~StubRoutines::call_stub
V [jvm.dll+0x13f35a]
V [jvm.dll+0x202c6e]
V [jvm.dll+0x13f3dd]
V [jvm.dll+0xc9945]
V [jvm.dll+0xd45e7]
C [javaw.exe+0x2070]
C [javaw.exe+0xa5b1]
C [javaw.exe+0xa63b]
C [kernel32.dll+0xb729]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J org.lwjgl.opengl.GL13.nglMultiTexCoord2f(IFFJ)V
J bjd.a(Lasp;F)V
J bfl.a(Latc;Lbft;F)V
j bfe.a(FJ)V+658
j bfe.b(F)V+510
J atv.S()V
j atv.d()V+88
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x40b99c00 JavaThread "Client write thread" [_thread_blocked, id=3724, stack(0x127c0000,0x12810000)]
0x41292400 JavaThread "Client read thread" [_thread_in_native, id=3728, stack(0x12770000,0x127c0000)]
0x41610800 JavaThread "Thread-11" daemon [_thread_in_native, id=816, stack(0x12720000,0x12770000)]
0x10340800 JavaThread "LWJGL Timer" daemon [_thread_blocked, id=3556, stack(0x12630000,0x12680000)]
0x10067c00 JavaThread "Thread-6" [_thread_blocked, id=4020, stack(0x0fe90000,0x0fee0000)]
0x100b8000 JavaThread "Thread-5" [_thread_blocked, id=2568, stack(0x0fe40000,0x0fe90000)]
0x031a5400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=1644, stack(0x0b300000,0x0b350000)]
0x0312a800 JavaThread "Timer hack thread" daemon [_thread_blocked, id=2984, stack(0x0b2b0000,0x0b300000)]
0x030ebc00 JavaThread "Snooper Timer" daemon [_thread_blocked, id=3784, stack(0x0b260000,0x0b2b0000)]
0x02ad1800 JavaThread "Service Thread" daemon [_thread_blocked, id=2576, stack(0x02f50000,0x02fa0000)]
0x02acbc00 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=496, stack(0x02f00000,0x02f50000)]
0x02aca000 JavaThread "Attach Listener" daemon [_thread_blocked, id=1832, stack(0x02eb0000,0x02f00000)]
0x02ac8c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4068, stack(0x02e60000,0x02eb0000)]
0x02a61000 JavaThread "Finalizer" daemon [_thread_blocked, id=2376, stack(0x02e10000,0x02e60000)]
0x02a5c000 JavaThread "Reference Handler" daemon [_thread_blocked, id=2384, stack(0x02dc0000,0x02e10000)]
=>0x0085a800 JavaThread "Minecraft main thread" [_thread_in_native, id=1736, stack(0x00940000,0x00990000)]
Other Threads:
0x02a5a400 VMThread [stack: 0x02d70000,0x02dc0000] [id=2284]
0x02ae5000 WatcherThread [stack: 0x02fa0000,0x02ff0000] [id=3708]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 60160K, used 47307K [0x12b40000, 0x16c80000, 0x1d5e0000)
eden space 53504K, 83% used [0x12b40000, 0x156a3d20, 0x15f80000)
from space 6656K, 43% used [0x16600000, 0x168cf1a8, 0x16c80000)
to space 6656K, 0% used [0x15f80000, 0x15f80000, 0x16600000)
tenured generation total 133496K, used 53987K [0x1d5e0000, 0x2583e000, 0x32b40000)
the space 133496K, 40% used [0x1d5e0000, 0x20a98f18, 0x20a99000, 0x2583e000)
compacting perm gen total 12288K, used 9562K [0x32b40000, 0x33740000, 0x36b40000)
the space 12288K, 77% used [0x32b40000, 0x334968b0, 0x33496a00, 0x33740000)
ro space 10240K, 41% used [0x36b40000, 0x36f72050, 0x36f72200, 0x37540000)
rw space 12288K, 52% used [0x37540000, 0x37b86800, 0x37b86800, 0x38140000)
Card table byte_map: [0x02b40000,0x02c70000] byte_map_base: 0x02aaa600
Polling page: 0x00990000
Code Cache [0x009c0000, 0x00f80000, 0x029c0000)
total_blobs=2688 nmethods=2348 adapters=275 free_code_cache=26885Kb largest_free_block=27527424
Compilation events (10 events):
Event: 65.753 Thread 0x02acbc00 2388 ! paulscode.sound.SoundSystem::playing (54 bytes)
Event: 65.754 Thread 0x02acbc00 nmethod 2388 0x00f7d788 code [0x00f7d8c0, 0x00f7dbd8]
Event: 65.804 Thread 0x02acbc00 2389 abw::a (423 bytes)
Event: 65.807 Thread 0x02acbc00 nmethod 2389 0x00f7ddc8 code [0x00f7e050, 0x00f7e4e0]
Event: 65.994 Thread 0x02acbc00 2390 nn::e (1 bytes)
Event: 65.995 Thread 0x02acbc00 nmethod 2390 0x00f7e848 code [0x00f7e940, 0x00f7e9c0]
Event: 66.047 Thread 0x02acbc00 2391 ! java.nio.charset.CharsetEncoder::encode (285 bytes)
Event: 66.050 Thread 0x02acbc00 nmethod 2391 0x00f7ea08 code [0x00f7eba0, 0x00f7f020]
Event: 66.351 Thread 0x02acbc00 2392 nn::S (7 bytes)
Event: 66.352 Thread 0x02acbc00 nmethod 2392 0x00f7f508 code [0x00f7f610, 0x00f7f6a0]
GC Heap History (10 events):
Event: 45.983 GC heap before
{Heap before GC invocations=85 (full 11):
def new generation total 69504K, used 17934K [0x12b40000, 0x176a0000, 0x1d5e0000)
eden space 61824K, 23% used [0x12b40000, 0x13939fe0, 0x167a0000)
from space 7680K, 47% used [0x16f20000, 0x172a9a40, 0x176a0000)
to space 7680K, 0% used [0x167a0000, 0x167a0000, 0x16f20000)
tenured generation total 154236K, used 57787K [0x1d5e0000, 0x26c7f000, 0x32b40000)
the space 154236K, 37% used [0x1d5e0000, 0x20e4ee60, 0x20e4f000, 0x26c7f000)
compacting perm gen total 12288K, used 9532K [0x32b40000, 0x33740000, 0x36b40000)
the space 12288K, 77% used [0x32b40000, 0x3348f388, 0x3348f400, 0x33740000)
Event: 46.161 GC heap after
Heap after GC invocations=86 (full 12):
def new generation total 64064K, used 0K [0x12b40000, 0x170c0000, 0x1d5e0000)
eden space 56960K, 0% used [0x12b40000, 0x12b40000, 0x162e0000)
from space 7104K, 0% used [0x162e0000, 0x162e0000, 0x169d0000)
to space 7104K, 0% used [0x169d0000, 0x169d0000, 0x170c0000)
tenured generation total 142204K, used 37244K [0x1d5e0000, 0x260bf000, 0x32b40000)
the space 142204K, 26% used [0x1d5e0000, 0x1fa3f3f8, 0x1fa3f400, 0x260bf000)
compacting perm gen total 12288K, used 9531K [0x32b40000, 0x33740000, 0x36b40000)
the space 12288K, 77% used [0x32b40000, 0x3348eff8, 0x3348f000, 0x33740000)
Event: 46.603 GC heap before
{Heap before GC invocations=86 (full 12):
def new generation total 64064K, used 14567K [0x12b40000, 0x170c0000, 0x1d5e0000)
eden space 56960K, 25% used [0x12b40000, 0x13979ef0, 0x162e0000)
Event: 46.739 GC heap after
Heap after GC invocations=87 (full 13):
def new generation total 60160K, used 0K [0x12b40000, 0x16c80000, 0x1d5e0000)
eden space 53504K, 0% used [0x12b40000, 0x12b40000, 0x15f80000)
from space 6656K, 0% used [0x15f80000, 0x15f80000, 0x16600000)
to space 6656K, 0% used [0x16600000, 0x16600000, 0x16c80000)
tenured generation total 133496K, used 40048K [0x1d5e0000, 0x2583e000, 0x32b40000)
the space 133496K, 29% used [0x1d5e0000, 0x1fcfc0b0, 0x1fcfc200, 0x2583e000)
Event: 48.460 GC heap before
{Heap before GC invocations=87 (full 13):
def new generation total 60160K, used 53041K [0x12b40000, 0x16c80000, 0x1d5e0000)
eden space 53504K, 99% used [0x12b40000, 0x15f0c560, 0x15f80000)
the space 12288K, 77% used [0x32b40000, 0x3348f018, 0x3348f200, 0x33740000)
Event: 48.481 GC heap after
Heap after GC invocations=88 (full 13):
def new generation total 60160K, used 6656K [0x12b40000, 0x16c80000, 0x1d5e0000)
from space 6656K, 100% used [0x16600000, 0x16c80000, 0x16c80000)
tenured generation total 133496K, used 42998K [0x1d5e0000, 0x2583e000, 0x32b40000)
the space 133496K, 32% used [0x1d5e0000, 0x1ffdd9a0, 0x1ffdda00, 0x2583e000)
Event: 50.715 GC heap before
{Heap before GC invocations=88 (full 13):
def new generation total 60160K, used 60160K [0x12b40000, 0x16c80000, 0x1d5e0000)
eden space 53504K, 100% used [0x12b40000, 0x15f80000, 0x15f80000)
compacting perm gen total 12288K, used 9561K [0x32b40000, 0x33740000, 0x36b40000)
the space 12288K, 77% used [0x32b40000, 0x33496480, 0x33496600, 0x33740000)
Event: 50.737 GC heap after
Heap after GC invocations=89 (full 13):
def new generation total 60160K, used 4595K [0x12b40000, 0x16c80000, 0x1d5e0000)
from space 6656K, 69% used [0x15f80000, 0x163fcf60, 0x16600000)
tenured generation total 133496K, used 49576K [0x1d5e0000, 0x2583e000, 0x32b40000)
the space 133496K, 37% used [0x1d5e0000, 0x2064a1d8, 0x2064a200, 0x2583e000)
Event: 59.792 GC heap before
{Heap before GC invocations=89 (full 13):
def new generation total 60160K, used 45778K [0x12b40000, 0x16c80000, 0x1d5e0000)
eden space 53504K, 76% used [0x12b40000, 0x15377bf0, 0x15f80000)
the space 12288K, 77% used [0x32b40000, 0x33496840, 0x33496a00, 0x33740000)
Event: 59.815 GC heap after
Heap after GC invocations=90 (full 13):
def new generation total 60160K, used 2876K [0x12b40000, 0x16c80000, 0x1d5e0000)
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 66.213 Thread 0x40b99c00 Threw 0x155dd700 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:2965
Event: 66.218 Thread 0x100b8000 Threw 0x155db2e0 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:2965
Event: 66.258 Thread 0x100b8000 Threw 0x155db480 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:2965
Event: 66.258 Thread 0x40b99c00 Threw 0x155dd888 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:2965
Event: 66.258 Thread 0x100b8000 Threw 0x155dc0d8 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:2917
Event: 66.259 Thread 0x40b99c00 Threw 0x155dda10 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:2917
Event: 66.261 Thread 0x100b8000 Threw 0x155dc238 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:2965
Event: 66.310 Thread 0x40b99c00 Threw 0x155ddb98 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:2965
Event: 66.311 Thread 0x100b8000 Threw 0x155dc3d8 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:2965
Event: 66.312 Thread 0x100b8000 Threw 0x155dc578 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:2917
Events (10 events):
Event: 57.997 Thread 0x41cc9400 Thread exited: 0x41cc9400
Event: 59.792 Executing VM operation: GenCollectForAllocation
Event: 59.815 Executing VM operation: GenCollectForAllocation done
Event: 62.133 Thread 0x40bd8c00 Thread added: 0x40bd8c00
Event: 62.157 Executing VM operation: RevokeBias
Event: 62.157 Executing VM operation: RevokeBias done
Event: 62.157 Thread 0x40bd8c00 Thread exited: 0x40bd8c00
Event: 62.990 Executing VM operation: RevokeBias
Event: 62.990 Executing VM operation: RevokeBias done
Event: 62.990 Thread 0x4111a400 Thread exited: 0x4111a400
Dynamic libraries:
0x00400000 - 0x0042f000 C:\Program Files\Java\jre7\bin\javaw.exe
0x7c900000 - 0x7c9b4000 C:\WINDOWS.0\system32\ntdll.dll
0x7c800000 - 0x7c8fd000 C:\WINDOWS.0\system32\kernel32.dll
0x77dc0000 - 0x77e6c000 C:\WINDOWS.0\system32\ADVAPI32.dll
0x77e70000 - 0x77f03000 C:\WINDOWS.0\system32\RPCRT4.dll
0x77fe0000 - 0x77ff1000 C:\WINDOWS.0\system32\Secur32.dll
0x7e360000 - 0x7e403000 C:\WINDOWS.0\system32\USER32.dll
0x77f10000 - 0x77f59000 C:\WINDOWS.0\system32\GDI32.dll
0x773c0000 - 0x774c3000 C:\WINDOWS.0\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\COMCTL32.dll
0x77c00000 - 0x77c58000 C:\WINDOWS.0\system32\msvcrt.dll
0x77f60000 - 0x77fd6000 C:\WINDOWS.0\system32\SHLWAPI.dll
0x76360000 - 0x7637d000 C:\WINDOWS.0\system32\IMM32.DLL
0x78aa0000 - 0x78b5f000 C:\Program Files\Java\jre7\bin\msvcr100.dll
0x6e770000 - 0x6eaf0000 C:\Program Files\Java\jre7\bin\client\jvm.dll
0x71a70000 - 0x71a7a000 C:\WINDOWS.0\system32\WSOCK32.dll
0x71a50000 - 0x71a67000 C:\WINDOWS.0\system32\WS2_32.dll
0x71a40000 - 0x71a48000 C:\WINDOWS.0\system32\WS2HELP.dll
0x76b20000 - 0x76b4e000 C:\WINDOWS.0\system32\WINMM.dll
0x76be0000 - 0x76beb000 C:\WINDOWS.0\system32\PSAPI.DLL
0x6bd00000 - 0x6bd0d000 C:\WINDOWS.0\system32\SYNCOR11.DLL
0x6e6c0000 - 0x6e6cc000 C:\Program Files\Java\jre7\bin\verify.dll
0x6d480000 - 0x6d4a0000 C:\Program Files\Java\jre7\bin\java.dll
0x6e750000 - 0x6e763000 C:\Program Files\Java\jre7\bin\zip.dll
0x10000000 - 0x1004c000 C:\Documents and Settings\Administrator\Dane aplikacji\.minecraft\versions\1.6.4\1.6.4-natives-2821997715131\lwjgl.dll
0x5f190000 - 0x5f25c000 C:\WINDOWS.0\system32\OPENGL32.dll
0x5c8f0000 - 0x5c911000 C:\WINDOWS.0\system32\GLU32.dll
0x736f0000 - 0x7373b000 C:\WINDOWS.0\system32\DDRAW.dll
0x73b50000 - 0x73b56000 C:\WINDOWS.0\system32\DCIMAN32.dll
0x77bf0000 - 0x77bf8000 C:\WINDOWS.0\system32\VERSION.dll
0x68000000 - 0x68036000 C:\WINDOWS.0\system32\rsaenh.dll
0x769a0000 - 0x76a5b000 C:\WINDOWS.0\system32\USERENV.dll
0x6ff40000 - 0x6ff96000 C:\WINDOWS.0\system32\netapi32.dll
0x6e4b0000 - 0x6e4c4000 C:\Program Files\Java\jre7\bin\net.dll
0x719f0000 - 0x71a30000 C:\WINDOWS.0\System32\mswsock.dll
0x76f10000 - 0x76f37000 C:\WINDOWS.0\system32\DNSAPI.dll
0x76d50000 - 0x76d69000 C:\WINDOWS.0\system32\iphlpapi.dll
0x76fa0000 - 0x76fa8000 C:\WINDOWS.0\System32\winrnr.dll
0x76f50000 - 0x76f7d000 C:\WINDOWS.0\system32\WLDAP32.dll
0x76fb0000 - 0x76fb6000 C:\WINDOWS.0\system32\rasadhlp.dll
0x6e4d0000 - 0x6e4df000 C:\Program Files\Java\jre7\bin\nio.dll
0x6d000000 - 0x6d143000 C:\Program Files\Java\jre7\bin\awt.dll
0x77110000 - 0x7719b000 C:\WINDOWS.0\system32\OLEAUT32.dll
0x774d0000 - 0x7760e000 C:\WINDOWS.0\system32\ole32.dll
0x5b1d0000 - 0x5b208000 C:\WINDOWS.0\system32\uxtheme.dll
0x75180000 - 0x751ae000 C:\WINDOWS.0\system32\msctfime.ime
0x69000000 - 0x694e2000 C:\WINDOWS.0\system32\atioglxx.dll
0x73ac0000 - 0x73ad5000 C:\WINDOWS.0\system32\mscms.dll
0x72f90000 - 0x72fb6000 C:\WINDOWS.0\system32\WINSPOOL.DRV
0x5e260000 - 0x5e2a1000 C:\WINDOWS.0\system32\icm32.dll
0x0fee0000 - 0x0ff45000 C:\Documents and Settings\Administrator\Dane aplikacji\.minecraft\versions\1.6.4\1.6.4-natives-2821997715131\OpenAL32.dll
0x7c9c0000 - 0x7d1df000 C:\WINDOWS.0\system32\SHELL32.dll
0x76fc0000 - 0x7703f000 C:\WINDOWS.0\system32\CLBCATQ.DLL
0x11c70000 - 0x11dcf000 C:\WINDOWS.0\system32\COMRes.dll
0x73ea0000 - 0x73efc000 C:\WINDOWS.0\system32\dsound.dll
0x76c20000 - 0x76c4e000 C:\WINDOWS.0\system32\WINTRUST.dll
0x11ed0000 - 0x11f68000 C:\WINDOWS.0\system32\CRYPT32.dll
0x0ff90000 - 0x0ffa2000 C:\WINDOWS.0\system32\MSASN1.dll
0x76c80000 - 0x76ca9000 C:\WINDOWS.0\system32\IMAGEHLP.dll
0x72cb0000 - 0x72cb9000 C:\WINDOWS.0\system32\wdmaud.drv
0x72ca0000 - 0x72ca8000 C:\WINDOWS.0\system32\msacm32.drv
0x77bd0000 - 0x77be5000 C:\WINDOWS.0\system32\MSACM32.dll
0x77bc0000 - 0x77bcd000 C:\WINDOWS.0\system32\midimap.dll
0x5ef80000 - 0x5ef84000 C:\WINDOWS.0\system32\KsUser.dll
0x6e640000 - 0x6e660000 C:\Program Files\Java\jre7\bin\sunec.dll
0x6e660000 - 0x6e669000 C:\Program Files\Java\jre7\bin\sunmscapi.dll
0x66780000 - 0x667de000 C:\WINDOWS.0\system32\hnetcfg.dll
0x71a30000 - 0x71a38000 C:\WINDOWS.0\System32\wshtcpip.dll
0x6e410000 - 0x6e41a000 C:\Program Files\Java\jre7\bin\management.dll
0x59bc0000 - 0x59c61000 C:\WINDOWS.0\system32\dbghelp.dll
VM Arguments:
jvm_args: -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M -Djava.library.path=C:\Documents and Settings\Administrator\Dane aplikacji\.minecraft\versions\1.6.4\1.6.4-natives-2821997715131
java_command: net.minecraft.client.main.Main --username Krwisty010 --session - --version 1.6.4 --gameDir C:\Documents and Settings\Administrator\Dane aplikacji\.minecraft --assetsDir C:\Documents and Settings\Administrator\Dane aplikacji\.minecraft\assets\virtual\legacy
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\WINDOWS.0\system32;C:\WINDOWS.0;C:\WINDOWS.0\System32\Wbem;C:\Program Files\Alky for Applications\Libraries\;C:\Program Files\ATI Technologies\ATI Control Panel;C:\Program Files\Java\jre7\bin
USERNAME=Administrator
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 3 Stepping 4, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Dodatek Service Pack 3
CPU:total 2 (1 cores per cpu, 2 threads per core) family 15 model 3 stepping 4, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ht, tsc
Memory: 4k page, physical 2095916k(990532k free), swap 4037328k(2939440k free)
vm_info: Java HotSpot(TM) Client VM (24.51-b03) for windows-x86 JRE (1.7.0_51-b13), built on Dec 18 2013 19:09:58 by "java_re" with unknown MS VC++:1600
time: Sun Mar 02 10:52:36 2014
elapsed time: 66 seconds"
