ADP 5600 – 8 mignięć kontrolki CANCEL, co oznacza ten błąd i jak go skasować?
domis33 22 Wrz 2014 12:50 4404 13
  • #1 13981014
    domis33
    Ocena: 220
    Czy ktoś wie co to oznacza? Jak skasować ten błąd ?
    Miga kontrolka oznaczona CANCEL
    pozdrawiam czekam na podpowiedż.
  • #2 13981108
    Darkdarkman
    Poziom 30  
    Ocena: 253
    Google nie gryzą i jest w nich wszystko.
    Whirlpool Dishwasher Error codes.
    F0. 10 flashes. Sensor Break (Only shown in test programme. Not visible to customer).
    F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
    F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
    F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
    F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
    F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
    F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
    Water Valve Closed. Water inlet hose blocked.
    Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
    F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
    F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
    F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
    FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
    FB. 12 Flashes. Motorised Diverter Valve
    FC. 13 Flashes. Water Hardness Sensor Failure
    Czyli po naszemu - brudny filtr (sitko) wody czystej.
    Może też chodzić o słabe ciśnienie wody w rurach.
  • #3 13981314
    domis33
    Ocena: 220
    Kolego dzięki za podpowiedz a może wiesz jak skasować ten błąd bo zmywarka nie przyjmuje żadnej komendy.
  • #4 13981322
    Darkdarkman
    Poziom 30  
    Ocena: 253
    Trzeba usunąć przyczynę.
    Potem powinno samo zniknąć.
  • #5 13981343
    domis33
    Ocena: 220
    Sitka czyste ciśnienie wody dobre i dalej to samo miga kontrolka osiem razy przerwa
    i znowu miga - nic nie mogę ustawić innego.
    Zawór też sprawdziłem -jest ok.
  • #6 13981350
    Darkdarkman
    Poziom 30  
    Ocena: 253
    Widzisz, radzę Ci tutaj, a sam źle zinterpretowałem opis błędu.
    Nie chodzi o dostarczanie wody z wodociągu, a o przepływ przez natryśnice.
    Oglądnij otwory w natryśnicach czy czasami jakieś resztki ich nie blokują.
    Może spróbować je czymś ostrym otworzyć.
    Dodatkowo wyczyść porządnie filtr na dnie.
  • #7 13981541
    domis33
    Ocena: 220
    Kolego dzięki za podpowiedzi ale cały czas jest problem
    jak skasować ten błąd żeby programator zaczął ŻYĆ
  • #8 13981562
    Darkdarkman
    Poziom 30  
    Ocena: 253
    Więcej nie pomogę :)
    Być może przyczyna leży w czujniku poziomu wody, który prawdopodobnie jest pod sitkiem od odpływu, ale to taka zgadywanka już.
  • #9 13981588
    domis33
    Ocena: 220
    Dzięki ale w tej zmywarce nie ma czujnika poziomu wody ani czujnika wody na dnie
  • #10 13981999
    gumasek
    Ocena: 112
    Witam. Twój typ zmywarki ma inną tabelę błędów niż kolega powyżej napisał. Zmywarka powinna ci zamigać te 8 razy przerwa i powinny być kolejne mignięcia np. 8 - 1 lub 8 -2 lub 8-3 .
    A jeśli chodzi o skasowanie błędu to naciśnij przycisk CANCEL i poczekaj aż dioda zgaśnie albo włącz program testowy.
  • #11 13982291
    domis33
    Ocena: 220
    Witam kolego.
    Na przycisk CANCEL dłuższe przytrzymanie nie reaguje - jak uruchomić program testowy ?
    gumasek
    Ocena: 112
    Przytrzymujesz przycisk wyboru programu aż się zapali kilka lampek. Trzymając dalej przycisk naciskasz 1 raz przycisk start i powinna tylko 1 dioda się palić. Puszczasz przycisk programu i naciskasz start i program powinien ruszyć. Test trwa około 5 min. Jeśli zacznie migać na koniec to policz ile razy i na pewno to będę dwie serie migania.
    Mam nadzieję że jest to jakoś zrozumiałe .
  • #13 13982419
    domis33
    Ocena: 220
    Dzięki jutro z rana sprawdzę
  • #14 13984413
    domis33
    Ocena: 220
    Dzięki kolego "gumasek" Jesteś WIELKI !!!
    Program testowy ruszył i zmywarka też. Nie pokazała żadnych błędów ale działa dobrze.
    Zamykam temat
Użytkownik zgłosił problem z zmywarką ADP 5600, która miga kontrolką CANCEL osiem razy, co wskazuje na błąd. W odpowiedziach zasugerowano, że przyczyną może być brudny filtr wody lub zablokowane natryśnice. Użytkownik potwierdził, że filtr jest czysty, a ciśnienie wody jest dobre. W końcu, po wskazówkach dotyczących uruchomienia programu testowego, zmywarka zaczęła działać poprawnie, nie pokazując żadnych błędów.
