Witam, chciałbym aby ktoś mi pomógł dostosować się do tych wskazówek. Niestety moja wiedza komputerowa i znajomość angielskiego nie jest wystarczająca.
"Windows 8 Users: You will need to Disable Driver Signature Enforcement between installing the PowerXpress fix Driver.
+ Disable Secure Boot (In the motherboard's UEFI firmware settings, click/tap on the Security menu, select the Secure Boot option, and click/tap/press Enter to enable or disable it.)
The TESTSIGNING boot configuration option is enabled or disabled through the BCDEdit command. To enable test-signing, use the following BCDEdit command:
Bcdedit.exe -set TESTSIGNING ON
To disable test-signing, use the following BCDEdit command:
Bcdedit.exe -set TESTSIGNING OFF
Note After you change the TESTSIGNING boot configuration option, restart the computer for the change to take effect.
To use BCDEdit, you must be a member of the Administrators group on the system and run the command from an elevated command prompt. To open an elevated Command Prompt window, create a desktop shortcut to Cmd.exe, right-click the Cmd.exe shortcut, and select Run as administrator."
Mógłby ktoś mi pomóc krok po kroku? Lenovo g500, Windows 8.1 64
Konkretniej próbuję zainstalować ten fix
Link
Link
