Jak usunąć wirusa W32.Gaobot.SN z pliku C:WINNTsystem32msgfix.exe?
maciejsekula 21 Maj 2005 19:46 1193 3
  • #1 1513594
    maciejsekula
    Cześć!! Mama taki problem antywirus wykrył mi taki wirus "W32.Gaobot.SN" i ma prośbę aby ktoś powiedział mi jaki to wirus i jak go usunąć z mojego dysku a, powiem tez ze on się znajduje w takim pliku:"C:\WINNT\system32\msgfix.exe" dzięki za pomoc!!!!1:)
  • #3 1513636
    invx
    Ocena: 102
    When W32.Gaobot.SN is executed, it performs the following actions:
    Registers itself as a service. This will cause it to keep running even if you log off.
    Creates the mutex "Moo" so that only one instance of the worm runs at once.
    Copies itself to one of the following locations:
    %System%\Msnss.exe
    %System%\Msgfix.exe
    Note: %System% is a variable. The worm locates the System folder and copies itself to that location. By default, this is C:\Windows\System (Windows 95/98/Me), C:\Winnt\System32 (Windows NT/2000), or C:\Windows\System32 (Windows XP).
    Adds one of these values:
    "Configuration Loader" = "msnss.exe"
    "Configuration Loader" = "msgfix.exe"
    to these registry keys:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    RunServices
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    so that the worm runs when you start Windows.
    Locates users on the network. Then, it uses a pre-defined set of passwords to try to log onto the network's shared resources. If it succeeds, then it will copy itself to the following locations:
    IPC$\msgfix.exe
    D$\msgfix.exe
    print$\msgfix.exe
    c$\msgfix.exe
    Admin$\msgfix.exe
    c$\windows\system32\msgfix.exe
    c$\winnt\system32\msgfix.exe
    Admin$\system32\msgfix.exe
    Scans for computers that are infected by Mydoom variants. If it finds any, it will copy itself to them as Msgfix.exe. Then, it uses the backdoor component of Mydoom to executes the file.
    Allows attackers to use a predetermined IRC channel to access the infected computer. The attacker can perform any of these actions:
    Download and execute files
    Scan the network
    List, stop, and start processes
    Control the file system (Delete, create, and list files)
    Launch Denial of Service (DoS) attacks
    Perform port redirection
    Steal system information and send it to the attacker using email
    Seals CD keys of the following popular games:
    Command & Conquer Generals
    FIFA 2003
    Need For Speed Hot Pursuit 2
    Soldier of Fortune II - Double Helix
    Neverwinter
    Rainbow Six III RavenShield
    Battlefield 1942 Road To Rome
    Project IGI 2
    Counter-Strike
    Unreal Tournament 2003
    Half-Life
    Również znany jako: W32.Gaobot
    Typ: robak
    Długość: 100352
    Niszczący dyski: nie
    Niszczący pliki: nie
    Efekty wizualne: nie
    Efekty dźwiękowe: nie
    Gaobot jest robakiem sieciowym, którego działanie polega na rozprzestrzenianiu się w sieciach lokalnych oraz poprzez IRCa.
    Po uruchomieniu przez użytkownika pliku załącznika robak tworzy na dysku swoje kopie w plikach: Svchosl.exe, Winhlpp32.exe oraz modyfikuje tak rejestr by jego kopia była uruchamiana przy każdym starcie systemu Windows.
    Aktywny trojan nasłuchuje na losowo wybranym porcie na komendy od swojego autora pozwalające na przejęcie kontroli nad komputerem ofiary poprzez sieć.
    Podobnie robak łączy się z kanałem IRCa, na którym nasłuchuje na komendy od swojego autora.
    Na koniec robak tworzy swoje kopie na udostępnionych zasobach sieciowych w sieci lokalnej.
    EDIT:
    spuznilem sie ... ale juz zostawie...
