Toshiba - Potrzebny full firmware Toshiba 32d1334dg 17mb95s-1
piotreksamba 11 Lis 2020 08:48 1536 4
  • #1 19036112
    piotreksamba
    Ocena: 155
    Szukam full firmware Toshiba 32d1334dg 17mb95s-1 panel ves315wndl-01
  • #3 19036367
    piotreksamba
    Ocena: 155
    This model is combo dvd. Toshiba's website has incomplete software. I need with mboo.bin and txt.
  • #4 19036371
    billobirillo
    Poziom 33  
    Ocena: 776
    percoco2000 napisał:
    Cannot found info on that TV. Are you sure of the model?
    Maybe is 32L1334DG? In that case here is the firmware from manufacturer
    http://www.dl.toshiba.com/dtv/NA/GB/EN/32L1343DG.html
    this is only an update, not the full software
    post a photo of the label on the back of the tv
  • #5 19036414
    piotreksamba
    Ocena: 155
    Model and main
    • Toshiba - Potrzebny full firmware Toshiba 32d1334dg 17mb95s-1 IMG_20201111_114613.jpg (2.35 MB) Musisz być zalogowany, aby pobrać ten załącznik.
    • Toshiba - Potrzebny full firmware Toshiba 32d1334dg 17mb95s-1 IMG_20201111_114627.jpg (2.14 MB) Musisz być zalogowany, aby pobrać ten załącznik.
