MIKROTIK RB941 - Błąd pętli na porcie eth4 i problem z DHCP, CAPSMAN, adres DC:XX:B7, SW ID: 6,49,7
likierpp 28 Mar 2023 14:14 663 2
  • #1 20512484
    likierpp
    znajomy poprosił mnie o rzucenie okiem na jego internet... problem z miktorikiem rb941.
    na porcie eth4 występuje błąd: interface,warning ether4 received loop protect pack
    et originated from Dc:XX:B7 (ether4)
    inne urządzenia zarządzane przez capsman.
    z tego co widzę urządzenie na porcie eth4 komunikuje się z innymi urządzeniami, ale odnajduje tam też swoje pakiety, pętla zostaje wykryta i port pada.. nie wiem czemu mikrotiki nie chcą przyjąć ip z serwera dhcp.
    adres Dc:XX:B7 to dokładnie port eht4.
    co robić?!
    # software id = 6,49,7
    # model = RB941-2nD
    # serial number = FDFDFDFDFDFDFD
    /caps-man channel
    add band=2ghz-g/n control-channel-width=20mhz frequency=2412,2437,2462 name=\
    3kanaly1_6_11
    add band=2ghz-b/g/n frequency=2412 name=channel1
    add band=2ghz-b/g/n frequency=2437 name=channel6
    add band=2ghz-b/g/n frequency=2462 name=channel11
    /interface bridge
    add admin-mac=6C:3B:XX:XX:2A:97 auto-mac=no name=bridgeADMIN
    add mtu=1500 name=bridgeKLIENT
    /interface wireless
    # managed by CAPsMAN
    set [ find default-name=wlan1 ] band=2ghz-b/g/n mode=ap-bridge ssid=MikroTikA
    /interface ethernet
    set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full comment=WAN \
    name=ether1-WAN
    set [ find default-name=ether2 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full loop-protect=\
    on
    set [ find default-name=ether3 ] comment="Siec klient"
    # 2023.03.28-12:29:19: received loop protect packet originated from Dc:XX:B7 (ether4)
    set [ find default-name=ether4 ] loop-protect=on
    /caps-man datapath
    add bridge=bridgeADMIN client-to-client-forwarding=yes local-forwarding=yes \
    name=datapath1aadm
    add bridge=bridgeKLIENT client-to-client-forwarding=yes name="datapath2 kli"
    /caps-man configuration
    add channel=channel11 channel.band=2ghz-b/g/n channel.control-channel-width=\
    20mhz country=poland datapath="datapath2 kli" \
    datapath.client-to-client-forwarding=no datapath.local-forwarding=no \
    name=cfg2GOPOGO rates.basic=1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps \
    rates.supported=1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps \
    security.authentication-types=wpa2-psk security.encryption=aes-ccm \
    security.passphrase=DOLCE123 ssid=GOPOGO
    /caps-man security
    add authentication-types=wpa2-psk name="sec adm" passphrase=789467894657xx
    add authentication-types=wpa2-psk name="sec GOPOGO" passphrase=DOLCE123
    add channel=3kanaly1_6_11 channel.band=2ghz-b/g/n \
    channel.control-channel-width=20mhz country=poland datapath=datapath1aadm \
    datapath.client-to-client-forwarding=yes datapath.local-forwarding=no \
    name=cfg2admin rates.basic="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps,\
    18Mbps,24Mbps,36Mbps,48Mbps,54Mbps" rates.supported="1Mbps,2Mbps,5.5Mbps,1\
    1Mbps,6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps" rx-chains="" \
    security="sec adm" ssid=DOLCE tx-chains=""
    add channel.band=5ghz-n/ac channel.control-channel-width=20mhz \
    channel.extension-channel=XXXX country=poland \
    datapath.client-to-client-forwarding=yes datapath.local-forwarding=yes \
    name=cfg-5ghz-ac security="sec adm" ssid=""
    add channel.band=5ghz-onlyn channel.control-channel-width=20mhz \
    channel.extension-channel=XX country=poland \
    name=cfg-5ghz-an security="sec adm" ssid=""
    /interface list
    add name=WAN
    add name=LAN
    /interface wireless security-profiles
    set [ find default=yes ] supplicant-identity=MikroTik
    /ip dhcp-server
    add authoritative=after-2sec-delay interface=ether1-WAN name=server3
    /ip ipsec profile
    add dh-group=modp2048 enc-algorithm=aes-256,aes-128,3des name=profile_1
    /ip ipsec peer
    add disabled=yes name=peer1 passive=yes profile=profile_1
    /ip ipsec proposal
    set [ find default=yes ] auth-algorithms=sha256,sha1 enc-algorithms=\
    aes-256-cbc,aes-128-cbc lifetime=0s pfs-group=none
    /ip pool
    add name=pool1-ADMIN ranges=192.168.1.50-192.168.1.150
    add name=pool2-KLIENT ranges=192.168.2.50-192.168.2.199
    add name=pool3_VPN ranges=10.10.10.10-10.10.10.200
    add name=dhcp ranges=192.168.1.50-192.168.1.150
    /ip dhcp-server
    add add-arp=yes address-pool=pool1-ADMIN authoritative=after-2sec-delay \
    disabled=no interface=bridgeADMIN lease-time=1h name=server1ADMIN
    add address-pool=pool2-KLIENT authoritative=after-2sec-delay disabled=no \
    interface=bridgeKLIENT lease-time=1d name=server2-KLIENT
    /ppp profile
    add dns-server=8.8.8.8,8.8.4.4 local-address=10.10.10.1 name=VPN-L2TP \
    remote-address=pool3_VPN use-encryption=required
    /queue simple
    add burst-limit=6M/9M burst-time=30s/30s disabled=yes max-limit=4M/8M name=\
    LimitowanieKlientow queue=default/default target=192.168.2.0/24
    queue1 queue=default/default target=55.10.55.132/32
    /snmp community
    set [ find default=yes ] addresses=0.0.0.0/0
    /system logging action
    set 0 memory-lines=1500
    /caps-man access-list
    add action=accept allow-signal-out-of-range=10s comment=accept disabled=yes \
    signal-range=-80..120 ssid-regexp=""
    add action=reject allow-signal-out-of-range=10s comment=reject disabled=yes \
    signal-range=-120..-81 ssid-regexp=""
    /caps-man manager
    set ca-certificate=auto certificate=auto enabled=yes
    /caps-man provisioning
    add action=create-dynamic-enabled master-configuration=cfg2admin name-format=\
    identity slave-configurations=cfg2GOPOGO
    add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=\
    cfg2GOPOGO name-format=identity
    /interface bridge port
    add bridge=bridgeADMIN interface=ether4
    add bridge=bridgeADMIN interface=ether2
    add bridge=bridgeADMIN interface=ether3
    add bridge=bridgeADMIN interface=wlan1
    /ip firewall connection tracking
    set tcp-established-timeout=5s
    /ip neighbor discovery-settings
    set discover-interface-list=LAN
    /interface detect-internet
    set detect-interface-list=all
    /interface list member
    add interface=ether1-WAN list=WAN
    add interface=bridgeKLIENT list=LAN
    add interface=bridgeADMIN list=LAN
    /interface wireless cap
    set certificate=CAPsMAN-CA-DBB4 discovery-interfaces=ether4 enabled=\
    yes interfaces=wlan1
    /ip address
    add address=55.10.55.132/24 interface=ether1-WAN network=55.10.55.0
    add address=192.168.1.1/24 interface=ether2 network=192.168.1.0
    add address=192.168.1.1/24 interface=bridgeADMIN network=192.168.1.0
    add address=192.168.2.1/24 interface=bridgeKLIENT network=192.168.2.0
    add address=55.10.55.131/24 interface=ether1-WAN network=55.10.55.0
    add address=192.168.103.1/24 disabled=yes interface=bridgeADMIN network=\
    192.168.103.0
    /ip dhcp-server network
    add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1 \
    netmask=24
    add address=192.168.2.0/24 dns-server=192.168.2.1 gateway=192.168.1.1 \
    netmask=24
    /ip dns
    set allow-remote-requests=yes cache-max-ttl=1d cache-size=512KiB servers=\
    83.238.216.22
    /ip dns static
    add address=192.168.1.1 name=router.lan
    /ip firewall address-list
    add address=192.168.1.0/24 list=SiecAdmin
    add address=192.168.2.0/24 list=SiecKLIENT
    /ip firewall filter
    add action=drop chain=forward comment="defconf: drop invalid" \
    connection-state=invalid
    add action=drop chain=forward comment=\
    "defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1-WAN
    add action=accept chain=input dst-port=5246,5247 protocol=udp
    /ip firewall mangle
    add action=mark-connection chain=input disabled=yes dst-address=55.10.55.132 \
    log=yes new-connection-mark=klient2 passthrough=yes
    /ip route
    add check-gateway=ping disabled=yes distance=1 gateway=192.168.4.10 \
    routing-mark=do_WAN1
    add check-gateway=ping disabled=yes distance=1 gateway=192.168.116.1 \
    pref-src=192.168.2.1 routing-mark=do_WAN2
    /ip service
    set telnet disabled=yes
    set ftp address=192.168.1.0/24 disabled=yes
    set www address=192.168.1.0/24,192.168.103.0/24
    set ssh address=192.168.1.0/24 disabled=yes
    set api disabled=yes
    set winbox address=\
    192.168.1.0/24,192.168.103.0/24,192.168.2.0/24,55.10.55.0/24
    set api-ssl disabled=yes
    /ip socks
    set enabled=yes port=4145
    /system clock
    set time-zone-name=Europe/Warsaw
    /system identity
    set name=nowenowe
    /system logging
    set 0 action=echo
    set 2 action=echo
    set 3 action=memory
    add topics=firewall
    add action=echo topics=wireless
  • #2 20512537
    m.jastrzebski
    Specjalista Sieci, Internet
    Ocena: 864
    Zacznij od zmiany wszystkich haseł. Bo właśnie jest publicznie całemu światu pokazałeś :-( Razem z publicznym IP.
    Na moich obu mikrotikach na wszystkich portach loop protect jest ustawiony na default a status ma off. Moze spróbuj ustawić na off?
  • #3 20512575
    likierpp
    Spokojnie, adresy i hasła zmieniłem przed wklejeniem..
    Z ustawieniami loop protect na default urządzenie się rozkłada całe i jest niedostępne po otrzymaniu pakietu sam od siebie..
    Myślę, że to ma związek z capsmanem.. tylko jaki😲
